[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 258: mysqli_fetch_assoc(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/mysqli.php on line 320: mysqli_free_result(): Couldn't fetch mysqli_result [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4433: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3315) [info] microRusEFI - Page 11 - rusefi.com
I bought 4 MRE from Dmitry Korostelev as well as 4 "Speeduino Blitzbox" for test use
"considering shielding the community from you" - SOUND VERY RUDE. I dont deserve this...
You have 4 MRE.
I am blunt and that could be border line rude, I have to accept that.
I would like to request that your next post contains a video of MRE opening ETB very quickly with a corresponding log file showing quick change of TPS.
In the current case I do not see how we would have space for it. There is not 1 square cm of the current MRE that does not have functional circuits on it.
My idea:
SD card can be placed on any "extended device" - flexible extender etc.
(is any 8pin header usable for it ..?? with SPI interface)
BT comunication - I have lowcost BT to TTL (HC-05) on my VEMS
We need 4pins, VCC RX TX GND for hardware ...
and software support - no baundrate change when we communicate ..
(thats all)
(I don't have MRE on my desk to test it ... at this moment)
My idea:
(thats all)
Those should both work. The SPI expansion header is all that's needed for an SD card to work - just MOSI/MISO/SCK/CS and power (3.3v). There are also exposed UART pins that should work with a normal "passthrough" bluetooth module.
Diodes on back side D6 and D20 are so close to bottom cover (black plastic case)
The 0402 Caps and Rezistors are soo close to other pins, (and too small to solder by hand, also )
Is able back traces for caps & rezs arrays to back side ..?? (on next PCB version .. ?? )
Attached are custom gerbers modified to use U-M-M5DD-W-4 USB vertical connector. USB connector orientation is different which is fine, open question is if USB is functional.
If you connect the ECU over USB before applying external power, it should appear as an SD card reader to your PC, so you can check functionality that way.
Apr 4 21:41:03 tosh ModemManager[942]: <warn> Could not grab port (tty/ttyACM0): 'Cannot add port 'tty/ttyACM0', unhandled serial type'
Apr 4 21:41:03 tosh ModemManager[942]: <warn> Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3': Failed to find primary AT port
Apr 4 21:41:30 tosh kernel: [100987.852573] usb 1-1.3: USB disconnect, device number 7
Apr 4 21:41:30 tosh ModemManager[942]: <info> (tty/ttyACM0): released by modem /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3
Apr 4 21:41:34 tosh kernel: [100991.723582] usb 1-1.3: new full-speed USB device number 8 using ehci-pci
Apr 4 21:41:34 tosh kernel: [100991.821051] usb 1-1.3: New USB device found, idVendor=0483, idProduct=5740
Apr 4 21:41:34 tosh kernel: [100991.821055] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 4 21:41:34 tosh kernel: [100991.821057] usb 1-1.3: Product: rusEFI Engine Management ECU
Apr 4 21:41:34 tosh kernel: [100991.821076] usb 1-1.3: Manufacturer: rusEFI LLC
Apr 4 21:41:34 tosh kernel: [100991.821078] usb 1-1.3: SerialNumber: 2E0029001447393432373039
Apr 4 21:41:34 tosh kernel: [100991.823887] usb-storage 1-1.3:1.0: USB Mass Storage device detected
Apr 4 21:41:34 tosh kernel: [100991.824266] scsi host11: usb-storage 1-1.3:1.0
Apr 4 21:41:34 tosh kernel: [100991.824748] cdc_acm 1-1.3:1.1: ttyACM0: USB ACM device
Apr 4 21:41:34 tosh mtp-probe: checking bus 1, device 8: "/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3"
Apr 4 21:41:34 tosh mtp-probe: bus: 1, device: 8 was not an MTP device
Apr 4 21:41:35 tosh kernel: [100992.828756] scsi 11:0:0:0: Direct-Access rusEFI SD Card v6.1 PQ: 0 ANSI: 4
Apr 4 21:41:35 tosh kernel: [100992.830049] sd 11:0:0:0: Attached scsi generic sg2 type 0
Apr 4 21:41:35 tosh kernel: [100992.834744] sd 11:0:0:0: [sdb] 3842048 512-byte logical blocks: (1.97 GB/1.83 GiB)
Apr 4 21:41:35 tosh kernel: [100992.835752] sd 11:0:0:0: [sdb] Write Protect is off
Apr 4 21:41:35 tosh kernel: [100992.835756] sd 11:0:0:0: [sdb] Mode Sense: 03 00 00 00
Apr 4 21:41:35 tosh kernel: [100992.836472] sd 11:0:0:0: [sdb] No Caching mode page found
Apr 4 21:41:35 tosh kernel: [100992.836476] sd 11:0:0:0: [sdb] Assuming drive cache: write through
Apr 4 21:41:35 tosh kernel: [100992.853660] sdb: sdb1
Apr 4 21:41:35 tosh kernel: [100992.858111] sd 11:0:0:0: [sdb] Attached SCSI removable disk
Apr 4 21:41:40 tosh acpid: client 1264[0:0] has disconnected
Apr 4 21:41:54 tosh ModemManager[942]: <info> Creating modem with plugin 'Generic' and '1' ports
Apr 4 21:41:54 tosh ModemManager[942]: <warn> Could not grab port (tty/ttyACM0): 'Cannot add port 'tty/ttyACM0', unhandled serial type'
Apr 4 21:41:54 tosh ModemManager[942]: <warn> Couldn't create modem for device at '/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.3': Failed to find primary AT port
Apr 4 21:42:10 tosh acpid: client connected from 1264[0:0]
Apr 4 21:42:10 tosh acpid: 1 client rule loaded
Apr 4 21:43:09 tosh kernel: [101086.761154] FAT-fs (sdb1): bogus number of reserved sectors
Apr 4 21:43:09 tosh kernel: [101086.761161] FAT-fs (sdb1): Can't find a valid FAT filesystem
Apr 4 21:44:27 tosh acpid: client 1264[0:0] has disconnected
