[Success Story] Daihatsu KF-VE Engine
Hello Everyone,
rusEFI has become such a nice community.
I do research kind of stuff on engines. Until my work was limited to engine dynamic modeling, model tuning and validation, I had data acquisition setup on an engine running with OEM ECU. I was able to acquire all the engine inputs and outputs. However, I had great limitation in extending my work beyond engine models. This was due to unavailability of engine test rig. My purpose with rusEFI is first to get it running, then (may be as i foresee) i shall be able to test different algorithms; such as control, observer, paramneter estimation, and fault diagnosis.
I am wokring on the following egine:
Make: Daihatsu
Vehicle: Mira (2014)
Engine Volume: 660cc, 3 Cylinder
I am using Frankenso rev. 0.4.
I have acquired Crankshaft trigger pattern in dev console from the egine(crankshaft_trigger_pattern_acquired_from_engine.png).
What i found through using eusEFI internal simulation option, trigger pattern is already there (that is, 36_2_2_2).
Here I have couple of questions and need some help:
1) Although both crank and camshafts are equipped with VR type sensors, however as per my understanding trigger pattern (36_2_2_2) in rusefi only includes crankshaft pattern, do i need to configure it as '4 stroke without cam sensor', or i can somehow incorporate cam sensor input in trigger pattern as well?
2) In case, 'trigger pattern' has only crankshaft trigger pattern, do i need to connect crankshaft position sensor to 'primary trigger'?
I have also arranged all the harness/connector pinout information (sensors and actuators not the ECU), ibnjector flow rate, fuel pump pressure and sensor calibration data for this engine. I shall hopefully share the data over here, may be it could be helpful for someone wokring on same engine.
Thanks for the anticipated rescue.
Make: Daihatsu
- crankshaft_trigger_pattern_acquired_from_engine.png (57.94 KiB) Viewed 10895 times
Re: Daihatsu KF-VE Engine
Does the decoder properly decodes RPM based on that crank trigger shape on the real vehicle?
cam support is a separate story if it's VVT, also we simply do not know anything about the cam signal shape. A single single tooth could be enabled as a generic option.
Please discover the magic of rusEFI online a crank-only example would be https://rusefi.com/online/view.php?msq=258
wiki is best for information sharing
https://github.com/rusefi/rusefi/wiki/HOWTO-M73-v12-on-Proteus and https://github.com/rusefi/rusefi/wiki/Mazda-Miata-2003-alt are examples
Overall for a plan, shall we get this engine starting/cranking with just crank to begin with? Later you would be able to add without changing the wiring.
Hello again,
Thanks for a prompt response.
1) With the help of the example you quoted, i configured the build as '4 stroke without cam sensor', in dev console i receive trigger signal as expected but its not decoding the RPM. RPM field stays at zero. I have attached the figure from dev console(trigger_crank_only),
2) As you have suggested to enable a generic single tooth cam, what option do i have to enable for the purpose?
For overall plan, yes its pretty good suggestion to attain starting/cranking with 'crank only',
Please correct me if wrong, for 'crank only' implementation I shall have to go for batch injection.
- trigger_crank_only.png (108.63 KiB) Viewed 10881 times
Please post a link to your tune on rusEFI online
See https://rusefi.com/forum/viewtopic.php?p=40388#p40388 for instructions on verbose trigger details.
For posting the tune online: right i shall post right after this reply.
For verbose output, I tried in dev console and got the following output
I followed the thread further, swapped the crankshaft VR sensor wires. Right now i am getting the following output:
After swapping the wires, trigger is decoding the RPM and detecting TDC (vertical green line in dev console). But trigger decodes RPM bit higher, more than 1000. Is it suppose to happen during cranking?
