[help needed] MX5 36-1 triger
atntpt
MX5 36-1 triger
Post by atntpt »
Hi! I want to run my NB with 36-1 trigger wheel.. Can someone help me whit the config ? The custom trigger wheel shuld be used with half moon cam.. But my cam trigger is different.. is NB1(non vvt) stock... is this posible?
BTW the PN is (ZM 01-11-408) higher resolution :D :?: :?:
Re: MX5 36-1 triger
Dude, HOW DO YOU KNOW THAT I try to run my VVT car with ZM-DE 2000 protege 36/1 trigger wheel ZM 01-11-408 TOMORROW?
The engine is in the car already we just need to hook fuel and TB. Hopefully there will be a video and tune file tomorrow. As for your NB1, you can just pretend to be VVT with VVT broken and custom VVT shift, so should work.
atntpt
Re: MX5 36-1 triger
Post by atntpt »
My turbo whistle to me you would !!! :D :D I will keep following your status about that !!! Hope it works ... I'm a bit paranoid about timming precision :shock: I'm not the kind of guy who likes guessing :mrgreen:
Re: MX5 36-1 triger
Well, it has just fired right away once we found the magic trigger offset value of 76 with a timing gun. Tune attached.
