[info] electronic throttle body control ETB
It's all about the code!
You have this is about 247 magic metric?
I think my record was closer to 150 but then again that's a random metric on a random test.
Just registered a free webex account, maybe we will record a tune session with @
960
Post by 960 »
With most of the settings I have tested with TPS "hangs" at around 20% at the way down when releasing pedal.
Playing with a non linear bias curve solve it, but hard to get correct.
So a automatic setup would be the most accurate I think.
Some boring progress pair tuning session which revealed https://github.com/rusefi/rusefi/issues/775 and https://github.com/rusefi/rusefi/issues/776
Is this two throttle bodies on the passenger side of this Lamborghini Murcielago v12 meaning four throttle bodies total?! Not that this is our most immediate concern :)
Throttle-Body-Valve-Assembly-0013000325-OEM-62L-V12-Lamborghini-Murcielago-272460829340-4.jpg
Throttle-Body-Valve-Assembly-0013000325-OEM-62L-V12-Lamborghini-Murcielago-272460829340-4.jpg (201.23 KiB) Viewed 37287 times
Throttle-Body-Valve-Assembly-0013000325-OEM-62L-V12-Lamborghini-Murcielago-272460829340-2.jpg
Throttle-Body-Valve-Assembly-0013000325-OEM-62L-V12-Lamborghini-Murcielago-272460829340-2.jpg (158.48 KiB) Viewed 37287 times
Throttle-Body-Valve-Assembly-0013000325-OEM-62L-V12-Lamborghini-Murcielago-272460829340-6.jpg
Throttle-Body-Valve-Assembly-0013000325-OEM-62L-V12-Lamborghini-Murcielago-272460829340-6.jpg (295.32 KiB) Viewed 37287 times
960
Post by 960 »
Is anyone able to translate Chapter ADVE, BGDVE, DDVE and GGDVE to english ?
http://files.s4wiki.com/docs/MED9.1%20TFSI.pdf
or
960
Post by 960 »
These chapters are interesting:
3.5 Vorsteuerung des I-Anteils
Aufgrund der stark nichtlinearen Regelstrecke wird bei einer DK-Bewegung durch den
Notluftpunkt (NLP) und aus dem Bereich des UMA heraus, der I-Anteil ¨uber eine
Vorsteuerung manipuliert.
Befindet sich die DK in der N¨ahe des UMA, so zieht sich der I-Anteil aufgrund der dort
stark erh¨ohten Reibung auf große negative Werte auf. Daher wird, wenn der DK-Sollwert
¨uber die Schwelle DLRUMABAND steigt und sich der I-Anteil auf ¨uber DLRUMAIINI
aufgezogen hat, der I-Anteil auf den kleineren Vorladewert DLRUMAIINI gesetzt.
Bei einer Bewegung der DK durch den NLP findet dort ein Momentensprung mit
Richtungsumkehr statt. Dieser Sprung wird mit einem Delta-I-Anteil DLRININI
kompensiert. Der Ablauf dieser Vorsteuerung ist nachfolgend beschrieben:
Das highword von dlriant_l ist f¨ur Messungen mit dem VS100 in dlriant_w verf¨ugbar.
3.7 digitaler PID-Regler
Die Reglerstruktur besteht aus einem PID-Regler, wobei der D-Anteil nur mit dem
Istwert gebildet wird. Die Nichtlinearit¨aten der Strecke werden sowohl in den
Kennlinien f¨ur den I-Anteil, als auch in bereichsabh¨angigen Parametern ber¨ucksichtigt.
Eine Bewegung der DK durch den NLP der DV-E wird durch Umladen des I-Anteils
unterst¨utzt, siehe Kapitel 3.2.
Der Regler wird in einem 1 ms - Grundraster und einem 3-fach verschr¨anktem 1 ms -
Raster (entspricht einem 3 ms - Raster) abgearbeitet.
Im 1 ms - Raster werden die Regelabweichung dwdkdlr_w, der D-Anteil, die Summe aller
Regleranteile (dlriant_l, dlrikl_w, dlrpant_l und dlrdant_w) und das PWM-Signal
(Betrag dlrspid_w und Vorzeichen B_dlrspid) berechnet (siehe Bild "pid_controller"
im Block FDEF). Der D-Anteil wird auf +/- 1000 %PWM begrenzt. Zus¨atzlich wird vor
der Bereitstellung des PWM-Signals der resultierende Wert (dlrkomp) aus der Kompensation
und der ver¨anderten Kreisverst¨arkung eingerechnet. Das PWM-Signal ist auf +/- 100 %PWM
begrenzt.
Im 3 ms - Raster werden die einzelnen Raster in der Z¨ahlweise 1 0 -1 1 0 ...
abgearbeitet. Im Raster 1 wird der I-Kleinanteil dlrikl_w berechnet. Dieser IKleinanteil
wird zum Losreißen der DK aus der Haftreibung verwendet. Der I-Kleinanteil
wird auf +/- 100 %PWM begrenzt. Im Raster 0 werden die Reglerparameter in Abh¨angigkeit
von der DK-Position (¨uber/unter NLP mit wdkba_w) und unter dem NLP (wdkba_w <
wdknlp_w) in Abh¨angigkeit von der Sprungh¨ohe des DK-Sollwertes (gwdkdlr_w) bestimmt.
Weiterhin wird hier der I-Anteil dlriant_l berechnet und auf +/- dlriamax begrenzt. Im
Raster -1 wird der P-Anteil berechnet und auf +/- 1000 %PWM begrenzt.
Der I-Klein-Anteil ist ¨uber das Codewort CWDLRIKL = false abschaltbar.
F¨ur den Betrieb des DV-E5 mit unverst¨arktem Potentiometer (B_wdk1v = false) unterm NLP
steht ein eigener Parametersatz zu Verf¨ugung.
3.5 feedforward control of the I component
Due to the highly non-linear controlled system is at a DK movement through the
emergency air point (NLP) and out of the range of the UMA, the I component manipulated via a feedforward
control.
If the DK is in the vicinity of the UMA, the I component
absorbs large negative values due to the much higher friction there . Therefore, if the DK setpoint
rises above the threshold DLRUMABAND and the I component has spread to DLRUMAIINI
, the I component is set to the smaller pre-load value DLRUMAIINI.
In a movement of the DK by the NLP there is a momentum jump
Reversal of direction. This jump is
compensated with a delta I component DLRININI . The sequence of this
precontrol is described below: The highword of dlriant_l is available for measurements with the VS100 in dlriant_w.
3.7 digital PID controller
The controller structure consists of a PID controller, whereby the D component is formed only with the
actual value , The non-linearities of the path are taken into
account both in the characteristic curves for the I-component and in the range-dependent parameters.
A movement of the DK by the NLP of the DV-E is supported by reloading the I-part
, see chapter 3.2.
The controller is processed in a 1 ms basic grid and a 3-fold scaled 1 ms
grid (corresponds to a 3 ms grid).
In the 1 ms grid, the control deviation dwdkdlr_w, the D component, the sum of all
controller components (dlriant_l, dlrikl_w, dlrpant_l and dlrdant_w) and the PWM signal
(amount dlrspid_w and sign B_dlrspid) are calculated (see figure "pid_controller"
in block FDEF) ). The D component is limited to +/- 1000% PWM. Additionally, before
providing the PWM signal, the resulting value (dlrkomp) from the compensation
and the changed loop gain is included. The PWM signal is limited to +/- 100% PWM
In 3 ms - scanning the individual pixels in the Z¨ahlweise 1 0 -1 0 1 ... are
processed. In grid 1, the small I component dlrikl_w is calculated. This small amount
is used to tear the DK out of static friction. The low I component
is limited to +/- 100% PWM. In grid 0, the controller parameters are determined as a function
of the DK position (above / below NLP with wdkba_w) and below the NLP (wdkba_w <
wdknlp_w), depending on the jump height of the DK setpoint (gwdkdlr_w) ,
Furthermore, the I component dlriant_l is calculated here and limited to +/- dlriamax. In
grid -1, the P component is calculated and limited to +/- 1000% PWM.
The I-Klein component can be switched off via the codeword CWDLRIKL = false.
For the operation of the DV-E5 with an unknown potentiometer (B_wdk1v = false) under NLP
, a separate parameter set is available.