2021-04-25_06_23_04_329: EngineState: TRG rpm=0 time=1127 index=0: gap=290.835 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_329: EngineState: TRG rpm=0 time=1127 index=1: gap=1.774 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_329: EngineState: calc 0: action 103 value 1127.00
2021-04-25_06_23_04_329: EngineState: calc 1: action 1 value 0.00
2021-04-25_06_23_04_329: EngineState: calc 2: action 5 value 1.00
2021-04-25_06_23_04_344: EngineState: calc 3: action 103 value 1127.00
2021-04-25_06_23_04_344: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_06_23_04_344: EngineState: calc 5: action 2 value 0.00
2021-04-25_06_23_04_344: EngineState: calc 6: action 6 value 0.00
2021-04-25_06_23_04_344: EngineState: calc 7: action 127 value 0.01
2021-04-25_06_23_04_344: EngineState: calc 8: action 1 value 1.00
2021-04-25_06_23_04_360: EngineState: calc 9: action 2 value 1.00
2021-04-25_06_23_04_360: EngineState: calc 10: action 7 value 1.00
2021-04-25_06_23_04_360: EngineState: setPin pump on
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=0: gap=0.001 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=1: gap=290.835 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=0: gap=0.800 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=1: gap=0.001 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=0: gap=0.902 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=1: gap=0.800 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=0: gap=0.939 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_360: EngineState: TRG rpm=0 time=1127 index=1: gap=0.902 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.964 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.939 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.985 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.964 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=1.071 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.985 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=2.780 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=1.071 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.358 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=2.780 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.800 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.358 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.781 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.800 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.837 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.781 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=0: gap=0.896 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_429: EngineState: TRG rpm=0 time=1127 index=1: gap=0.837 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=0.941 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=0.896 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=0.963 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=0.941 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=0.991 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=0.963 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=0.990 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=0.991 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=1.005 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=0.990 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=1.006 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=1.005 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=1.014 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=1.006 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=0: gap=1.018 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_529: EngineState: TRG rpm=0 time=1127 index=1: gap=1.014 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=0: gap=1.022 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=1: gap=1.018 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=0: gap=1.123 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=1: gap=1.022 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=0: gap=3.211 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=1: gap=1.123 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=0: gap=1.315 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=1: gap=3.211 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=0: gap=0.358 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_545: EngineState: TRG rpm=0 time=1127 index=1: gap=1.315 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_629: EngineState: TRG rpm=0 time=1127 index=0: gap=0.986 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_629: EngineState: TRG rpm=0 time=1127 index=1: gap=0.358 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_629: EngineState: TRG rpm=0 time=1127 index=0: gap=1.036 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_645: EngineState: TRG rpm=0 time=1127 index=1: gap=0.986 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_645: EngineState: TRG rpm=0 time=1127 index=0: gap=0.993 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=1.036 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.872 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=0.993 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.809 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=0.872 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.849 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=0.809 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.908 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=0.849 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.942 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=0.908 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.970 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=1: gap=0.942 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_660: EngineState: TRG rpm=0 time=1127 index=0: gap=0.978 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=0.970 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=0: gap=1.063 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=0.978 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=0: gap=2.702 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=1.063 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=0: gap=0.374 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=2.702 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=0: gap=0.965 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=0.374 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=0: gap=1.038 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=0.965 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=0: gap=1.030 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=1.038 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_676: EngineState: TRG rpm=0 time=1127 index=1: gap=1.030 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_730: EngineState: TRG rpm=0 time=1127 index=0: gap=1.092 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_730: EngineState: TRG rpm=0 time=1127 index=1: gap=1.063 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=1.141 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=1.092 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=1.260 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=1.141 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=1.054 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=1.260 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=0.929 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=1.054 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=1.050 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=0.929 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=1.034 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=1.050 