I'm putting a 2013 S1000RR engine in a racecar. The factory ECM is a total bear to get working in non OEM applications and I'd rather sell it working and put something aftermarket on it than deal with that science fair.
It is a fairly "normal" 4 cylinder motorcycle engine with a few unusual characteristics:
- Redline is 16,000 rpm
- It has staged injection - 4 injectors at the port, 4 up in the trumpets
- Active exhaust and intake - fairly simple butterflies that go on/off at different rpm setpoints
The factory ECM runs full sequential on the injection (at least at low RPM). I don't think sequential is that important here. I note that the RUS docs say staged injection is supported. How does this work? Can I set the two banks up with independent VE tables?
Excited to try out RUSefi. I've been a disgruntled megasquirt user for many years
James