ADVE
APP VPSKO 3.40.1 Application Notes
Underlying for first application:
CWVPSKO = 0
CWVPSKO: Bit 0 = true: to the application, as long as the torque structure is not applied, MIN (PSSCHAP and psmxschs_w) can be specified
Bit 0 = false: normal operation
Bit 1 = true: for the application: Specify psxhmms_w directly in the HMM mode via PSHMMSP
Bit 1 = false: normal operation
Bit 2 = true: for the application: in the HOS mode, specify psxhoss_w directly via PSHOSSP
Bit 2 = false: normal operation
Bit 3 = true: for application: Specify psxschs_w directly via PSSCHSP in SCH mode
Bit 3 = false: normal operation
Bit 4 = true: for the application: in the SKH mode, specify psxskhs_w directly via PSSKHSP
Bit 4 = false: normal operation
Bit 5 = true: to the application, as long as the torque structure is not applied, the map is addressed via rk
Bit 5 = false: normal operation
KFPSMXRKAP for application as long as the torque structure is not yet filled. However, care should be taken not to
all maps have 10 x 10 stucco points but in some cases less stubs
KFPSMXHMM the mapping of the 3 maps from the optimization of e.g. Flammability, consumption, .... from
KFPSMXHOS
KFPSMXSCH
Note:
An excessively large number of support points for the project (for example in the map KFPSMXSCH) can be obtained by equal treatment of adjacent ones
Reduce support points (and associated map values) during integration.
PSSKHAP = 900 hPa
PSHMMAP = 900 hPa
PSHOSAP = 900 hPa
PSSCHAP = 900 hPa
FU ADVE 10.20.0 Control of the DV-E with the DLR
FDEF ADVE 10.20.0 Function definition
Main:
Check_of_battery_voltage
if
if not
Monitoring_of_position
SY_UBR 0
Switch_on_coordination_of_powerstage
Digital_PID_controller
Monitoring_of_PID_rang
960
Post by 960 »
Just checked some flash files in winols, and found ADVE with all the constants:
Simon@FutureProof
Slack: Orchardperformance
Post by Simon@FutureProof »
Abricos wrote:
Sun Apr 28, 2019 3:15 am
control.
, see chapter 3.2.
In 3 ms - scanning the individual pixels in the Z¨ahlweise <Copy error "Zählweise" "counting" 1 0 -1 0 1 ... are
DLRUMABAND - Uncertainty band at jump from UMA area
DLRUMAIINI - Precharge value I component for jump from UMA range
DLRININI - I share at initiation of the NLP function
DK - DrosselKlapp - Throttle Flap
NLP - Notluftpunkt - Emergency air point (limp home angle?)
DV-E or DV-E5 - Bosch ETB for this generation
FDEF - Funktion Definition
UMA - Overwatch/watchdog concept for shutdown path (I think?) - might be closed position but the document is unclear on the definition of UMA
dwdkdlr_w - Differential throttle angle setpoint - actual value
dlriant_l - DLR, I share
dlrikl_w - DLR, I-small share
dlrpant_l - DLR, P share
dlrdant_w - DLR, P small share
dlrspid_w - DLR for DV-E: Sum of PID shares
B_dlrspid - Condition: DLR, sign of the sum of the PID components, = 1: positive, = 0: negative
dlrkomp - DLR, factor loop gain
wdkba_w - Throttle angle related to lower stop
wdknlp_w - DK angle of the emergency air position
gwdkdlr_w - Change of throttle target angle, amount for characteristic input
dlriamax - DLR, maximum possible I share
CWDLRIKL - Codeword: DLR-I-small share active
B_wdk1v - Condition Calculation of the DK angle from amplified signal from potentiometer 1
DLR - Delta Torque for Idle speed control
960
Post by 960 »
ADVE Functions:
/*					Module Internal Definitions    						*/
/* Define-Constants														*/
#define		IANT_MIN		-511	/* -100 % in high-part of dlriant_l */
#define		IANT_MAX		511		/* 100 % in high-part of dlriant_l	*/
#define		POTI_MASK 		0xFFFC
/*#define	WDKS_KONST		5872026l */
/*#define	CORR_WDKS		(WDKS_KONST / MICROSECONDS_TO_TICKS(10000)) */
#define		CORR_WDKS		179
#define		CORR_UB			128
#define		REL_2			255
#define		HUNDRED_PERCENT	4095	/* 100 % of range -800..800*/
#define		INIT_DLRBAT		0x8000	/* = 1 (16 Bit)	*/
#define		INIT_DLRI		16		/* 1 % 			*/
#define		P5OF100			328u	/* 0,5 of range 100 % */
#define		P5OF1600		20	/* 0,5 of range -800..800 % */
#define		DANTMAX			 5120	/*  1000 %PWM, q = 0.19531%PWM */
#define		DANTMIN			-5120	/* -1000 %PWM, q = 0.19531%PWM */
#define		MAXDK			 4095	/*  100 %DK, q = 0.02441 */
#define		MINDK			-4095	/* -100 %DK, q = 0.02441 */
#define		MAXDLRPANT		 4095	/*  800 %PWM, q = 0.19531 */
#define		MINDLRPANT		-4095	/* -800 %PWM, q = 0.19531 */
#define		MAXDLRIKL		 512	/*  100 %PWM, q = 0.19531 */
#define		MINDLRIKL		-512	/* -100 %PWM, q = 0.19531 */
#define		MAXELEMENT		31		/*  32 table-values */
#define		MAXELEMENTSHL	248		/*  32 table-values */
/* Macros Local To This Module											*/
/* Local Module RAM-Definitions (attribute static)						*/
/* Definition of variables only local to this module. That is, not to 	*/
/* be exported to other modules and not relevant for calibration. 		*/
/*static	<data type>		<name>;										*/
/* Local Prototypes (attribute static)									*/
/* Declarations (Prototypes) of functions, only used in this module   	*/
static void dlrber_test(void);
/* module description
function:	drive of DVE with digital attitude control
			(Ansteuerung des DVE mit dem digitalen Lageregler)
/* modul inputs       */
/* dlrd				   		0 .. 1020 %PWM/%DK	 8 Bit	q=4 %PWM/%DK	  */
/* dlrdant_w			-1000 .. 1000 %PWM		14 Bit	q=0.19531 %PWM	  */
/* dlri			   		   0 ...  16  %PWM/%DK 	 8 Bit	q=0.0625 %PWM/%DK */
/* dlriant_l			-100 ... 100  %PWM		26 Bit	q=2.98e-6 %PWM	  */
/* highword dlriant_l	-100 ... 100  %PWM		10 Bit	q=0.19531 %PWM	  */
/* dlrikl_w				-100 ... 100  %PWM		10 Bit	q=0.19531 %PWM	  */
/* dlrndif_w			-200 ... 200  %DK		14 Bit	q=0.02441 %DK	  */
/* dlrpant is tempS16	-800 ... 800  %PWM		14 Bit	q=0.19531 %PWM	  */
/* dlrspid_w		   	   0 ... 100  %PWM		16 Bit	q=1.53e-3 %PWM	  */
/* dwdkdlr_w			-200 ... 200  %DK		14 Bit	q=0.02441 %DK	  */
/* dwdkdlra_w			-200 ... 200  %DK		14 Bit	q=0.02441 %DK	  */
/* dwdks_w				 -50 ...  50  %DK		16 Bit	q=1.53e-3 %DK	  */
/* wdkba_w				-200 ... 200  %DK		14 Bit	q=0.02441 %DK	  */
/* wdkbaalt_w			-200 ... 200  %DK		14 Bit	q=0.02441 %DK	  */
/* wdknlp_w		   		   0 ... 100  %DK		16 Bit	q=1.53e-3 %DK	  */