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=0.994 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=1.034 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=0: gap=0.875 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_745: EngineState: TRG rpm=0 time=1127 index=1: gap=0.994 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_761: EngineState: TRG rpm=0 time=1127 index=0: gap=0.867 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_761: EngineState: TRG rpm=0 time=1127 index=1: gap=0.875 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_761: EngineState: TRG rpm=0 time=1127 index=0: gap=2.177 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_761: EngineState: TRG rpm=0 time=1127 index=1: gap=0.867 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_830: EngineState: TRG rpm=0 time=1127 index=0: gap=0.879 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_830: EngineState: TRG rpm=0 time=1127 index=1: gap=2.177 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=0: gap=0.351 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=1: gap=0.879 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=0: gap=0.950 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=1: gap=0.351 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=0: gap=1.009 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=1: gap=0.950 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=0: gap=1.008 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=1: gap=1.009 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=0: gap=1.021 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=1: gap=1.008 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_845: EngineState: TRG rpm=0 time=1127 index=0: gap=1.026 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.021 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=1.038 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.026 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=1.052 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.038 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=1.089 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.052 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=1.123 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.089 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=1.243 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.123 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=2.309 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.243 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=1.056 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=2.309 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=0: gap=0.471 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_861: EngineState: TRG rpm=0 time=1127 index=1: gap=1.056 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_930: EngineState: TRG rpm=0 time=1127 index=0: gap=0.842 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_930: EngineState: TRG rpm=0 time=1127 index=1: gap=0.471 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_930: EngineState: TRG rpm=0 time=1127 index=0: gap=0.919 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_946: EngineState: TRG rpm=0 time=1127 index=1: gap=0.842 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_946: EngineState: TRG rpm=0 time=1127 index=0: gap=0.960 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_946: EngineState: TRG rpm=0 time=1127 index=1: gap=0.919 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_946: EngineState: TRG rpm=0 time=1127 index=0: gap=0.987 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=1: gap=0.960 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=0: gap=1.009 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=1: gap=0.987 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=0: gap=1.026 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=1: gap=1.009 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=0: gap=1.039 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=1: gap=1.026 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=0: gap=1.070 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=1: gap=1.039 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=0: gap=1.098 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=1: gap=1.070 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_04_961: EngineState: TRG rpm=0 time=1127 index=0: gap=1.275 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_04_977: EngineState: TRG rpm=0 time=1127 index=1: gap=1.098 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_031: EngineState: TRG rpm=0 time=1128 index=0: gap=5.800 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_031: EngineState: TRG rpm=0 time=1128 index=1: gap=1.275 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_031: EngineState: TRG rpm=0 time=1128 index=0: gap=0.208 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=5.800 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=0: gap=0.826 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=0.208 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=0: gap=0.946 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=0.826 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=0: gap=0.981 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=0.946 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=0: gap=1.031 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=0.981 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=0: gap=1.076 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=1.031 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=0: gap=1.164 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_046: EngineState: TRG rpm=0 time=1128 index=1: gap=1.076 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_131: EngineState: TRG rpm=0 time=1128 index=0: gap=1.506 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_131: EngineState: TRG rpm=0 time=1128 index=1: gap=1.164 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_131: EngineState: TRG rpm=0 time=1128 index=0: gap=2.993 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_131: EngineState: TRG rpm=0 time=1128 index=1: gap=1.506 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_146: EngineState: TRG rpm=0 time=1128 index=0: gap=0.310 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_146: EngineState: TRG rpm=0 time=1128 index=1: gap=2.993 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_231: EngineState: TRG rpm=0 time=1128 index=0: gap=0.962 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_231: EngineState: TRG rpm=0 time=1128 index=1: gap=0.310 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_231: EngineState: TRG rpm=0 time=1128 index=0: gap=1.116 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_246: EngineState: TRG rpm=0 time=1128 index=1: gap=0.962 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_246: EngineState: TRG rpm=0 time=1128 index=0: gap=1.394 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_246: EngineState: TRG rpm=0 time=1128 index=1: gap=1.116 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_331: EngineState: TRG rpm=0 time=1128 index=0: gap=4.186 expected from 0.375 to 0.625 error=No
2021-04-25_06_23_05_331: EngineState: TRG rpm=0 time=1128 index=1: gap=1.394 expected from 0.750 to 1.250 error=No
2021-04-25_06_23_05_848: EngineState: engine has STOPPED
2021-04-25_06_23_05_848: EngineState: templog engine has STOPPED 0.507400989
2021-04-25_06_23_05_863: EngineState: trigger ICU hw: 1141 1140 1
2021-04-25_06_23_05_879: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_06_23_05_879: EngineState: trigger#1 event counters up=0/down=1141
2021-04-25_06_23_05_879: EngineState: expected cycle events 30/0/0
