MAP not showing any value
- Snake____1
Hi there,
Any suggestions on why the MAP value isn't showing up?
I have tried both PA0 and PA7 for comparison. @2.63v the MAP value is reading 0. On floating in a noisy 50hz enviroment MAP value bounces around 56kpa.
Just downloaded the new firmware 20180104_1855 and still no value.
(X) BMW E36 318i M50B50 Turbo (MegaSquirt (KdFI v1.3))
(X) BMW E36 325tds M70B50 (ViPEC V88)
(X) BMW E36 328i M52B28 Turbo (rusEFI PnP @me)
(✓) BMW E36 320i M70B50 (rusEFI project car)
(✓) BMW E46 325Xi M57D30 (daily)
Re: MAP not showing any value
please post
mapinfo
and
analoginfo
output from console
mapinfo
and
analoginfo
output from console
- Snake____1
Ah, I see! But it's limited to 250kpa... What does this limitation correlate to?
2018-01-06 01_45: EngineState: confirmation_mapinfo:7
2018-01-06 01_45: EngineState: instant value=256.08kPa
2018-01-06 01_45: EngineState: map type=0/MT_CUSTOM MAP=0.00kPa mapMinBufferLength=1
2018-01-06 01_45: EngineState: MAP 2.13v @PA0
2018-01-06 01_45: EngineState: at 0.00v=0.00 at 5.00v=300.00
2018-01-06 01_45: EngineState: WARNING: unexpected MAP value: 256.08
2018-01-06 01_45: EngineState: confirmation_analoginfo:10
2018-01-06 01_45: EngineState: analogInputDividerCoefficient: 2.00
2018-01-06 01_45: EngineState: fast enabled=Yes
2018-01-06 01_45: EngineState: hip9011 ADC10 fast PC0 adc=0.20/input=0.41v/divider=2.00
2018-01-06 01_45: EngineState: ADC is not assigned for fuel gauge
2018-01-06 01_45: EngineState: TPS ADC2 slow PA2 adc=0.00/input=0.00v/divider=2.00
2018-01-06 01_45: EngineState: ADC is not assigned for pPS
2018-01-06 01_45: EngineState: CLT ADC12 slow PC2 adc=2.29/input=4.59v/divider=2.00
2018-01-06 01_45: EngineState: IAT ADC11 slow PC1 adc=2.29/input=4.58v/divider=2.00
2018-01-06 01_45: EngineState: AFR ADC13 slow PC3 adc=0.00/input=0.00v/divider=2.00
2018-01-06 01_45: EngineState: MAP ADC0 fast PA0 adc=2.13/input=4.26v/divider=2.00
2018-01-06 01_45: EngineState: ADC is not assigned for OilP
2018-01-06 01_45: EngineState: ADC is not assigned for A/C sw
2018-01-06 01_45: EngineState: HIP9011 ADC10 fast PC0 adc=0.20/input=0.40v/divider=2.00
2018-01-06 01_45: EngineState: Vbatt ADC14 slow PC4 adc=0.98/input=8.49v/divider=8.60
250kpa is a lot of forced induction! What units do you speak?
normal atmosphere should be 100kpa give or take.
- Snake____1
Yeah, I know. Hehe...russian wrote:250kpa is a lot of forced induction!
300kpa = 2bars of boost.
I have a 3bar MAP sensor. I might swap it out for a MPXH6400A "4bar" over time. Running 1.5bars of boost isn't to uncommon for a forged engine So I would like to try 2bars at another date
Maybe you should add a customizeable maximum MAP value?
- Snake____1
Also note, the VE table almost looks inverted for some odd reason... Any Idea as to why?
- VEtable
- VEtable.png (204.93 KiB) Viewed 9022 times
Because certain areas were self-tuned for longer than others, while some areas were never touched? (see the green and red maps on the right)Snake____1 wrote:Any Idea as to why?
Hi,
I take this post to ask a question.
What is the maximum pressure that rusEFI can handle?
Because I am preparing a car file for drag, and I am aiming for a maximum turbo pressure of 340 to 350kpa.
But I do not understand why I can not put values above 300kpa
- AFR_Tab.jpg (165.69 KiB) Viewed 8813 times
No reason, will change limit to 500kpa
What is your MAP sensor maximum pressure hold ???
Model of your MAP sensor ??? PDF !!!
Thanks a lot...
https://github.com/rusefi/rusefi/commit/ee3e6c1eaf53b97cfc2266a974075d6e777280da
I will try soon
Peugeot 1.6 16v with gtx3071r for dragrace.
Hop more than 450hp for the moment.
Pics & video soon
One question, I would like to know if LC & NLS work?