/* modul outputs      */
/*					Local Process Definitions		           			*/
#define START_SECTION_Task_r10ms
#include "pragma.h"
  	if( dlrpidc_w > KW_DLRPID2T )
		SET_B_dlrpide;		/* set error DLR control range at limitstop */
	#if (SY_CJ230 > 0)
		dveestatm = dveestat;
		if (dveestat>0)
		  	SET_B_dveese;	/* set DVE powerstage error */
	#else
		if (!GET_B_dveeson)
	#endif
  	else
    	if( dlrpidc_w > KW_DLRPID1T )
	#if (SY_DVEAIF > 0)
			if( ! (!GET_B_stend && (nmot < KW_DWDKNMOMIN) && ((tmot < KW_DWDKTMIN) || (tans < KW_DWDKTMIN)) ) )
				SET_B_dlrbe;
	#else
			SET_B_dlrbe;	/* request for rev. SKA */
	#endif
		else
	  		if( ! GET_B_dlrspi10 && (dlrpidc_w > KW_DLRPID0T) && (nmot == 0) )
				SET_B_dvete; 	/* extended exchange detection */
		dlrpidc_w++;		/* increment error counter (no OV, we are < DLRPID2T) */
		dlrpidrc_w++;		/* increment ice break error counter (no OV, we are < DLRPID2T)*/
		if( ! GET_B_dveeson )
		/* attempt for DVE powerstage healing (Powerstage_restart_test)*/
	  		if( dveesc >= KW_DVEEST )
	  			CLR_B_dveesh; 	/* reset switch-off-request of DVE powerstage */
	  		else
	    		dveesc++;		/* increment antibeat counter */
				if( dveesc >= KW_DVEEST)
		  			SET_B_dveesh;	/* set switch-off-request of DVE powerstage */
		else
	  		dveesc = 0;		/* reset antibeat counter */
#define STOP_SECTION_Task_r10ms
#include "pragma.h"
/*					Global Process Definitions		           			*/
/*	process: adve_ini2												   */
/*	purpose: 														   */
#define START_SECTION_Task_rini2
#include "pragma.h"
void adve_ini2(void)
	dlrkomp = KW_DLRKREIS;
	dlrbatkp_w = INIT_DLRBAT;
	dlrp = KW_DLRKPONLP0;
	dlri = INIT_DLRI;
	dlrd = KW_DLRKDONLP0;
	SET_B_dlrparc;
	SET_B_dlrumzu;
#if (SY_UBR == 0)
	SET_B_ubdve;
	SET_B_ubpvg;
	SET_B_ub_ok;		/* battery voltage is OK */
#endif
	dlrrast = 2;
	/* dlrhaftak	9 Bit  -100 ... 0 %	PWM	q=0,1953125 % PWM	*/
	/* DLRHAFTMN	9 Bit  -100 ... 0 %	PWM	q=0,1953125 % PWM	*/
	/* DLRININI		9 Bit   0 ... 100 %	PWM	q=0,1953125 % PWM	*/
	/* DLRKREIS		8 Bit	0.1 ... 2			q=7,8125e-3		*/
  	dlrhaftak = (sint16)(((sint32)KW_DLRHAFTMN << 7) / KW_DLRKREIS);
  	if( dlrhaftak < (sint16) IANT_MIN )	/* limitation to -100 % PWM */
		dlrhaftak = (sint16) IANT_MIN;
  	dlrini_w  = (KW_DLRININI << 7 ) / KW_DLRKREIS;
  	if( dlrini_w > IANT_MAX )		   /* limitation to 100 % PWM */
	dlrini_w = IANT_MAX;
  	SET_B_nldve1;
#if (SY_UBR > 0)
	SET_B_nldve;
  	/*** Battery voltage check BCHECK_1SG ***/
  	if ( GET_B_ubdve )
  	  	if ( ubrsq < SY_UBDEDIQ )	/* ub less than 7 V ? */
		  	CLR_B_ubdve;
		  	CLR_B_ubpvg;
  	else
  	  	if ( ubrsq > SY_UBDEENQ )	/* ub greater than  8 V ? */
		  	SET_B_ubdve;
		  	SET_B_ubpvg;
#if (SY_ACCSSRY > 0)
  	PUT_B_ub_ok( GET_B_ubdve && !GET_B_nachl);
#else
  	PUT_B_ub_ok( GET_B_ubdve && GET_B_kl15);
#endif
#endif
	/* for ICE-funktion */
  	SET_B_wdksg;    /* Set 'all seems well'-Signal */
#define STOP_SECTION_Task_rini2
#include "pragma.h"
/*	process: adve_1ms												   */
/*	purpose: 														   */
#define START_SECTION_Task_r1ms
#include "pragma.h"
void adve_1ms(void)
/* Das 1 ms Raster teilt sich in verschiedene Bereiche auf. Ein Teil, der bei jedem	*/
/* Durchlauf berechnet wird, drei Teile, die jeweils nur bei jedem dritten Durch-	*/
/* lauf gerechnet werden. Im ersten Teil werden Regelabweichung, Aktivierungs-		*/
/* schwellen für den D-Anteil, D-Anteil und das PWM-Tastverhältnis berechnet. Zudem	*/
/* erfolgt in diesem Teil die Ausgabe in den PWM-Kanal.								*/
/* Im 'case 2' des geteilten Rasters wird abhängig von B_dlrikla der I-Kleinanteil	*/
/* berechnet. In 'case 1' werden die Reglerparameter abhängig von NLP und der 		*/
/* I-Anteil bestimmt. Im letzten Teil ('case 0') wird der P-Anteil berechnet und	*/
/* die Summe von I-, P- und I-Klein-Anteil gebildet.								*/
	sint16		tempS16;
	uint16		tempU16;
	uint16		abs_dwdkdlr_w;
	uint16		abs_gwdkdlr_w;
	LInt		tempS32;
	uint8		tabindex;
	if ( ! GET_B_nldve1 )
		return;
  	#if (SY_DVEKOOR == 1)
	tempS16 = wdkdlr_w - wdkbak_w;
  	#else
	tempS16 = wdkdlr_w - wdkba_w;
  	#endif
	if (tempS16 >= MAXDK)		/* limit max. and min. DK-deviation */
		dwdkdlr_w = MAXDK;
	else if (tempS16 <= MINDK)
		dwdkdlr_w = MINDK;
	else
		dwdkdlr_w = tempS16;
	if(GET_B_wdk1v)					/* DK-angle from pot 1 */
		dlrdsv_w = DANTGESWV;
		dlrdsw_w = DANTSCHWV;
	else
		dlrdsv_w = DANTGESWNV;
		dlrdsw_w = DANTSCHWNV;
	dlrndif_w = wdkbaalt_w - wdkbak_w;
	wdkbaalt_w = wdkbak_w;		/* save actual value */
  	#else
	dlrndif_w = wdkbaalt_w - wdkba_w;
	wdkbaalt_w = wdkba_w;		/* save actual value */
  	#endif
	if ((dlrndif_w >= dlrdsv_w) || (-dlrndif_w >= dlrdsv_w) || (dwdkdlr_w > dlrdsw_w) || (-dwdkdlr_w > dlrdsw_w))
		tempS16 = (sint16)((dlrndif_w * dlrd) >> 1);	/* q = 0.19531%PWM = (0.02441%DK * 4%PWM/%DK) * 2 */
		if (tempS16 >= DANTMAX)
			tempS16 = DANTMAX;
		else
		  if (tempS16 <= DANTMIN)
			tempS16 = DANTMIN;
		tempS16 += sum_ipikl_w;		/* sum_ipikl_w  14bit  q = 0.19531%PWM */
	}									/* the calculation of sum_ipikl is at the end of dlrrast = -1 */
	else
		tempS16 = sum_ipikl_w;
	/* dlrspid_w = sum_ipikl_w * dlrkomp							*/
	/* q = 0.001526 %PWM = 0.19531 %PWM * 0.00781						*/
	/*     0.001526 %PWM = 0.001526 %PWM  -> no correction necessary !	*/
	/* limit dlrspid_w to 100 %PWM means range of 16 bit -> o.k.		*/
	if (tempS16 >= 0)
		SET_B_dlrspid;
		dlrspid_w = MulU16((uint16)tempS16,dlrkomp);
	else
		CLR_B_dlrspid;
		dlrspid_w = MulU16((uint16)-tempS16,dlrkomp);
	/* Output PWM-signal */
	/* Output of PWM-signal moved to HT2KTDVE */
	/* DISTORTED */
	dlrrast--;
	if (dlrrast == 1)
		/************** Raster 2 (dlrrast = 1) **************/
		if (GET_B_dlrikla && (KW_CWDLRIKL > 0))
			/*LRG_GO*/
			if (GET_B_dlriklst)
				dwdkdlra_w = dwdkdlr_w;
				wdkbas_w = wdkbak_w;
  				#else
				wdkbas_w = wdkba_w;
  				#endif
				CLR_B_dkbew;
				CLR_B_dlriklst;
			else
				/*STOPIKLEIN*/
				if ( ((dwdkdlr_w <= 0) && (dwdkdlra_w >= 0)) || ((dwdkdlr_w >= 0) && (dwdkdlra_w <= 0)) )
					CLR_B_dlrikla;	/*ClrBdlri*/
			/*DK-Bewegung*/
			if (!GET_B_iklrest)