2021-04-25_06_23_05_879: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_06_23_05_879: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_06_23_05_879: EngineState: synchronizationNeeded=Yes/isError=No/total errors=0 ord_err=0/total revolutions=2/self=No
2021-04-25_06_23_05_879: EngineState: gap from 0.37 to 0.62
2021-04-25_06_23_05_879: EngineState: primary trigger input: PC6
2021-04-25_06_23_05_879: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_06_23_05_879: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_06_23_05_879: EngineState: primary logic input: NONE
2021-04-25_06_23_05_879: EngineState: secondary logic input: NONE
2021-04-25_06_23_05_879: EngineState: totalTriggerHandlerMaxTime=520
2021-04-25_06_23_06_364: EngineState: calc 0: action 103 value 1129.00
2021-04-25_06_23_06_364: EngineState: calc 1: action 1 value 0.00
2021-04-25_06_23_06_380: EngineState: calc 2: action 5 value 1.00
2021-04-25_06_23_06_380: EngineState: calc 3: action 103 value 1129.00
2021-04-25_06_23_06_395: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_06_23_06_395: EngineState: calc 5: action 2 value 0.00
2021-04-25_06_23_06_395: EngineState: calc 6: action 6 value 0.00
2021-04-25_06_23_06_395: EngineState: calc 7: action 127 value 1.00
2021-04-25_06_23_06_395: EngineState: calc 8: action 1 value 1.00
2021-04-25_06_23_06_395: EngineState: calc 9: action 2 value 0.00
2021-04-25_06_23_06_395: EngineState: calc 10: action 7 value 0.00
2021-04-25_06_23_06_395: EngineState: setPin pump off
2021-04-25_06_41_06_879: EngineState: calc 0: action 103 value 47.00
2021-04-25_06_41_06_879: EngineState: calc 1: action 1 value 0.00
2021-04-25_06_41_06_879: EngineState: calc 2: action 5 value 1.00
2021-04-25_06_41_06_879: EngineState: calc 3: action 103 value 47.00
2021-04-25_06_41_06_879: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_06_41_06_894: EngineState: calc 5: action 2 value 0.00
2021-04-25_06_41_06_894: EngineState: calc 6: action 6 value 0.00
2021-04-25_06_41_06_894: EngineState: calc 7: action 127 value 0.01
2021-04-25_06_41_06_910: EngineState: calc 8: action 1 value 1.00
2021-04-25_06_41_06_910: EngineState: calc 9: action 2 value 1.00
2021-04-25_06_41_06_910: EngineState: calc 10: action 7 value 1.00
2021-04-25_06_41_06_925: EngineState: setPin pump on
2021-04-25_06_41_07_295: EngineState: WARNING: trigger not happy current 16/0/0 expected 30/0/0
2021-04-25_06_41_10_032: EngineState: engine has STOPPED
2021-04-25_06_41_10_032: EngineState: templog engine has STOPPED 0.527544021
2021-04-25_06_41_10_048: EngineState: trigger ICU hw: 344 343 1
2021-04-25_06_41_10_048: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_06_41_10_063: EngineState: trigger#1 event counters up=0/down=344
2021-04-25_06_41_10_063: EngineState: expected cycle events 30/0/0
2021-04-25_06_41_10_063: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_06_41_10_063: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_06_41_10_063: EngineState: synchronizationNeeded=Yes/isError=Yes/total errors=14 ord_err=0/total revolutions=18/self=No
2021-04-25_06_41_10_070: EngineState: gap from 0.37 to 0.62
2021-04-25_06_41_10_070: EngineState: primary trigger input: PC6
2021-04-25_06_41_10_070: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_06_41_10_070: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_06_41_10_070: EngineState: primary logic input: NONE
2021-04-25_06_41_10_070: EngineState: secondary logic input: NONE
2021-04-25_06_41_10_070: EngineState: totalTriggerHandlerMaxTime=491
2021-04-25_06_41_10_549: EngineState: engine stopped
2021-04-25_06_41_10_549: EngineState: calc 0: action 103 value 50.00
2021-04-25_06_41_10_549: EngineState: calc 1: action 1 value 0.00
2021-04-25_06_41_10_549: EngineState: calc 2: action 5 value 1.00
2021-04-25_06_41_10_549: EngineState: calc 3: action 103 value 50.00
2021-04-25_06_41_10_549: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_06_41_10_549: EngineState: calc 5: action 2 value 0.00
2021-04-25_06_41_10_549: EngineState: calc 6: action 6 value 0.00
2021-04-25_06_41_10_549: EngineState: calc 7: action 127 value 1.02
2021-04-25_06_41_10_565: EngineState: calc 8: action 1 value 1.00
2021-04-25_06_41_10_565: EngineState: calc 9: action 2 value 0.00
2021-04-25_06_41_10_565: EngineState: calc 10: action 7 value 0.00
2021-04-25_06_41_10_565: EngineState: setPin pump off
2021-04-25_06_41_35_224: EngineState: calc 0: action 103 value 75.00
2021-04-25_06_41_35_224: EngineState: calc 1: action 1 value 0.00
2021-04-25_06_41_35_224: EngineState: calc 2: action 5 value 1.00
2021-04-25_06_41_35_224: EngineState: calc 3: action 103 value 75.00
2021-04-25_06_41_35_240: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_06_41_35_240: EngineState: calc 5: action 2 value 0.00
2021-04-25_06_41_35_240: EngineState: calc 6: action 6 value 0.00
2021-04-25_06_41_35_240: EngineState: calc 7: action 127 value 0.00
2021-04-25_06_41_35_255: EngineState: calc 8: action 1 value 1.00
2021-04-25_06_41_35_262: EngineState: calc 9: action 2 value 1.00
2021-04-25_06_41_35_262: EngineState: calc 10: action 7 value 1.00
2021-04-25_06_41_35_262: EngineState: setPin pump on
2021-04-25_06_41_35_654: EngineState: WARNING: trigger not happy current 17/0/0 expected 30/0/0
2021-04-25_06_41_40_316: EngineState: engine has STOPPED
2021-04-25_06_41_40_316: EngineState: templog engine has STOPPED 0.538187026
2021-04-25_06_41_40_316: EngineState: trigger ICU hw: 965 964 1
2021-04-25_06_41_40_331: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_06_41_40_331: EngineState: trigger#1 event counters up=0/down=965
2021-04-25_06_41_40_331: EngineState: expected cycle events 30/0/0
2021-04-25_06_41_40_331: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_06_41_40_331: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_06_41_40_331: EngineState: synchronizationNeeded=Yes/isError=No/total errors=36 ord_err=0/total revolutions=49/self=No
2021-04-25_06_41_40_331: EngineState: gap from 0.37 to 0.62
2021-04-25_06_41_40_331: EngineState: primary trigger input: PC6
2021-04-25_06_41_40_331: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_06_41_40_331: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_06_41_40_331: EngineState: primary logic input: NONE
2021-04-25_06_41_40_331: EngineState: secondary logic input: NONE
2021-04-25_06_41_40_331: EngineState: totalTriggerHandlerMaxTime=491
2021-04-25_06_41_40_817: EngineState: engine stopped
2021-04-25_06_41_40_817: EngineState: calc 0: action 103 value 81.00
2021-04-25_06_41_40_817: EngineState: calc 1: action 1 value 0.00
2021-04-25_06_41_40_817: EngineState: calc 2: action 5 value 1.00
2021-04-25_06_41_40_817: EngineState: calc 3: action 103 value 81.00
2021-04-25_06_41_40_817: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_06_41_40_817: EngineState: calc 5: action 2 value 0.00
2021-04-25_06_41_40_832: EngineState: calc 6: action 6 value 0.00
2021-04-25_06_41_40_832: EngineState: calc 7: action 127 value 1.03
2021-04-25_06_41_40_832: EngineState: calc 8: action 1 value 1.00
2021-04-25_06_41_40_832: EngineState: calc 9: action 2 value 0.00
2021-04-25_06_41_40_832: EngineState: calc 10: action 7 value 0.00
2021-04-25_06_41_40_848: EngineState: setPin pump off
second snippet does not contain verbose trigger info
Regrets, i overlooked checking the verbose output,
it is here:
it is here:
2021-04-25_07_14_01_163: EngineState: index=0 NaN gap
2021-04-25_07_14_01_163: EngineState: TRG rpm=0 time=42 index=0: gap=2147483647.647 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_178: EngineState: index=1 NaN gap
