As of April 2019, rusEfi is quite far from GDI gasoline direct injection. No reason not to make some baby steps
Went to a yard today tring to find a connector for BMW 760 13647512081 injector, did not find anything. My naive idea was to grab other GDI injectors but in reality those all had different connectors.
Did not really find the connector But grabbed a few random relevant parts.
Fuel high pressure sensor 0261545035
AUDI A4 B8
High? Low? FUEL PRESSURE SENSOR 9F972EA
2016 Ford Focus
06F906036A injector
2005-2009 Audi A4
R=2.1 Ohm
CM5E-BB injector
Ford Focus
R=2.8 Ohm
Special guest
35350-2B110 injector
12-17 KIA RIO Kia Soul HYUNDAI ACCENT 1.6
R=2.4 Ohm
From just grabbing injectors I know now that VAG is less enjoyable to work on, Ford seemed easier with less stuff on the engine and fewer kinds of special tools required. Focus seems to be using a lot of Bosch licensed stuff - https://rusefi.com/forum/viewtopic.php?f=4&t=582 154 pin ECU connector and Bosch-inspired ETB with a custom connector.
QUESTIONS:
1) is calibration available for Fuel high pressure sensor 0261545035 or any other VAG Fuel high pressure sensor?
2) what is 9F972EA - is it high pressure, low pressure or both? eBay is a bit confused about this part number. is calibration available for it?
GDI overall status thread
- gdi_parts.jpg (584.67 KiB) Viewed 8962 times
Re: GDI overall status thread
@ says 0261545053 interchangable with L807-18-211 and 0261545006 and
0261545074 see https://www.amazon.com/CBK-Pressure-Sensor-L807-18-211-0261545006/dp/B07D9HPGHN
we now have 0261545006.pdf saved at https://github.com/rusefi/rusefi_documentation/tree/master/oem_docs/Bosch
Thank you @! One mystery solved
- Slack: Orchardperformance
Oh snap, if I had known you were looking for some of those plugs I could have pointed you in the correct direction, that's the same as 90% of 80s/90s bmw injectors. It's a pretty standard Bosch connector.
http://bmwfans.info/parts-catalog/12521732460/
https://www.schmiedmann.com/en/product/1979556-new?product=12-52-1-732-460
Do we have pinouts wiring diagram from BMW 760 GDI module ???
GDI status update
1) order was placed for https://rusefi.com/forum/viewtopic.php?f=4&t=1337 board
2) (so far only) a couple of lines of code was added under https://github.com/rusefi/rusefi/issues/784
More fun at https://rusefi.slack.com/messages/CFP3QAJCW/details/
Circuits are mostly finished, and component placing started at my version of testboard
Worst case scenario we can use OEM GDI driver box for our first GDI test mule - see https://rusefi.com/forum/viewtopic.php?f=4&t=1564
2014 Hyundai Genesis 3.8L GDI Fuel Injector Control Module | 39172-3C020
Wiring diagram for 2014 Hyundai Genesis 3.8L GDI Fuel Injector Control Module - that module is on page 5
- 2014 Hyundai 3.8 ECU diagram.pdf
- (1.21 MiB) Downloaded 188 times
"Dave B. 5:03 PM
