TS display
TS display
After dubious searching, I feel like I may be having a brain fart. is there someplace in the software to change the display units to Fahrenheit, PSI, etc instead of metric? Maybe a change to the .ini file?
Josh
94 Ford Taurus SHO
Frankenso in progress
94 Ford Taurus SHO
Re: TS display
Currently not a way to do it. We'd have to do it seni-manually by adding converted versions of each gauge/table/config and selectors in TS for each one.
Re: TS display
rusEFI Fahrenheit support was so broken that we have rightfully killed it. Also I believe there was drama with F being default or something.
I am a C believer. Vodka is measured in liters!
Re: TS display
Just be glad that the MAP doesn't indicate in Pascals!
