magneti marelli trigger pathern
atntpt
hi, can someone help me to figure out the settings, if possibele, to make this pathern work?
Re: magneti marelli trigger pathern
You cannot just apply settings without changing the code but I can change the code for you.
Can you please tell me more about this trigger pattern? What vehicles have used it? What years?
atntpt
It's Fiat /Lancia IAW P8 from the 90' from 2.0 16 v turbo engine my specific car is a Lancia Coupe
I should have it done in maybe two or three days, maaaaaaaaaaaybe later today
https://github.com/rusefi/rusefi/issues/619
Actually done, this one was easy. You can download latest firmware, create new project and there will be another item on the list.
atntpt
Thank you very much for the speed with which you created the decoder. Did you notice that there are 2 different signs? the crankshaft signal is a wheel with 4 teeth and on the cam you have 2 teeth with 180 degree spacing. of what it seems to me that you have created only contemplate the part of the cam sensor. the signs have different appearance because the one of the crankshaft is vr and in the cam is hall
Yep, you are right. Good news is that you should be able to start as is, once you have it running we will add missing signals to increase precision.
