Hello from France : BMW M10 EFI conversion
marc426
Post by marc426 »
Hi everyone,
Just received my mini RusEFI a couple of days ago. Nice piece of kit!
I'm in the process of converting a BMW M10B18 engine. It was initially a K-Jetronic engine so it already has some of the sensors needed.
I'm also in the possession of a M10B18 L-Jetronic air intake with injectors and fuel rail / pressure regulator so that should make things easier!
Marc
Re: Hello from France : BMW M10 EFI conversion
Welcome to the forum!
Are you planning MAP or MAF sensor?
Is this engine wrapped in some vehicle? Any pictures? :)
Lyonz
kit assembler
Post by Lyonz »
Bienvenu Marc...
Super projet. Envoie des photos et des détails. :D
Simon@FutureProof
Slack: Orchardperformance
Post by Simon@FutureProof »
Fri May 08, 2020 9:22 pm
mmmm, K-jet, I am going to guess early E30 318.
marc426
Post by marc426 »
Hi all,
Thanks for the welcome.
Wrong guess about the E30, it's actually an E21 ;)
Planning to run MAP with a MAP+IAT Bosch sensor that will be adapted on the manifold. As you probably know, the K-Jet was a MAF set-up (even though it's not electronic injection per se) so have to adapt a couple of sensors.
I'll post pictures when the whole thing gets going but I'm still waiting on a lot of parts!
