Fiat Coupé 16v Turbo
This boy will be soon running on DIY frankenso Fully rebuilt engine as well as everything else in the car.
Simple question, I'm using 60-2 with 1 tooth sync cam , can that cam tooth be anywhere on the engine phase or has to be in a specific place ?
- IMG_20190302_202816.jpg (3.2 MiB) Viewed 12422 times
Re: Fiat Coupé 16v Turbo
https://en.wikipedia.org/wiki/Fiat_Coup%C3%A9 it's beautiful car!
When I have a two acre parking lot I will import this one and also https://en.wikipedia.org/wiki/Opel_Calibra
This one is like new !
- received_318352482372172.jpeg (873.33 KiB) Viewed 12418 times
I believe you are asking about the crank angle offset. I believe you can put the missing tooth at any crank angle, then use the crank angle offset and a timing gun to set it to TDC. Once this offset is known and set in the parameters, then you are good to go.
Also is your crank wheel OEM? If not, could you use an OEM crank wheel?
Crank offset is already defined , I was really asking about Camshaft "sync" signal to run sequencial.
Original trigger uses something similar to Nissan CAS but was removed .
So crank is defined with correct offset and working the question was if there is any rule to CAM sync signal in degree in the cycle . I think in some cars it's at TDC of 1st cylinder .
I saw an offset setting but was for vvt which I don't have .
All you care about is "first half" or "second half" - that's all your cam would be used for, to identify phase.
See https://rusefi.com/s/vvt
TKANKS!
about baro correction, i only was able to find the table on console not on TS plus i cant set sensor specs, can you help with that?
EDIT: ok found the table why is it only active on Speed desity? plus still unable to set sensor values
Baro is not implemented yet.
oh okay there is any way to put a bounty on some features? like baro and launch?
the equation is very simple (MAP/Baro)*100 = % Load i guess the implementation not that much but it would be great to have it
You've got me interested
Do not have a test mule for launch but baro we should be able to add.
Current rusEfi SD formulas - where would you like to see see Baro in kPa there? Probably (Baro/100) somewhere, with Baro=100 if no baro correction
I think something like map=(map/baro)*100
I have some cars I can use as test mules launch isn't I think I find useful ether but people seams to love pops and bangs for no reason ahahahhaha .
Baro sensor setting wasn't TS available, thank to Andreika direction I was able to add couple line to ini and it's now configurable
- 15532842055973598084103745879854.jpg (5.7 MiB) Viewed 12348 times
https://github.com/rusefi/rusefi/blob/master/firmware/tunerstudio/rusefi.ini says
Let's do it right and not post details about how to do it wrong
; rusefi.ini is generated by invoking gen_config.bat (look inside for the exact command to run it outside of Windows)
; inputs are rusefi.input template and rusefi_config.txt file
great thats working!!
about launch anything i can do?
Just a couple more photos
- received_272055913511506.jpeg (120.91 KiB) Viewed 12308 times
- received_1805760412858623.jpeg (35.89 KiB) Viewed 12308 times
If you have first hand experience using launch control we better continue at https://rusefi.com/forum/viewtopic.php?f=5&t=871
do you have vehicle speed sensor on this car?