				if (wdkbak_w >= wdkbas_w)
					tempU16 = (uint16)(wdkbak_w - wdkbas_w);
				else
					tempU16 = (uint16)(wdkbas_w - wdkbak_w);
  				#else
				if (wdkba_w >= wdkbas_w)
					tempU16 = (uint16)(wdkba_w - wdkbas_w);
				else
					tempU16 = (uint16)(wdkbas_w - wdkba_w);
  				#endif
				if ((tempU16 > KW_WDKBEWS) && !GET_B_dkbew)
					dlriklst_w = dlrikl_w;
					SET_B_dkbew;
			if (GET_B_dlrikla && !GET_B_dcdisfr)
				/*IKleinant*/
				/* dlrikl_w += dwdkdlr_w * DLRIKLPAR					*/
				/* dwdkdlr_w limited to 100%DK (12bit signed)			*/
				/* 0.19531%PWM += 0.02441%DK * 0.0625%PWM/%DK / corr	*/
				/* 0.19531%PWM += 0.0015256%PWM / corr					*/
				/* -> corr = 1/2^7 = (2^2 * 2^7) / 2^16					*/
				tempS32.lng = ((sint32)dwdkdlr_w << 2) * ((sint32)KW_DLRIKLPAR << 7);
				tempS16 = tempS32.wrd.h + dlrikl_w;
				if (tempS16 >= MAXDLRIKL)
					dlrikl_w = MAXDLRIKL;
				else if (tempS16 <= MINDLRIKL)
					dlrikl_w = MINDLRIKL;
				else
					dlrikl_w = tempS16;
			else
				dlrikl_w = 0;
		else
			if (GET_B_dcdisfr)
				dlrikl_w = 0;
	else if (dlrrast == 0)
		/************** Raster 1 (dlrrast = 0) **************/
		if (dwdkdlr_w >= 0)
			abs_dwdkdlr_w = (uint16)dwdkdlr_w;
		else
			abs_dwdkdlr_w = (uint16)(-dwdkdlr_w);
		if (abs_dwdkdlr_w >= MAXELEMENTSHL)
			tabindex = MAXELEMENT;
		else
			tabindex = (uint8)(abs_dwdkdlr_w >> 3);
		if (wdkbak_w >= (sint16)(wdknlp_w >> 4))
  	#else
		if (wdkba_w >= (sint16)(wdknlp_w >> 4))
  	#endif
			dlri = KWB_DLRKIONLP0(tabindex);
		else
			if( GET_B_wdk1v )
				if (GET_B_dlrparc)
					/*** abs_gwdkdlr_w ***/
					if( gwdkdlr_w < 0)
						if ( gwdkdlr_w == MININT16)
							abs_gwdkdlr_w = MAXINT16;	/* 8000h --> 7FFFh */
						else
							abs_gwdkdlr_w = (Word)-gwdkdlr_w;
					else
						abs_gwdkdlr_w = (Word) gwdkdlr_w;
					if (abs_gwdkdlr_w > DLRDWDKSS1)
						dlrp = KW_DLRKPUNLP0;
						dlrd = KW_DLRKDUNLP0;
						dlri = KWB_DLRKIUNLP0(tabindex);
					else if (abs_gwdkdlr_w > DLRDWDKSS2)
						dlrp = KW_DLRKPUNLP1;
						dlrd = KW_DLRKDUNLP1;
						dlri = KWB_DLRKIUNLP1(tabindex);
					else
						dlrp = KW_DLRKPUNLP2;
						dlrd = KW_DLRKDUNLP2;
						dlri = KWB_DLRKIUNLP2(tabindex);
				else	/* B_dlrparc == FALSE */
					if (abs_dwdkdlr_w > (DLRDWDKSS1>>4))
			else
				dlrp = KW_DLRKPUNLP3;
				dlrd = KW_DLRKDUNLP3;
				dlri = KWB_DLRKIUNLP3(tabindex);
		dlriant_l.lng += (((Int32)dwdkdlr_w << 2) * ((Int32)dlri << 7));
		if (dlriant_l.wrd.h <= (sint16)-dlriamax)
			dlriant_l.wrd.h = (sint16)-dlriamax;
			dlriant_l.wrd.l = 0;
		else
			if (dlriant_l.wrd.h >= (sint16)dlriamax)
				dlriant_l.wrd.h = (sint16)dlriamax;
	else
		/************** Raster 0 (dlrrast = -1) **************/
		tempS32.lng = (sint32)dwdkdlr_w * dlrp;
		if (tempS32.lng >= MAXSINT16)
			tempS16 = MAXDLRPANT;
		else if (tempS32.lng <= MINSINT16)
			tempS16 = MINDLRPANT;
		else
			tempS16 = (sint16)(tempS32.lng>>3);
		sum_ipikl_w = tempS16 + dlriant_l.wrd.h;
		sum_ipikl_w += dlrikl_w;
		dlrrast = 2;
#define STOP_SECTION_Task_r1ms
#include "pragma.h"
/*	process: adve_10ms												   */
/*	purpose: 														   */
#include "pragma.h"
void adve_10ms(void)
  	Word dlrspid10_w;	/* Copy of dlrspid_w from 1 ms process */
  	Int16 dwdkdlr10_w;	/* Copy of dwdkdlr_w from 1 ms process */
  	/* Take care! dwdkdlr10_w	is only used once and changed to ABS(dwdkdlr10_w)!! */
  	Int16 sollwert_w;
  	Int16 temp_S16;
 #if (SY_UBR > 0)
	if( !GET_B_nldve )
		return;
#endif
	PUT_B_dlrspi10(GET_B_dlrspid);
	dlrspid10_w = dlrspid_w;
	dwdkdlr10_w = dwdkdlr_w;
	/* Quantizations: ***************************************/
	/* DKNOTBEGR	0 ... 100 %DK	8 Bit	q=0,3906 %DK	*/
	/* dknbegr_u16	0 ... 100 %DK  12 Bit	q=0,02441 %DK	*/
	/* wdkdlr_w		0 ... 100 %DK  12 Bit	q=0,02441 %DK	*/
	/* wdkdlrz_w	0 ... 100 %DK  12 Bit	q=0,02441 %DK	*/
	/* gwdkdlr_w  -50 ...  50 %DK  16 Bit	q=1,526e-3 %DK	*/
	/* wdks_w		0 ... 100 %DK  16 Bit	q=1,526e-3 %DK	*/
	/* wdkada_w		0 ... 100 %DK  16 Bit	q=1,526e-3 %DK	*/
	/* 		function: registration set value 				*/
	if( GET_B_dkaden )
		sollwert_w = (sint16)(wdkada_w >> 4);
	else
		if( GET_B_appnolu )
			if( GET_B_dkp1e || GET_B_dkp2e || GET_B_i_ska_um || ! GET_B_ubdve
			|| GET_B_wdksive || GET_B_dlrbe || GET_B_dlrpide || GET_B_dknot)
				CLR_B_appnolu;
  			    sollwert_w = (sint16)(wdks_w >> 4);
			else
				sollwert_w = KW_WDKSAPNOL;
		else
  			if (GET_B_dknolu)
				sollwert_w = (sint16)((sub_U16U16_U16(wdknlp_w,P5OF100))>> 4);  /* only positive range used! */
			else
  #if (SY_DVEAIF == 3)
				if (GET_B_dkeisakt)
				  	sollwert_w = (sint16)(wdklosbs_w >> 4);	/* icefunction-throttle-preset */
				else
  #endif
				  	sollwert_w = (sint16)(wdks_w >> 4);		/* throttle-preset */
  		wdkdlrz_w = sollwert_w ;
		sollwert_w = sollwert_w + wdkoff_w;
		/* else	sollwert_w not changed */
	#endif
	#if (SY_DKZEROP == 1)
  		if (sollwert_w < KW_WDKLIMIT )
  		if (GET_B_edks)
			temp_S16 = wdkbak_w;
  		#else
			temp_S16 = wdkba_w;
		#endif
		else
  			temp_S16 = MINIMUM(wdk1k_w,wdk2k_w);
	  			temp_S16 = MINIMUM(temp_S16,wdkbak_w);
  		#else
  			temp_S16 = MINIMUM(wdk1_w,wdk2_w);
	  			temp_S16 = MINIMUM(temp_S16,wdkba_w);
		#endif
  			if (temp_S16 >= (KW_WDKLIMIT + P5OF1600))
				sollwert_w = KW_WDKLIMIT;
			else
				sollwert_w = MAXIMUM((wdkdlr_w - KW_WDKSTEP),sollwert_w);
	#endif
  	if (sollwert_w < 0)
		sollwert_w = 0;
  	else
	  	if (sollwert_w > HUNDRED_PERCENT )
	  		sollwert_w = HUNDRED_PERCENT;
	if( GET_B_wdk1v )		/* Poti 1 amplified ? */
		wdkdlr_w = sollwert_w ;	/* no mask, on account of accuracy of ampl. poti 1 */
	else
	wdkdlr_w = (sint16)((uint16)sollwert_w  & POTI_MASK);	/* adaption on not amplified poti 1 */
						   		/* 0..100            		0..100  from -800..800*/
  	gwdkdlr_w = sub_U16U16_S16((((Word)wdkdlr_w) << 4), (((Word)wdkdlra_w) << 4)) ;
	wdkdlra_w = wdkdlr_w;
	/* 		end function: registration set value 			*/
	/* 		function: power save function		 			*/
  	if(!GET_B_dkaden && (wped <= KW_MAXWPEDPWS) && (nmot == 0)
#if( SY_STASTO > 0)
	  && ! GET_B_staanf
#endif
#if (SY_TWDKS > 0)
	  && ! GET_B_cwdk
#endif
