Hello World
As Many of you have probably seen my Partner John and I had a yellow Festiva running a rusEFI with a 1.8 Escort drive line in it. We ran it for a few years in Lemons and Champcar ( aka Chumpcar). Over this past winter we transplanted the motor and rusEFI from the lunchbox body Festiva into a 94 Escort GT. Did a ground up build on the car including all wiring. Well finally the day has come the rusEFI landed in the overall winners circle in the Bracket GP series. The motor was built be DDE Race Engines, and we did all our tuning at Radical Racing in Atco NJ. Thurday night before we left for the race we spent the night on the dyno and found 15 hp between 3500 and 5200 just tuning in the acceleration enrichment correctly or at least closer I think ther's still a little more to be fine tuned out of the motor.
Congratulations rusEFI and Andrey rusEFI is now a winning ECU if it was not already
Drew..
[Success Story] rusEFI Wins 2019 Bracket GP at Thompson Motor Speedway
Kyocmondeo
Re: rusEFI Wins 2019 Bracket GP at Thompson Motor Speedway
Unbelievable!
Thank you for trusting in rusEfi
matt
- donator
Congratulations!!
Ok, what engine is? I know there is written Ford, but I'm sure it is related with Mazda FE.
matt
- donator
One thing, what trigger they're using? Standard or custom? Actually my kia sportage engine look like this. It is FE engine, but with Kia stamp on rocker cover.
i believe miata na sensor is used
Kyocmondeo
The ignition system is from Fab 9 Tuning. It's comes as a direct plug-n-Play for miata's. We got the kit with no plugs and wired it into the rusEFI. It's straight coil packs with the trigger is mounted on the inner fenderwall.
https://fab9tuning.com/fab9tuning-plug-play-coil-on-plug-conversion-kit/