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=0: gap=1.269 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=1: gap=1.593 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=0: gap=0.647 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=1: gap=1.269 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=0: gap=0.517 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=1: gap=0.647 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=0: gap=1.030 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=1: gap=0.517 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=0: gap=0.987 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=1: gap=1.030 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=0: gap=0.910 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=1: gap=0.987 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=0: gap=0.788 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=1: gap=0.910 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=0: gap=0.806 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_279: EngineState: TRG rpm=0 time=42 index=1: gap=0.788 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=0: gap=0.867 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=1: gap=0.806 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=0: gap=0.924 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=1: gap=0.867 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=0: gap=0.951 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=1: gap=0.924 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_363: EngineState: TRG rpm=0 time=42 index=0: gap=0.978 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=0.951 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=0.980 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=0.978 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=2.085 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=0.980 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=0.955 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=2.085 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=0.520 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=0.955 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=1.048 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=0.520 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=1.044 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=1.048 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=1.062 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=1.044 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=1.092 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=1.062 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=1.145 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=1.092 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=1.204 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=1.145 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=0: gap=0.974 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=1.204 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_379: EngineState: TRG rpm=0 time=42 index=1: gap=0.974 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=1.038 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=0.980 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=1.054 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=1.038 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=1.012 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=1.054 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=0.954 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=1.012 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=0.812 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=0.954 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=1.606 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=0.812 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=1.209 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=1.606 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=0: gap=0.623 expected from 0.375 to 0.625 error=No
2021-04-25_07_14_01_488: EngineState: TRG rpm=0 time=42 index=1: gap=1.209 expected from 0.750 to 1.250 error=No
2021-04-25_07_14_01_488: EngineState: WARNING: trigger not happy current 16/0/0 expected 30/0/0
2021-04-25_07_14_01_488: EngineState: error: synchronizationPoint @ index 30 expected 30/0/0 got 16/0/0
2021-04-25_07_14_01_488: EngineState: TRG rpm=946 time=42 index=0: gap=0.505 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_488: EngineState: TRG rpm=946 time=42 index=1: gap=0.623 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_488: EngineState: TRG rpm=946 time=42 index=0: gap=1.017 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_488: EngineState: TRG rpm=946 time=42 index=1: gap=0.505 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_500: EngineState: TRG rpm=946 time=42 index=0: gap=1.008 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_500: EngineState: TRG rpm=946 time=42 index=1: gap=1.017 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_500: EngineState: TRG rpm=946 time=42 index=0: gap=1.016 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_508: EngineState: TRG rpm=946 time=42 index=1: gap=1.008 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=0: gap=1.015 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=1: gap=1.016 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=0: gap=1.055 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=1: gap=1.015 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=0: gap=1.043 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=1: gap=1.055 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=0: gap=1.075 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=1: gap=1.043 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_510: EngineState: TRG rpm=946 time=42 index=0: gap=1.109 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_519: EngineState: TRG rpm=946 time=42 index=1: gap=1.075 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_581: EngineState: TRG rpm=946 time=42 index=0: gap=1.200 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_581: EngineState: TRG rpm=946 time=42 index=1: gap=1.109 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_581: EngineState: TRG rpm=946 time=42 index=0: gap=1.194 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_581: EngineState: TRG rpm=946 time=42 index=1: gap=1.200 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_581: EngineState: TRG rpm=946 time=42 index=0: gap=1.913 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_591: EngineState: TRG rpm=946 time=42 index=1: gap=1.194 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_591: EngineState: TRG rpm=946 time=42 index=0: gap=1.041 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_591: EngineState: TRG rpm=946 time=42 index=1: gap=1.913 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_591: EngineState: TRG rpm=946 time=42 index=0: gap=0.476 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_591: EngineState: TRG rpm=946 time=42 index=1: gap=1.041 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_591: EngineState: error: synchronizationPoint @ index 26 expected 30/0/0 got 14/0/0
