work in progress rusEfi own wide band controller board add-on using CJ125
..Voltages are from "my" gui, it's UR and UA voltages ...
no VCC or SPI voltages ...
No doubtJRD McLAREN wrote: ↑Thu Sep 19, 2019 12:46 pm..Voltages are from "my" gui, it's UR and UA voltages ...
but my attention is SPI voltages. if we use 3.3V SPI, we walk on the borders that can be changed by ambient temperature.
Where did you find the curve of temperature vs Nernst resistance or UR?
I found an empirical formula for temperature(not bad for starting
T = Tcal * vUrCal / vUr
Tcal = 750 for LSU 4.2
Tcal = 780 for LSU 4.9
The shape of the temperature curve doesn't actually matter. You're just trying to keep the resistance (and as a result temperature) at some constant point, so you don't really care the shape of the curve as you shouldn't ever be deviating very far. Since the function of resistance (and as a result vUr) is continuous, a small change int the temperature results in a small change in the voltage, so at some "zero width" point, it's effectively linear.
No doubt mck1117.
The temperature displaying results better user interface.
Where is the firmware code for the wideband control stashed?russian wrote: ↑Sun Jul 03, 2016 1:43 pmOur little board for Bosch CJ125
https://github.com/rusefi/rusefi/tree/master/hardware/CJ125_board
ibom available at https://rusefi.com/docs/ibom/
https://github.com/rusefi/rusefi/tree/master/firmware/hw_layer/sensorsinfinityedge wrote: ↑Fri Dec 27, 2019 5:08 pmWhere is the firmware code for the wideband control stashed?
Thank you!russian wrote: ↑Fri Dec 27, 2019 10:40 pmhttps://github.com/rusefi/rusefi/tree/master/firmware/hw_layer/sensorsinfinityedge wrote: ↑Fri Dec 27, 2019 5:08 pmWhere is the firmware code for the wideband control stashed?
Would anyone be available to help by adding lcsc.com part numbers into schematic component fields? This way we would be able to pre-assemble these little boards.
I have no problem with this...
but ,, in my opinion...
board need to be redesigned...
heater led..
bigger pads for sensor wires
2 layer board
heater led..
2 layer board
Might also want to switch out the VNS14NV04 power driver for a non-obsolete part as well.JRD McLAREN wrote: ↑Wed Jan 08, 2020 7:53 amI have no problem with this...
heater led..
2 layer board
- Paul Walker
In regards to the topic of board redesign, why was the SOIC24 package of the CJ125 chip chosen instead of the LQFP32? Both the package sizes seem readily available on FutureElectronics and the LQFP32 is half the size of the SOIC24.
I believe at the time, of the original circuit design, the SOIC24 was available, but the other was not. That might have changed as time progressed. I do not recall any specific design concerns, both should be able to work just fine.
- Paul Walker
I'm facing some issues with the CJ125 chip. All the SPI communications yield the right results, the Lambda readings are correct (only tested in open air) but the temperature output from the chip seems stuck at ~0.86 V regardless of how hot or cold the sensor is. Tried 4 different chips but all of them behave the same, so I was wondering if it was something wrong with the LQFP32 package because everyone seems to be using the SOIC24 one.
@960 has a board he is not sharing with us where he has LQFP32 working according to him.
I'm using LQFP32 pakage without any problem!Paul Walker wrote: ↑Tue Jan 14, 2020 5:33 pmI'm facing some issues with the CJ125 chip. All the SPI communications yield the right results, the Lambda readings are correct (only tested in open air) but the temperature output from the chip seems stuck at ~0.86 V regardless of how hot or cold the sensor is. Tried 4 different chips but all of them behave the same, so I was wondering if it was something wrong with the LQFP32 package because everyone seems to be using the SOIC24 one.
Anyone have a reliable vendor with cj125 in stock in either so24 or tqfp32?
You can find anything in china (www.1688.com).
But in your local store search these part numbers:
Bosch 30481
Bosch 30615
Bosch 30481
Bosch 30615
- Paul Walker
Future Electronics & Rutronik would be your go to in the North American Markettexasgdp754 wrote: ↑Thu Jan 16, 2020 12:38 amAnyone have a reliable vendor with cj125 in stock in either so24 or tqfp32?
- Paul Walker
The part number is 30615.
In our country, we have many local chip stores, because repairing of commercial ECUs is very popular.
I ordered 30615 from one of this stores. But the gateway of these chips is chinese distributors(www.1688.com).
My schematic/Code is same as RUSEFI with some modifications.
- lambda.png (311.42 KiB) Viewed 10209 times
Future electronics shows 11 in lqfp32. Ill order there. Only place I can find elsewhere is from china auction sites. I try to avoid them when It comes to ic's.
- Paul Walker
The part number for future would be 0272240103texasgdp754 wrote: ↑Thu Jan 16, 2020 10:36 pmFuture electronics shows 11 in lqfp32. Ill order there. Only place I can find elsewhere is from china auction sites. I try to avoid them when It comes to ic's.
- Paul Walker
Thank you!!!Ahmad wrote: ↑Thu Jan 16, 2020 10:26 pmThe part number is 30615.
Bosch 30615 = Bosch 40103 = CJ125(LQFP-32)
Bench testing with nucleo stm32f767zi once cj125 boards and components arrive. Will cj125 work on any other spi port like spi4 rather than spi2?
spi4 support not implemented in rusEfi as of today. There are reports of issues with F7 running cj125 - maybe we have issues with SPI parameters maybe user error, who knowstexasgdp754 wrote: ↑Mon Jan 20, 2020 2:27 amBench testing with nucleo stm32f767zi once cj125 boards and components arrive. Will cj125 work on any other spi port like spi4 rather than spi2?
Assuming spi 1 2 and 3 are all functioning with f4 mcu?
A few people have seen cj125 working with rusEfi code but not me so far.
At least my 0.3 hardware talks to me with just 6 wires: GND, 5v, 4xSPI
New commands are cj125_info, cj125_restart, enable cj125verbose - diag register response is now parsed in human-readable form.
Also we have a LQFP-32 version of the module now at https://github.com/rusefi/hw_modular/tree/master/cj125_Module - not tested yet.
- cj125_restart.png (119.83 KiB) Viewed 6302 times
- rusefi_cj125_LQFP-32.jpg (715.22 KiB) Viewed 6302 times