	if( dpwrsvc < KW_TPWRSV )
			dpwrsvc++;
		else
		{	/* switch off power stage */
			SET_B_pwrsv;
	else
	{	/* reset counter for powersave */
		dpwrsvc = 0;
		CLR_B_pwrsv;
	/* 		end function: power save function		 		*/
	/* 		function: manipulation of I quota				*/
	/*** absgwdkdlr ***/
	if( gwdkdlr_w < 0)
    		temp_S16 = MAXINT16;	/* 8000h --> 7FFFh */
    	else
    		temp_S16 = -gwdkdlr_w;
  	else
  		temp_S16 =  gwdkdlr_w;
	if (KW_CWDLRIKL > 0)
	/*** Initialization of small I-quota ***/
	/*   determination of start conditions */
		CLR_B_iklstar;
    	if( temp_S16 > 0)
			SET_B_dlrparc;
  	  		if( gwdkdlr_w < 0)
  	    		CLR_B_wdksauf;
  	  		else
  	    		SET_B_wdksauf;
			/** start conditions small-I-quota */
  	  		if( (temp_S16>>4) <= KW_DWDKSIKLS )
				if( ! GET_B_dlrikla )
					CLR_B_iklrest;	/* No restart, due to change of set value */
				SET_B_iklstar;		/* Condition for start small-I-quota met */
		else
      		CLR_B_dlrparc;
			/* restartconditions of small I-quota no changes of set value */
			/*absolute value of dwdkdlr_w */
  	  		if( dwdkdlr10_w < 0 )	   /* MININT not possible */
  	    		dwdkdlr10_w = -dwdkdlr10_w;
  	  		if((dwdkdlr10_w <= KW_DWDKSIKLS) && (( GET_B_wdk1v && (dwdkdlr10_w >= KW_WDKSTFEIN)) ||
  		  		( !GET_B_wdk1v && (dwdkdlr10_w >= KW_WDKSTGROB) )) )
					SET_B_iklrest;	/* restart, as there is no change of set value */
				SET_B_iklstar; 	/* Condition for retrigger small-I met */
		/* If there is a great leap of set value, small-I-quota is deactivated and set to zero */
    	if ( (temp_S16>>4) > KW_DWDKSIKLS )
			CLR_B_dlrikla;
			dlrikl_w = 0;
		/* Activation/Deactivation of small-I-quota */
		if( ! GET_B_dlrikla && GET_B_iklstar )
			SET_B_dlrikla;		/* set small-I */
			SET_B_dlriklst;		/* set 'small-I start' */
			/* Initialize parameters for small-I */
			if( GET_B_iklrest )
				dlrikl_w = 0;		/* no preset if retriggering */
			else
				/*** Quantizations ****************************************/
				/* dlriklst_w	-100 ... 100 %	10 bit	q = 0.1953 %	  	*/
				/* dlrikl_w		-100 ... 100 %	10 Bit	q = 0.1953 %  	*/
				/* WDKREIB		   0 ... 1		 8 bit	q = 0.003906  	*/
        		if( dlriklst_w < 0)
          			temp_S16 = -dlriklst_w;
        		else
          			temp_S16 = dlriklst_w;
        		dlrikl_w = (sint16)((uint32)temp_S16 * (uint32)KW_WDKREIB) >> 8;
        		if( ! GET_B_wdksauf )
          			dlrikl_w = -dlrikl_w;
	} /* end of initialization if small-I-quota */
	/* for data acquisition */
	dlriant_w = dlriant_l.wrd.h;
	/* preallocate I-Part for jump outside UMA-Band */
  	if( wdkbak_w <= KW_DLRUMABAND )
#else
  	if( wdkba_w <= KW_DLRUMABAND )
#endif
		if( wdkdlr_w >= KW_DLRUMABAND )
	  		if( dlriant_w < KW_DLRUMAIINI )
	    		dlriant_l.wrd.h = KW_DLRUMAIINI;
	/* precontrol of I-quota in default idle position */
	/* ... for closing direction */
	/**** Quantizations *******************************************/
	/* wdkdlr_w		0 ... 100 %		12 Bit		q=0.0244 % DK	*/
	/* wdknlp_w		0 ... 100 %		16 Bit		q=0.0015 % DK	*/
	/* wdkba_w	 -200 ... 200 %		14 Bit		q=0.0244 % DK	*/
	/* dlriant_l -100 ... 100 %		26 Bit		q=2.98e-6 % PWM */
	/* DLRNLPD		0 ... 100 %		16 Bit		q=0.0015 % DK	*/
	if( GET_B_dlrumzu )
		if( wdkdlr_w < (Int16)(sub_U16U16_U16(wdknlp_w, KW_DLRNLPD) >> 4) )
      		if( wdkbak_w >(Int16)(wdknlp_w >> 4) )
        		temp_S16 = wdkbak_w - (Int16)(wdknlp_w >> 4);
	  		else
	    		temp_S16 = (Int16)(wdknlp_w >> 4) - wdkbak_w;
	  	#else
      		if( wdkba_w > (Int16)(wdknlp_w >> 4) )
        		temp_S16 = wdkba_w - (Int16)(wdknlp_w >> 4);
	  		else
	    		temp_S16 = (Int16)(wdknlp_w >> 4) - wdkba_w;
	  	#endif
	  		if( temp_S16 > (Int16)(KW_DLRNLPD >> 4) )
	    		dlriant_l.wrd.h -= (sint16)dlrini_w;
	  		CLR_B_dlrumzu;
  	else
    	/* ... for opening direction */
    	if( wdkdlr_w > (Int16)(add_U16U16_U16(wdknlp_w, KW_DLRNLPD) >> 4) )
      		if( wdkbak_w > (Int16)(wdknlp_w >> 4) )
	  		else
  		#else
			else
  		#endif
	    		dlriant_l.wrd.h += (Int16)dlrini_w;
			SET_B_dlrumzu;
	/* limitation ob dlriant_l */
	if( dlriant_l.wrd.h > IANT_MAX )
		dlriant_l.wrd.h = IANT_MAX;		/* 100 % */
	else
		if( dlriant_l.wrd.h < IANT_MIN )
			dlriant_l.wrd.h = IANT_MIN;		/* -100 % */
	/* while power stage is switched off, reset I-part */
	if( GET_B_dcdisfr )
		dlriamax = 0;
		dlriklst_w = 0;
	else
		dlriamax = KW_DLRIAMAXA;
	/* 		end function: manipulation of I quota			*/
	/* 		function: Monitoring of PID range				*/
  	if ((!(GET_B_wdksive || GET_B_dlrpide)|| GET_B_appnolu)
  	   && !GET_B_dkpiu && !GET_B_i_ska_um
       #if (SY_SGANZ > 1)
	   && !GET_B_dcdiscan
	   #endif
		if( GET_B_ubdve && ! GET_B_dkaden && ! GET_B_pwrsv )
	  		if( ( GET_B_dlrspi10 && (dlrspid10_w > KW_DLRPIDMAX) )
	  		|| ( ! GET_B_dlrspi10 && (dlrspid10_w > KW_DLRPIDMIN) )
			|| (GET_B_dklosb && !GET_B_wdksg)
	#endif
        		dlrber_test();  /* out of signal range */
      		else
        		CLR_B_dlrbe;	/* clear reversible SKA */
				dlrpidc_w = sub_U16U16_U16(dlrpidc_w, KW_TDLRPIDC);	/* decrement error counter */
				if( dlrpidc_w > KW_DLRPID2T+1)
		  			dlrpidc_w = KW_DLRPID2T + 1;
        		CLR_B_dveesh;
     			dlrpidrc_w = 0; 	/* zero ice break error counter */
		else
			CLR_B_dveesh;
			CLR_B_dvete; /* reset extended exchange detection */
	else
      /* flag suspect for exceed control setting range */
  	PUT_B_dlrbev (dlrpidc_w > KW_DLRPID3T);
	/* observation of control setting range */
  	if ((dlrpidrc_w == 0)
  		&& !GET_B_dkeis
	#endif
      SET_B_wdksg;    /* set 'all seems well'-Signal */
  	else
	  	if (dlrpidrc_w > KW_DLRPID3T)
	      CLR_B_wdksg;    /* clear 'all seems well'-Signal */
	/* 		end function: Monitoring of PID range			*/
	/* 		function: switch on coordination of powerstage 	*/
	if (GET_B_dcdisr || ((GET_B_wdksive || GET_B_dlrpide ) && ! GET_B_appnolu) ||
		#if (SY_TWDKS > 0)
			(GET_B_dkpiu && !GET_B_lrnwt) ||
		#else
			GET_B_dkpiu ||
		#endif
			GET_B_i_ska_um ||
			GET_B_dveesh || ! GET_B_ubdve || GET_B_pwrsv
       	#if (SY_SGANZ > 1)
			|| GET_B_dcdiscan
		#endif
    	SET_B_dcdisfr;
  	else
