Alternator field control circuit
Re: Alternator field control circuit
It just works
Is it as simple as this? Where do you place the diode for flyback?
Is not miata alternator controlled by just logic level pwm signal? I believe my 2001 miata controls the alternator with only frankenso as is.
On dodge neon yes we used that large mosfet with the small addon board. I need to document better when i get home on Saturday
Yes, you are correct, I thought we still needed some external chip before the alternator.russian wrote: ↑Wed Apr 11, 2018 11:34 amIs not miata alternator controlled by just logic level pwm signal? I believe my 2001 miata controls the alternator with only frankenso as is.
https://rusefi.com/wiki/index.php?title=Vehicle:Mazda_Miata_1999
