work in progress MREAdapter55 PnP 55 pin ECU
A lot of older vehicles (thus cheaper) in Russia use same or similar 55 pin ECU connector.
Those vehicle range from 8 valve https://en.wikipedia.org/wiki/Lada_Riva grandchildren of https://en.wikipedia.org/wiki/Fiat_124 to https://en.wikipedia.org/wiki/GAZelle light commercial vehicles.
We are still trying to get developers and https://github.com/rusefi/rusefi/blob/master/misc/Strategy_2019.md still applies. I believe we need a cheap plug&play solution for this 4 cylinder 55 pin market. At this point 6 and 8 cylinders if those ever used this 55 pin connector are out of scope.
https://github.com/rusefi/hw_55_te
https://github.com/rusefi/hw_55_te/raw/master/microrusefi55adapter.pdf
Re: PnP 55 pin ECU
There are at least three vendors using same or similar 55 pin connector:
* Bosch seems to be the oldest offering.
* Yanvar/January
* Mikas
At least two modifications of the connector were used, maybe three. Yanvar and Mikas seem to be using same or similar slim case where microRusEfi maaaaaaybe will fit but extremely tight fit. I have a Mikas in my collection, looks like they use https://www.te.com/usa-en/product-963063-1.html which is available new from US distributors at about $15. We have a board for this connector! https://rusefi.com/forum/viewtopic.php?f=4&t=616
0261206683 MIVI3T64 Bosch uses a longer version of the connector which is available from China. TE support does not recognize this part, maybe too old maybe not TE maybe custom Bosch edition. PCB footprint is a bit different, we would need to modify the breakout board. 0261206683 MIVI3S64 (S instead of T) uses metal connector housing?! My next step would be to get 0261206683 MIVI3T64 in my hands looks like it's a simpler option to begin with.
* Yanvar/January
* Mikas
Re: PnP 55 pin ECU
TBD
Re: PnP 55 pin ECU
tbd
Re: PnP 55 pin ECU
@andreika has reminded me that rusEfi firmware was already used with this Chinese connector! So we would not need to measure the footprint again
https://rusefi.com/forum/viewtopic.php?p=26893
Re: PnP 55 pin ECU
Simon has created first draft of the pinout compatibility chart. I did not realize that BMW M70 v12 and https://en.wikipedia.org/wiki/GAZ-3102 had this pinout in common?!
- 55pin ECU pinouts - 55 pin - rusEfi 2020-03-02.pdf
- (53.15 KiB) Downloaded 428 times
- Slack: Orchardperformance
Re: PnP 55 pin ECU
Thanks Andrey.
I will try to take a look at the Vauxhall and Volvo stuff too, wondering how similar they are now.
Do we think that we can get away with just one of those plugs?
Do we think they may be compatible or interchange?
Re: PnP 55 pin ECU
First phase is to investigate how our long connector would would work with original motronic cases and if there are variations of that case.OrchardPerformance wrote: ↑Tue Mar 03, 2020 10:17 amDo we think that we can get away with just one of those plugs? Do we think they may be compatible or interchange?
Many Russian vehicles use that other case with another connector, the small case and small connector. This case could be challenging for us but ideally we need two two boards to lure people with a promise of having a board for their existing case.
Re: PnP 55 pin ECU
One thought, does it need to fit the existing case at all? Just has to fit in the same space.
I have a motronic connector out of the car at the moment. I will take a look how hard it is to replicate an end plate.
Re: PnP 55 pin ECU
The whole idea of rusEfi PnP is design, fabrication and eventual user cost reduction. Reusing OEM cost is simplifying our life tremendously, we should do our best to fit OEM cases in my opinion - it would pay of by fabrication simplicity.OrchardPerformance wrote: ↑Tue Mar 03, 2020 3:30 pmOne thought, does it need to fit the existing case at all?
Re: PnP 55 pin ECU
Dron has taken a VAZ Bosch apart and well... that's a bit surprising.
- vaz_bosch_1583268242561.JPEG (25.66 KiB) Viewed 22099 times
- vaz_bosch_1583268088870.JPEG (95.85 KiB) Viewed 22099 times
- vaz_bosch_1583268088832.JPEG (104.83 KiB) Viewed 22099 times
- vaz_bosch_1583268088795.JPEG (209.2 KiB) Viewed 22099 times
- vaz_bosch_1583268088673.JPEG (160.16 KiB) Viewed 22099 times
- vaz_bosch_1583268088640.JPEG (118.3 KiB) Viewed 22099 times
- vaz_bosch_1583262269191.JPEG (54 KiB) Viewed 22099 times
- Dron_Gus
- Github Username: dron0gus
Re: PnP 55 pin ECU
Январь-5.1.1 / Yanvar-5.1.1
- 20200304_115926.jpg (1.59 MiB) Viewed 22063 times
- 20200304_115012.jpg (2.85 MiB) Viewed 22063 times
- 20200304_114822.jpg (2.91 MiB) Viewed 22063 times
Re: PnP 55 pin ECU
https://github.com/rusefi/hw_55_te/ is the repo for this ^^^ case.
Need to call Cricut tech support - on these chipboard prototypes my X precision is amazing my Y precision not so great
- IMG-20200304-WA0003.jpg (223.07 KiB) Viewed 22046 times
Re: PnP 55 pin ECU
reminds me of the internals of modern SSDs
they are somewhat similar -– tiny boards with huge connectors and oversized enclosures...
Re: PnP 55 pin ECU
Re: PnP 55 pin ECU
Is Gary on this thread? Would he see comments if I were to make some?
Re: PnP 55 pin ECU
I would assume zero speeduino people on the rusEfi forum thread if you are referring to rusEfi forum thread.
No idea about facebook viode thread.
No idea about many things really.
Re: PnP 55 pin ECU
Re: MREAdapter55 PnP 55 pin ECU
Cardboard test of cap array clearance holes was a success.
- cap_holes.jpg (562.14 KiB) Viewed 18755 times
We have https://github.com/rusefi/hw_55_te release candidate but we do not have test mules lined up Not sure what's the plan for this board now.
I would be interested in trying this on a turbo setup the only issue is it is an inline 6 m20b25 same connector
if it looks the same it should be possible to make it work
please get yourself a microRusEFI this would motive us to finish this board and make it work for your 6 cylinder application.