		CLR_B_dcdisfr;
#include "pragma.h"
/*	process: adve_20ms												   */
/*	purpose: 														   */
#define START_SECTION_Task_r20ms
#include "pragma.h"
void adve_20ms(void)
	uint16 temp_u16;
	sint16 gwdkdlr20_w;	/* Copy of gwdkdlr_w from 10 ms process */
#if (SY_UBR > 0)
	if( ! GET_B_nldve ) /* after-run but no further demand for ADVE */
		return;					  /* then return */
#endif
	gwdkdlr20_w = gwdkdlr_w;       /* local copy */
	/* 		function: check of battery voltage 				*/
#if (SY_UBR > 0)
	/* 		function: check of ub			 				*/
	if(GET_B_ubg)
	    if ( GET_B_ubdve )
		  	    CLR_B_ubdve;
		  	    CLR_B_ubpvg;
  	    else
		  	    SET_B_ubdve;
		  	    SET_B_ubpvg;
	else
		CLR_B_ubdve;
		CLR_B_ubpvg;
	/* 		end function: check of ub		 				*/
    /* === block check_of_battery_voltage === */
    if ( GET_B_ubdve
        && !GET_B_nachl
      #else
  	    && GET_B_kl15
      #endif
        SET_B_ub_ok;
    else
        CLR_B_ub_ok;
#else  /* (SY_UBR > 0) */
	if ( GET_B_ubdve )
    	if ( ubsq < SY_UBDEDIQ )	/* ub less than 7 V ? */
  	  		CLR_B_ubdve;
  	  		CLR_B_ubpvg;
  	  		CLR_B_ub_ok;		/* battery voltage is too low */
  	else
    	if ( ubsq > SY_UBDEENQ )	/* ub greater than  8 V ? */
  	  		SET_B_ubdve;
  	  		SET_B_ubpvg;
#endif	/* SY_UBR > 0*/
	/* 		end function: check of battery voltage 			*/
	/* 		function: monitoring of position	 			*/
	if ( !GET_B_dkpiu && !GET_B_i_ska_um && GET_B_ubdve
       #if (SY_SGANZ > 1)
	   && !GET_B_dcdiscan
	   #endif
		if ( GET_B_dknolu && ! GET_B_appnolu )	/* observation of DK_NLP while driving in NLP */
			if( !GET_B_lrnerf ||
	    	( wdkbak_w > (Int16)add_U16U16_U16(wdknlp_w, KW_WDKNLPTOL) >> 4 )
  #else
	    	( wdkba_w  > (Int16)add_U16U16_U16(wdknlp_w, KW_WDKNLPTOL) >> 4 )
  #endif
      			SET_B_nlpne;		/* activate reversible SKA */
		    else
      			CLR_B_nlpne;	/* reversible SKA deactivate */
		else	/* observation of DK-Soll- / Istwert */
			CLR_B_nlpne;
		if( !GET_B_wdksive && !GET_B_dlrpide && !GET_B_dkaden && !GET_B_pwrsv )
				/* Quantization:												*/
				/* gwdkdlr_w    signed 16 bit  -50 ...49.9 %DK	q=0,001526 %DK	*/
				/* gwdk_kge		signed 15 bit    0 ...49.9 %DK	q=0,001526 %DK	*/
				/* dwdksimx	  unsigned  8 bit	 0 ... 100 %DK	q=0,392    %DK	*/
				/* wdksfi_w		signed 14 bit -200 ... 200 %DK	q=0,024414 %DK	*/
				/* wdkba_w	    signed 14 bit -200 ... 200 %DK	q=0,024414 %DK	*/
				/* DWDKSBAMX  unsigned 16 bit	 0 ... 100 %DK	q=0,001526 %DK	*/
	/* 		function: dk angle deviation mx		 			*/
			if( gwdkdlr20_w < 0)
	  			if ( gwdkdlr20_w == MININT16)
	    			gwdk_kge = MAXINT16;	/* 8000h --> 7FFFh */
	  			else
	    			gwdk_kge = (Word)-gwdkdlr20_w;/* gwdk_kge is input in KL DWDKSBAMX */
			else
	  			gwdk_kge =  (Word)gwdkdlr20_w;
			dwdksimx = (uint8)(KL_DWDKSBAMX >> 8);	/* use high byte */
	#if (SY_DVEAIF > 0)
			if( !GET_B_stend && (nmot < KW_DWDKNMOMIN) && ((tmot < KW_DWDKTMIN) || (tans < KW_DWDKTMIN)))
				dwdksimx = add_U8U8_U8( dwdksimx, KW_DWDKSTART);
	#endif
			if( wdksfi_w > wdkbak_w )
	  			temp_u16 = (Word)(wdksfi_w - wdkbak_w);
			else
	  			temp_u16 = (Word)(wdkbak_w - wdksfi_w);
		#else
			if( wdksfi_w > wdkba_w )
	  			temp_u16 = (Word)(wdksfi_w - wdkba_w);
			else
	  			temp_u16 = (Word)(wdkba_w - wdksfi_w);
		#endif
			if( (temp_u16 >> 4) > dwdksimx )
				if( dklagerc > KW_DKLAGERT )
				  	SET_B_wdksive;	/* set flag, for request notluftfahren */
				  #if (SY_CJ230 > 0)
				    if (dveestat>0)
				  #else
				    if (!GET_B_dveeson)
				  #endif
				else
	  				dklagerc++;			/* increment error counter */
			else
				if( dklagerc > KW_TDKLAGDE)
					dklagerc -= KW_TDKLAGDE;		/* reduce error counter */
	  			else
	    			dklagerc = 0;				/* limit error counter to zero */
				/* lowpass filter of DK-set value for prediction of DK-actual value */
				/* Result of filter is only in the next raster required */
				/* Quantization:										*/
				/* wdkdlr_w	  unsigned 12 bit	 0 ... 100 %DK  qa=0,024414 %DK */
				/* wdksfi_w		signed 14 bit -200 ... 200 %DK	qb=0,024414 %DK	*/
				/* ZKWDKSPT1  unsigned  8 bit    0 ... 0,7 		qz=0,002734 	*/
				/* correction factor cf for appropriate quantization:			*/
				/*	cf = 65536 * qz * 32768 / 781 = 7516  (CORR_WDKS = 7516)	*/
				/* WDKS_CONST = 65536 * qz * 32768 = 5872026					*/
				/*	cf = 65536 * qz = 179,2	  (CORR_WDKS = 179)					*/
				/* The result is then the high word of the lowpass filter.		*/
			wdkstp1_l.lng = tp1_S32( (uint16)ZKWDKSPT1 * CORR_WDKS, (sint16)wdkdlr_w,
				(sint16)wdkstp1_l.wrd.h, (uint16)wdkstp1_l.wrd.l);
			wdksfi_w = wdkstp1_l.wrd.h;		/* new filter value of wdksfi_w */
  	PUT_B_wdksivev(dklagerc > KW_DKLAGERTV);
	/* 		end function: monitoring of position	 		*/
#define STOP_SECTION_Task_r20ms
#include "pragma.h"
/*	process: adve_50ms												   */
/*	purpose: 														   */
#define START_SECTION_Task_r50ms
#include "pragma.h"
void adve_50ms(void)
	sint16 gwdkdlr50_w;
#if (SY_UBR > 0)
	if( ! GET_B_nldve )
		return;
#endif
	/* 		function: reduction of I-quota static friction	*/
	if( ! GET_B_dlrien )
		gwdkdlr50_w = gwdkdlr_w;
		if( gwdkdlr50_w < 0)	/* set absolute value of gwdkdlr_w */
			if ( gwdkdlr50_w == MININT16)
				gwdkdlr50_w = MAXINT16;		/* 8000h --> 7FFFh */
			else
				gwdkdlr50_w = -gwdkdlr50_w;
		if( (dlriant_l.wrd.h < dlrhaftak) && (gwdkdlr50_w <= KW_DLRHAFTST) )
		 	if ( dlrihaftc > KW_TDLRHAFTMX )
		 		dlriant_l.wrd.h = dlrhaftak;
		 		dlrihaftc = 0;
		 	else
		 		dlrihaftc++;
		else
			if (dlrihaftc > 0)
				dlrihaftc--;
#define STOP_SECTION_Task_r50ms
#include "pragma.h"
/*	process: adve_100ms												   */
/*	purpose: 														   */
#define START_SECTION_Task_r100ms
#include "pragma.h"
void adve_100ms(void)
	uint8 temp;
#if (SY_UBR > 0)
	if( ! GET_B_nldve )
		return;
#endif
	/* 		function: compensation battery voltage			*/
	/* Quantizstion ---------------------------------*/
	/* DLRUBSOLL	0 ... 25.5 V	8 Bit	0.1 V 	 */
	/* ubsq			0 ... 25.5 V	8 Bit	0.1 V 	 */
	/* dlrbatkp_w	0 ... 2		   16 Bit  30.52e-6  */
	/* ZKUBDLR		0 ... 0.5		8 Bit	0.00195	 */
