Thank you so much for this, its amazing to have something to use to get a good order to do the project in.
however, be warned folks there are at least a couple typos, i assume going by the BOM page for those would be best.
https://rusefi.com/docs/ibom/frankenso_latest.html
for example
LD604 and 3 others that are badly marked = LED, beware R604 is backwards vs the other 3 LEDs actually LD603 LD607 LD608
should say
LD604 is backwards vs the other 3 LEDs actually LD603 LD607 LD608
and
C602 C604 = 1.0uF (104)
should say
C602 C604 =
 0.1uF (104)
and
R172 R172 - Do not populate
should say
R172
R173 - Do not populate
and
C612 C613 = 3300pF (332)
should say
C162 C163 = 3300pF (332)
U531 = FT232RL
http://www.ftdichip.com/Support/Documen ... FT232R.pdf
should say
U351 = FT232RL
R401 R410 = 22 ohm (220)
should say
R407 R410 = 22 ohm (220)
R412 R421 R424 = 1k ohms (102)
should say
R412
R420 R424 = 1k ohms (102)
R414 R422 R432 = 22 ohms (220)
should say
R411 R422
R423 = 22 ohms (220)
R427 = 1k ohms (102)
should say
R472 =
10k ohms (all mine are 4 code ones so im not going to bother)
U531 = FT232RL
should say
U351 = FT232RL
R230 = 3900 ohms (392)
i think this is supposed to be
R320 = 39k ohms
D436 = Diode
to be clear there is a D436 but it was listed twice and D434 is otherwise missing
D434 = Diode (the first listed one i think was the typo)
C166 = 24pf. not listed but is on bom sheet