2021-04-25_07_14_01_591: EngineState: TRG rpm=1221 time=42 index=0: gap=0.846 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_599: EngineState: TRG rpm=1221 time=42 index=1: gap=0.476 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_599: EngineState: TRG rpm=1221 time=42 index=0: gap=0.820 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_599: EngineState: TRG rpm=1221 time=42 index=1: gap=0.846 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=42 index=0: gap=0.892 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=42 index=1: gap=0.820 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=0: gap=0.919 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=1: gap=0.892 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=0: gap=0.955 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=1: gap=0.919 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=0: gap=0.983 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=1: gap=0.955 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=0: gap=0.976 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=1: gap=0.983 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=0: gap=1.006 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=1: gap=0.976 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=0: gap=0.997 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_601: EngineState: TRG rpm=1221 time=43 index=1: gap=1.006 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_680: EngineState: TRG rpm=1221 time=43 index=0: gap=1.003 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_680: EngineState: TRG rpm=1221 time=43 index=1: gap=0.997 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_680: EngineState: TRG rpm=1221 time=43 index=0: gap=1.011 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_680: EngineState: TRG rpm=1221 time=43 index=1: gap=1.003 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_680: EngineState: TRG rpm=1221 time=43 index=0: gap=1.019 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_680: EngineState: TRG rpm=1221 time=43 index=1: gap=1.011 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=0: gap=1.009 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=1: gap=1.019 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=0: gap=2.227 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=1: gap=1.009 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=0: gap=1.779 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=1: gap=2.227 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=0: gap=0.922 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=1: gap=1.779 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_690: EngineState: TRG rpm=1221 time=43 index=0: gap=0.504 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1221 time=43 index=1: gap=0.922 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_705: EngineState: error: synchronizationPoint @ index 32 expected 30/0/0 got 17/0/0
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=0: gap=1.046 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=1: gap=0.504 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=0: gap=1.030 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=1: gap=1.046 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=0: gap=0.927 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=1: gap=1.030 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=0: gap=0.828 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_705: EngineState: TRG rpm=1081 time=43 index=1: gap=0.927 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_790: EngineState: TRG rpm=1081 time=43 index=0: gap=0.827 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_790: EngineState: TRG rpm=1081 time=43 index=1: gap=0.828 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_790: EngineState: TRG rpm=1081 time=43 index=0: gap=0.889 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_792: EngineState: TRG rpm=1081 time=43 index=1: gap=0.827 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_792: EngineState: TRG rpm=1081 time=43 index=0: gap=0.927 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_792: EngineState: TRG rpm=1081 time=43 index=1: gap=0.889 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=0: gap=0.958 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=1: gap=0.927 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=0: gap=0.975 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=1: gap=0.958 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=0: gap=0.976 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=1: gap=0.975 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=0: gap=2.090 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=1: gap=0.976 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=0: gap=0.945 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=1: gap=2.090 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=0: gap=0.517 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_800: EngineState: TRG rpm=1081 time=43 index=1: gap=0.945 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_800: EngineState: error: synchronizationPoint @ index 24 expected 30/0/0 got 13/0/0
2021-04-25_07_14_01_800: EngineState: TRG rpm=1486 time=43 index=0: gap=1.043 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=1: gap=0.517 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=0: gap=1.041 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=1: gap=1.043 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=0: gap=1.045 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=1: gap=1.041 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=0: gap=1.071 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=1: gap=1.045 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=0: gap=1.096 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_810: EngineState: TRG rpm=1486 time=43 index=1: gap=1.071 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=0: gap=1.190 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=1: gap=1.096 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=0: gap=1.221 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=1: gap=1.190 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=0: gap=0.975 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=1: gap=1.221 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=0: gap=0.999 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_812: EngineState: TRG rpm=1486 time=43 index=1: gap=0.975 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_903: EngineState: TRG rpm=1486 time=43 index=0: gap=1.043 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_903: EngineState: TRG rpm=1486 time=43 index=1: gap=0.999 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_903: EngineState: TRG rpm=1486 time=43 index=0: gap=1.031 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_903: EngineState: TRG rpm=1486 time=43 index=1: gap=1.043 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_903: EngineState: TRG rpm=1486 time=43 index=0: gap=0.931 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_903: EngineState: TRG rpm=1486 time=43 index=1: gap=1.031 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_911: EngineState: TRG rpm=1486 time=43 index=0: gap=0.822 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_911: EngineState: TRG rpm=1486 time=43 index=1: gap=0.931 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_911: EngineState: TRG rpm=1486 time=43 index=0: gap=1.627 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_923: EngineState: TRG rpm=1486 time=43 index=1: gap=0.822 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_923: EngineState: TRG rpm=1486 time=43 index=0: gap=1.216 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_923: EngineState: TRG rpm=1486 time=43 index=1: gap=1.627 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_923: EngineState: TRG rpm=1486 time=43 index=0: gap=0.624 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_923: EngineState: TRG rpm=1486 time=43 index=1: gap=1.216 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_923: EngineState: error: synchronizationPoint @ index 30 expected 30/0/0 got 16/0/0