	/* DLRKREIS		0 ... 2			8 Bit	0.00781	 */
	/* DLRKREISST	0 ... 2			8 Bit	0.00781	 */
	/* dlrkomp		0 ... 2			8 Bit	0.00781	 */
	/* ubrsq		0 ... 25.5 V	8 Bit	0.1 V	 */
	/* temp			0 ... 2			8 Bit	0.00781  */
	/* CORR_UB	128									 */
#if (SY_UBR > 0)
	if( ubrsq <= (KW_DLRUBSOLL >> 1) )	 /* limitation of temp to max. range (2)*/
		temp = REL_2;
	else
		temp = (uint8) ((uint16) KW_DLRUBSOLL * CORR_UB / ubrsq);
#else
	if( ubsq <= (KW_DLRUBSOLL >> 1) )
		temp = REL_2;		/* limitation to 2 */
	else
		temp = (uint8) ((uint16) KW_DLRUBSOLL * CORR_UB / ubsq);
#endif
	dlrbatkp_w = tp1_U16( (uint16)KW_ZKUBDLR * CORR_UB, temp, dlrbatkp_w);
	if( GET_B_st && GET_B_nmot )
		dlrkomp = (uint8)(((uint32)KW_DLRKREISST * (uint32)dlrbatkp_w) >> 15);
	else
		dlrkomp = (uint8)(((uint32)KW_DLRKREIS * (uint32)dlrbatkp_w) >> 15);
#define STOP_SECTION_Task_r100ms
#include "pragma.h"
/*	process: adve_1s												   */
/*	purpose: 														   */
#define START_SECTION_Task_r1000ms
#include "pragma.h"
void adve_1s(void)
	/* adve_1s:																*/
	/* On request of KW_CWDKNOLU the bit B_appnolu will be triggert. Only 	*/
	/* after the transition KW_CWDKNOLU 1 --> 0 --> 1 B_appnolu can be		*/
	/* retriggert.	 														*/
	/* B_appnolu activates in SREAKT 'limp home' function; but the 			*/
	/* setvalue of throttle blade can be set with position control.			*/
	/* DON'T USE adve_1s() in run after !!!!!! */
	if( ! GET_B_kl15 )	/* switch off adve_1s in run after */
		return;
#if (SY_UBR > 0)
	SET_B_nldve;	/* refresh and prepare for usage in run-after in other processes */
#endif
	SET_B_nldve1;
	/* 		function: application of limphome position		*/
	if( (KW_CWDKNOLU > 0) && (nmot > 0) )
		if( ! GET_B_apnoluv )
			SET_B_appnolu;
			SET_B_apnoluv;
	else
		CLR_B_appnolu;
		CLR_B_apnoluv;
#define STOP_SECTION_Task_r1000ms
#include "pragma.h"
process: adve_1msSwOff
#define START_SECTION_Task_r1msSwOff
#include "pragma.h"
void adve_1msSwOff(void)
	adve_1ms();
#define STOP_SECTION_Task_r1msSwOff
#include "pragma.h"
process: adve_10msSwOff
#define START_SECTION_Task_r10msSwOff
#include "pragma.h"
void adve_10msSwOff(void)
	adve_10ms();
#define STOP_SECTION_Task_r10msSwOff
#include "pragma.h"
process: adve_20msSwOff
#define START_SECTION_Task_r20msSwOff
#include "pragma.h"
void adve_20msSwOff(void)
	adve_20ms();
#define STOP_SECTION_Task_r20msSwOff
#include "pragma.h"
process: adve_50msSwOff
#define START_SECTION_Task_r50msSwOff
#include "pragma.h"
void adve_50msSwOff(void)
	adve_50ms();
#define STOP_SECTION_Task_r50msSwOff
#include "pragma.h"
process: adve_100msSwOff
Disable power stage for DVE: P_DVE = TRUE and value for DVE PWM-Channel
dlrspid_w = 0;
Refresh of PWM-Channel every 100 ms.
#define START_SECTION_Task_r100msSwOff
#include "pragma.h"
void adve_100msSwOff(void)
#if (SY_UBR > 0)
	if( twdknlc > KW_TWDKNL )
#endif
		SET_B_dcdisfr;		/* disable power stage during after run */
		dlrspid_w = 0;			/* PWM = 0 % */
		CLR_B_dlrspid;
#if (SY_UBR > 0)
		CLR_B_nldve;
#endif
		CLR_B_nldve1;
	/* PWMNegative
		Vorbereitung PWM-Ausgabe
		Quantisierung
		PWM-Kanal:		q= 50 ns	bei fcpu=20 MHz
		Periodendauer:	t= 0.5 ms	(f=2 kHz)
						PP2I = 9999
		dlrspid_w:		0 ... 65535
						0 ... 100 %		*/
	/* Output of PWM-signal is moved to HT2KTDVE */
#if (SY_UBR > 0)
	else
		if( GET_B_nmin )
			if( twdknlc < MAXBYTE )
				twdknlc++;
#endif
	adve_100ms();
}	/* end adve_100msSwOff */
#define STOP_SECTION_Task_r100msSwOff
#include "pragma.h"
/*	process: adve_fcmclr											   */
/*	purpose: 														   */
#define START_SECTION_Task_rfcmclr
#include "pragma.h"
void adve_fcmclr(void)
#if (SY_BLOOP > 0)
	if (getClf(DFP_DVEL) )
	  	CLR_B_wdksive;
	  	CLR_B_wdksivev;
		dklagerc = 0;
	if (getClf(DFP_DVEE) )
		CLR_B_dveese;
		dveesc = 0;
	if (getClf(DFP_DVER) )
		CLR_B_dlrpide;
		CLR_B_dlrbe;
	  	CLR_B_dlrbev;
	  	dlrpidc_w = 0;
	  	dlrpidrc_w = 0;
#endif
}	/* end fcmclr */
#define STOP_SECTION_Task_rfcmclr
#include "pragma.h"
960
Post by 960 »
These are the variable constants that can be changed in flash for ADVE:
Address;Name;Id;Size
"$14484";"Schwelle Aktivierung D-Anteil (Geschwindigkeit) im unverstärkten Bereich";"DANTGESWNV";"1x1"
"$14486";"Schwelle Aktivierung D-Anteil (Geschwindigkeit) im verstärkten Bereich";"DANTGESWV";"1x1"
"$14488";"Schwelle Aktivierung D-Anteil (Abweichung) im unverstärkten Bereich";"DANTSCHWNV";"1x1"
"$1448A";"Schwelle Aktivierung D-Anteil (Abweichung) im verstärkten Bereich";"DANTSCHWV";"1x1"
"$10B34";"zulässige Fehlerzeit für DK-Soll-/Istvergleich";"DKLAGERT";"1x1"
"$1448C";"DLR, obere Grenze zur Parameterumschaltung";"DLRDWDKSS1";"1x1"
"$1448E";"DLR, untere Grenze zur Parameterumschaltung";"DLRDWDKSS2";"1x1"
"$1B79E";"min. notwendiger I-Anteil im Haftreibunsfall";"DLRHAFTMN";"1x1"
"$1B7A0";"max. Sollwertgradient zur Aktivierung der Haftreibunsroutine";"DLRHAFTST";"1x1"
"$14490";"maximal zulässiger I-Anteil";"DLRIAMAXA";"1x1"
"$10B35";"DLR, I-Klein Parameter";"DLRIKLPAR";"1x1"
"$14492";"I-Anteil bei Inititialisierung der NLP-Funktion";"DLRININI";"1x1"
"$10B36";"DLR, D-Parameter über NLP";"DLRKDONLP0";"1x1"
"$10B37";"DLR, D-Parameter unter NLP (schwach)";"DLRKDUNLP0";"1x1"
"$10B38";"DLR, D-Parameter unter NLP (mittel)";"DLRKDUNLP1";"1x1"
"$10B39";"DLR, D-Parameter unter NLP (stark)";"DLRKDUNLP2";"1x1"
"$10B3A";"DLR, D-Parameter unter NLP (unverstärktes Poti)";"DLRKDUNLP3";"1x1"
"$10BDB";"DLR, P-Parameter über NLP";"DLRKPONLP0";"1x1"
"$10BDC";"DLR, P-Parameter unter NLP (schwach)";"DLRKPUNLP0";"1x1"
"$10BDD";"DLR, P-Parameter unter NLP (mittel)";"DLRKPUNLP1";"1x1"
"$10BDE";"DLR, P-Parameter unter NLP (stark)";"DLRKPUNLP2";"1x1"
"$10BDF";"DLR, P-Parameter unter NLP (unverstärktes Poti)";"DLRKPUNLP3";"1x1"
"$18882";"DLR, Faktor Kreisverstärkung";"DLRKREIS";"1x1"
"$18883";"DLR, Faktor Kreisverstärkung zur Zeit des Motorstarts";"DLRKREISST";"1x1"
"$14494";"Unschärfebereich für DK-Notluftposition";"DLRNLPD";"1x1"
"$14496";"Fehlerzeit für DLR-Stellbereich im Anschlag zur erweiterten Stellertauscherkenng";"DLRPID0T";"1x1"
