RascalGC8 93 impreza EJ18
RascalGC8
ej18 automatic
Re: RascalGC8 93 impreza
You've got style! How come I have not seen this car?!
Joel has stopped by and progress was made!
We found the ECU! It was located in the passenger footwell Miata NA6 style
ECU pinout wiring colors match the car so we at least have ECU pinout! But not a proper wiring diagram
We get power from ignition switch from pin E29#10. No +12v detected on "Control unit power supply" pin E29#13 so there might be some main relay somewhere.
Problem: internet says that 7 tooth looks like the left wheel at
in reality it looks more like
is that engine compression messing up the shape or is that a different wheel or is that some sort of rusEFI issue?
If it's VR, try swapping the wires. That looks like a lazy falling edge on a VR sensor...
Yes, VR on microRusEFI
- Dron_Gus
- Github Username: dron0gus
13021AA100
Re: RascalGC8 93 impreza EJ18
Wow, this car uses high-side main relay control? microRusEFI does not have an easy option so I've simply wires main relay to ignition switch. https://github.com/rusefi/hw_microRusEfi/issues/204
With only one VR channel on microRusEFI I had to add new "Subaru 7 without 6" trigger wheel shape. TODO https://github.com/rusefi/rusefi/issues/2073
Next step wiring in WBO and we will calibrate this unknown MAF against a known MAF.
Innovate shows either 7 or 22 - please fix that
You want a "GM 3bar" MAP sensor mounted somewhere under the hood.
Joel has just got himself a 2001 740. Do we know what's inside?
Should be an M60B40.
wiki says 2001 is M62TUB44
https://en.wikipedia.org/wiki/BMW_M62#M62B44
what do we know about M62TUB44?
TUB engines add intake VANOS (vvt). Two, one per intake cam. Fixed exhaust cams.