2021-04-25_07_14_01_931: EngineState: TRG rpm=1003 time=43 index=0: gap=0.506 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_931: EngineState: TRG rpm=1003 time=43 index=1: gap=0.624 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=0: gap=1.012 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=1: gap=0.506 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=0: gap=1.013 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=1: gap=1.012 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=1: gap=1.013 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=0: gap=1.022 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=0: gap=1.045 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=1: gap=1.022 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=0: gap=1.042 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=1: gap=1.045 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=0: gap=1.075 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_933: EngineState: TRG rpm=1003 time=43 index=1: gap=1.042 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_941: EngineState: TRG rpm=1003 time=43 index=0: gap=1.104 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_943: EngineState: TRG rpm=1003 time=43 index=1: gap=1.075 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_01_943: EngineState: TRG rpm=1003 time=43 index=0: gap=1.190 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_01_943: EngineState: TRG rpm=1003 time=43 index=1: gap=1.104 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_003: EngineState: TRG rpm=1003 time=43 index=0: gap=1.207 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_003: EngineState: TRG rpm=1003 time=43 index=1: gap=1.190 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_003: EngineState: TRG rpm=1003 time=43 index=0: gap=1.978 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_003: EngineState: TRG rpm=1003 time=43 index=1: gap=1.207 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_003: EngineState: TRG rpm=1003 time=43 index=0: gap=1.042 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_003: EngineState: TRG rpm=1003 time=43 index=1: gap=1.978 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_013: EngineState: TRG rpm=1003 time=43 index=0: gap=0.474 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_013: EngineState: TRG rpm=1003 time=43 index=1: gap=1.042 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_013: EngineState: error: synchronizationPoint @ index 26 expected 30/0/0 got 14/0/0
2021-04-25_07_14_02_013: EngineState: TRG rpm=1225 time=43 index=0: gap=0.842 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_022: EngineState: TRG rpm=1225 time=43 index=1: gap=0.474 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.821 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.842 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.893 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.821 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.922 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.893 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.957 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.922 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.976 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.957 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.980 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.976 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=1.007 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.980 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=0.996 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=1.007 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=1.010 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=0.996 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=1.011 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=1.010 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=0: gap=1.013 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_024: EngineState: TRG rpm=1225 time=43 index=1: gap=1.011 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_114: EngineState: TRG rpm=1225 time=43 index=0: gap=1.016 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_114: EngineState: TRG rpm=1225 time=43 index=1: gap=1.013 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_114: EngineState: TRG rpm=1225 time=43 index=0: gap=2.237 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_114: EngineState: TRG rpm=1225 time=43 index=1: gap=1.016 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_114: EngineState: TRG rpm=1225 time=43 index=0: gap=1.791 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_122: EngineState: TRG rpm=1225 time=43 index=1: gap=2.237 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1225 time=43 index=0: gap=0.899 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1225 time=43 index=1: gap=1.791 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1225 time=43 index=0: gap=0.500 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1225 time=43 index=1: gap=0.899 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_124: EngineState: error: synchronizationPoint @ index 32 expected 30/0/0 got 17/0/0
2021-04-25_07_14_02_124: EngineState: TRG rpm=1067 time=43 index=0: gap=1.050 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1067 time=43 index=1: gap=0.500 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1067 time=43 index=0: gap=1.021 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1067 time=43 index=1: gap=1.050 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1067 time=43 index=0: gap=0.944 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_124: EngineState: TRG rpm=1067 time=43 index=1: gap=1.021 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=0: gap=0.830 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=1: gap=0.944 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=0: gap=0.829 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=1: gap=0.830 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=0: gap=0.886 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=1: gap=0.829 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=0: gap=0.926 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_132: EngineState: TRG rpm=1067 time=43 index=1: gap=0.886 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_215: EngineState: TRG rpm=1067 time=43 index=0: gap=0.964 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_215: EngineState: TRG rpm=1067 time=43 index=1: gap=0.926 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_215: EngineState: TRG rpm=1067 time=43 index=0: gap=0.976 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_215: EngineState: TRG rpm=1067 time=43 index=1: gap=0.964 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=0: gap=0.974 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=1: gap=0.976 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=0: gap=2.095 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=1: gap=0.974 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=0: gap=0.944 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=1: gap=2.095 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_231: EngineState: TRG rpm=1067 time=43 index=0: gap=0.518 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_246: EngineState: TRG rpm=1067 time=43 index=1: gap=0.944 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_253: EngineState: error: synchronizationPoint @ index 24 expected 30/0/0 got 13/0/0
