Hello
In which direction should I measure trigger angle offset, alpha or beta?
Kind regards
Andreas
tunerstudio trigger angle
Re: tunerstudio trigger angle
In this case, I think you want to use negative alpha. My car has the missing tooth roughly 90 degrees BTDC #1, and I enter 86 to get the timing light to match up.Andreas_28023 wrote: ↑Fri Oct 09, 2020 5:54 amHello
Kind regards
Andreas
Skickat från min SM-N960F via Tapatalk
Yours looks like around -60 or so.
Should we change parameter label from "trigger angle offset" to "trigger angle advance"?
https://github.com/rusefi/rusefi/commit/ee2a01396098eaed3e674c3e630af6d32eeb6d96 and https://github.com/rusefi/rusefi/commit/0a49ea933ec238d0b84e7dee5675e1dca48461a4
Thanks
//Andreas
//Andreas
