52 pin connector for Galant VR4 pnp
gptech2444
Post by gptech2444 »
Hi,
Just picked up another car and I would like to do a pnp.
1992 Galant VR4
This is the connector 52pin ND
Picture from diyautotune.
Does anyone know of anyone else that does a pcb to wire up one of these connectors?
Re: 52 pin connector for Galant VR4 pnp
24 pin plug www.te.com/usa-en/product-172317-7.html
18 pin housing 172316-7
10 pin housing 172315-7
contacts 170353-1
This series is called "pulse lock"
The housing you have is http://www.te.com/usa-en/product-172319-1.html
Now you need to interest someone to design the PCB :)
gptech2444
russian wrote:
Sun Feb 04, 2018 10:25 am
If I say pretty please you'll make some?
It will be a bit of time before I could do this. I'm trying to focus on the Common Rail Diesel board. I wonder if I might be able to encourage @ to give this a go. The below link is the last one I did, it's a fairly good reference.
https://rusefi.com/forum/viewtopic.php?f=4&t=1303
I might need an occasional poke as a reminder to keep this on the radar.
gptech2444
The prices just for the connectors are quite high.
I might just get the connector from DIYautotune when I'm ready to do it.
Once @ gets to merge, this should be available for review.
That's some sweet progress :)
Some files are now available at https://github.com/rusefi/rusefi/tree/master/hardware/172319-1_52pin-connector but at the moment KiCAD application and knowledge are required. Let's produce PCB pdf files to enable simpller paper printing test?
We now have https://github.com/rusefi/rusefi/blob/master/hardware/172319-1_52pin-connector/172319-1_connector_LAYOUT.pdf
Next step is printing this at 100% scale and checking if that looks right against a real physical connector. I might have one at home by the way but I am couple weeks away from home.
Also are there silk screen suggestions? Right now there basically isn't anything more than a revision number.
Joeldc510
Post by Joeldc510 »
kb1gtt wrote:
Sun Feb 04, 2018 1:09 pm
Sorry guys, my laptop's power supply circuit gave up on me and didn't purchase a laptop until today basically :?
