I cannot explain any of this. I love my bits and bytes, but this is not bits and not bytes. It's a very pleasant surprise that it works
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
Question about Open loop boost control.
As discussed a few times now, this is what happens when you update firmware with an incompatible change to the config layout. There was nothing there before, so it just reads out whatever garbage used to be there.
I am not following you?
I am afraid that this is not how things work. There is a chance that this is bad advice.960 wrote: ↑Tue Mar 31, 2020 11:54 pmDefault values are set in engine_configuration, and should be there if it's updated.
In that case, the .ini must have been updated without updating firmware.
The only thing I can think of are if you select send tunerstudio-configuration at first connect after update,
this will happen.
not sure what you mean here. all low side drivers are the same aren't they?