"$14498";"zulässige Fehlerzeit 1 für DLR-Stellbereich am Anschlag";"DLRPID1T";"1x1"
"$1449A";"zulässige Fehlerzeit 2 für DLR-Stellbereich am Anschlag";"DLRPID2T";"1x1"
"$1449C";"max. zulässiges PWM-Tastverhältnis für DLR";"DLRPIDMAX";"1x1"
"$1449E";"min. zulässiges PWM-Tastverhältnis für DLR";"DLRPIDMIN";"1x1"
"$18884";"DLR, Batterie Normalspannung";"DLRUBSOLL";"1x1"
"$144A0";"Unsicherheitsband bei Sprung aus UMA-Bereich";"DLRUMABAND";"1x1"
"$144A2";"Vorladewert I-Anteil bei Sprung aus UMA-Bereich";"DLRUMAIINI";"1x1"
"$10BE0";"Zeit für Heilungsversuch der DV-E-Endstufe";"DVEEST";"1x1"
"$144B0";"max. Soll-/Ist-DK-Winkel-Abweichung als f(dwdks)";"DWDKSBAMX";"5x1"
"$144BA";"Schwelle zur Aktivierung des I-Kleinanteils";"DWDKSIKLS";"1x1"
"$18885";"Identifizierung des DLR-Parametersatzes zu DV-E-Typ";"KDLRIDDVE";"1x1"
"$10BE1";"Zeitdelta für Fehlerzählerlöschung bei DK-Soll-/Istvergleich";"TDKLAGDE";"1x1"
"$18886";"Verweildauer für Aktivierung der Haftreibungsroutine";"TDLRHAFTMX";"1x1"
"$144BC";"Zeitdelta zur Fehlerzeitdecrementierung bei DLR-Stellbereichsüberwachung";"TDLRPIDC";"1x1"
"$144BE";"Wartezeit bis DV-E Powersave aktiv wird";"TPWRSV";"1x1"
"$18887";"Zeit nach nmot = 0 und Kl.15 AUS bis Nachlauf gestartet wird";"TWDKNL";"1x1"
"$144C0";"zulässige Potispannungs-Toleranz des NLP";"UDKNLPTOL";"1x1"
"$144C2";"Schwelle zur DK-Bewegungserkennung (I-Klein)";"WDKBEWS";"1x1"
"$144C4";"zulässige DK-Winkel-Toleranz des NLP";"WDKNLPTOL";"1x1"
"$10BE2";"Haftreibungsanteil der DK für I-Klein";"WDKREIB";"1x1"
"$144C6";"DK-Sollwert bei Applikationshilfe DK-Notluftfahren";"WDKSAPNOL";"1x1"
"$144C8";"Schwelle zur Stationaritätserkennung (verstärkter Bereich)";"WDKSTFEIN";"1x1"
"$144CA";"Schwelle zur Stationaritätserkennung (unverstärkter Bereich)";"WDKSTGROB";"1x1"
"$18888";"DLR, Zeitkonstante für Filterung von Ubatt";"ZKUBDLR";"1x1"
"$10BE3";"Zeitkonstante für Prädiktion DK-Winkel aus Sollwert";"ZKWDKSPT1";"1x1"
Simon@FutureProof
Is there a TLDR version of that? :lol:
960
Post by 960 »
OrchardPerformance wrote:
Sun Apr 28, 2019 4:20 pm
TLDR?
Simon@FutureProof
Too long - didn't read :lol:
960
Post by 960 »
The biggest issue seems to be within the first percents of Throttle opening.
It looks ok when testing, starting the engine changes that.
It's to slow and/or "nervous" around idle if that make any sense.
Maybe that could be solved by a target table like Link, or another table to make it nonlinear.
I "solved" the outcome from some of the functions yesterday, and got some of the scenario values:
dlrp = KW_DLRKPONLP0(30%PWM%TPS);
dlrd = KW_DLRKDONLP0(548%PWM%TPS);
dlri = KWB_DLRKIONLP0(32x1 table); 1,875% up to 4% TPS then 0,6250
dlrp = KW_DLRKPONLP1(60%PWM%TPS);
dlrd = KW_DLRKDONLP1(500%PWM%TPS);
dlri = KWB_DLRKIONLP1(32x1 table); 1,875% up to 4% TPS then 0,6250
dlrp = KW_DLRKPONLP2(60%PWM%TPS);
dlrd = KW_DLRKDONLP2(500%PWM%TPS);
dlri = KWB_DLRKIONLP2(32x1 table); 1,875% up to 4% TPS then 0,6250
I MAX 74,951
Does a higher I below 4% make sense?
960 wrote:
Tue Apr 30, 2019 10:02 am
We _REALLY_ need your logs. We _REALLY_ need your magic number test result.
See also slack channel https://rusefi.slack.com/messages/CF6F16278/details/
Simon@FutureProof
I suspect that is due to an increase in friction around the closed region.
With a greater DeltaP across the throttle there will be a larger side load on the spindle, most are still plain bearings so the loading ups the friction.
Have you tried increasing the compensation for the friction inline with the MAP value?
TL;DR: Very not linear around zero
-5%
0%
15%
gives more or less same default position
And the jump between 15% to 19% would open throttle completely!
And if we go -20% to fully close it - sometimes returning to 0% duty would not open throttle, there is so much friction (?) that the spring would not return throttle back to default position unless we give it a 10% duty cycle kick.
Log attached - here is a screenshot.
2019-04-30_21_48_11 etb.msl
(932.29 KiB) Downloaded 722 times
some clarification needed. what sort of etb is that?
do the spring-loaded electronic throttles need the same H-bridge? or a single PWM is sufficient?
what do the negative values mean in terms of electrical signal? since at 0% it doesn't produce any noise, it looks as if at 0% it turns off the signal.
it seemed to me that the spring-loaded ETB I once had didn't imply reverse polarity, since there was no room to close it any more - the spring did it all the way to the min.
960
Post by 960 »
russian wrote:
Wed May 01, 2019 2:10 am
-5%
0%
15%
This shows exactly the kind of issues I had.
Thats why I wanted to automatic set the bias curve.
Ideally with points for every TPS% from 0 - 30%
I also had a lot of strange behaveor around 0, but not every time.
Not much oscillation, but also slow response? Is that what we would call this log?
Magic Result = 263
Larger P, kind of not very scientific I & D. WAY better results! Magic Result = 58
960
Post by 960 »
How do you get that few decimals at the pid settings?
And so high numbers at the pid, have you changed some factors?
I have so many that I cannot see the first numbers in the fields :-(
And why do you suddenly have that high numbers in the bias curve again?
960 wrote:
Thu May 02, 2019 2:11 pm
I use the keyboard to remove zeros. This would not stay if you close the dialog, I know it's annoying - but it works while you are on the dialog.
I can't find it. Do you use CS pin (to control current consumption)? How many control pins are needed from the discovery side? What are those pins?
puff wrote:
Thu May 02, 2019 2:28 pm
You cannot find WHAT? Menus are at the bottom of left "general" section in TS.
CS pin of WHAT?
At the moment three stm32 pins are used to control VNH2SP30 - two direction and duty cycle. Negative duty cycle actually means "closing" direction while positive means "opening".
thx!
so, enA & enB pins pulled up in hardware?
cs = current sense pin on that board - could be handy to detect hard limits or blocked throttle.
960
Post by 960 »
Are you getting same or different results with the 7209?