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=0: gap=1.045 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=1: gap=0.518 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=0: gap=1.032 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=1: gap=1.045 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=0: gap=1.053 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=1: gap=1.032 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_253: EngineState: TRG rpm=1472 time=43 index=0: gap=1.068 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=1: gap=1.053 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=0: gap=1.108 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=1: gap=1.068 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=0: gap=1.200 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=1: gap=1.108 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=0: gap=1.205 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=1: gap=1.200 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=0: gap=0.936 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=1: gap=1.205 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=0: gap=1.032 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_268: EngineState: TRG rpm=1472 time=43 index=1: gap=0.936 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_284: EngineState: TRG rpm=1472 time=43 index=0: gap=1.040 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_284: EngineState: TRG rpm=1472 time=43 index=1: gap=1.032 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_284: EngineState: TRG rpm=1472 time=43 index=0: gap=1.026 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_284: EngineState: TRG rpm=1472 time=43 index=1: gap=1.040 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=0: gap=0.927 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=1: gap=1.026 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=0: gap=0.819 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=1: gap=0.927 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=0: gap=1.633 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=1: gap=0.819 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=0: gap=1.217 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_315: EngineState: TRG rpm=1472 time=43 index=1: gap=1.633 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=1472 time=43 index=0: gap=0.624 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=1472 time=43 index=1: gap=1.217 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: error: synchronizationPoint @ index 30 expected 30/0/0 got 16/0/0
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=0.506 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=0.624 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.015 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=0.506 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.011 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.015 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.010 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.011 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.027 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.010 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.044 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.027 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.040 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.044 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.075 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.040 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.099 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.075 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=0: gap=1.194 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_331: EngineState: TRG rpm=993 time=43 index=1: gap=1.099 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=0: gap=1.490 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=1: gap=1.194 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=0: gap=1.859 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=1: gap=1.490 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=0: gap=0.595 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=1: gap=1.859 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=0: gap=0.706 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=1: gap=0.595 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=0: gap=0.873 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_416: EngineState: TRG rpm=993 time=43 index=1: gap=0.706 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=0.943 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=0.873 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=0.973 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=0.943 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=1.001 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=0.973 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=1.009 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=1.001 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=1.033 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=1.009 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=1.060 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=1.033 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=0: gap=1.086 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_431: EngineState: TRG rpm=993 time=43 index=1: gap=1.060 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=0: gap=1.139 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=1: gap=1.086 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=0: gap=3.588 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=1: gap=1.139 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=0: gap=1.179 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=1: gap=3.588 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=0: gap=0.295 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=1: gap=1.179 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=0: gap=0.915 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_516: EngineState: TRG rpm=993 time=43 index=1: gap=0.295 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=0: gap=0.958 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=1: gap=0.915 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=0: gap=1.008 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=1: gap=0.958 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=0: gap=1.059 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=1: gap=1.008 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_616: EngineState: TRG rpm=993 time=43 index=0: gap=1.131 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_632: EngineState: TRG rpm=993 time=43 index=1: gap=1.059 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_654: EngineState: TRG rpm=993 time=44 index=0: gap=1.290 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_654: EngineState: TRG rpm=993 time=44 index=1: gap=1.131 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_669: EngineState: TRG rpm=993 time=44 index=0: gap=3.506 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_669: EngineState: TRG rpm=993 time=44 index=1: gap=1.290 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_716: EngineState: TRG rpm=993 time=44 index=0: gap=0.379 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_716: EngineState: TRG rpm=993 time=44 index=1: gap=3.506 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_716: EngineState: TRG rpm=993 time=44 index=0: gap=0.866 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_716: EngineState: TRG rpm=993 time=44 index=1: gap=0.379 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_748: EngineState: TRG rpm=993 time=44 index=0: gap=1.033 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_748: EngineState: TRG rpm=993 time=44 index=1: gap=0.866 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_02_748: EngineState: TRG rpm=993 time=44 index=0: gap=1.240 expected from 0.375 to 0.625 error=Yes
2021-04-25_07_14_02_754: EngineState: TRG rpm=993 time=44 index=1: gap=1.033 expected from 0.750 to 1.250 error=Yes
2021-04-25_07_14_03_263: EngineState: engine has STOPPED
2021-04-25_07_14_03_263: EngineState: templog engine has STOPPED 0.546182990
2021-04-25_07_14_03_263: EngineState: trigger ICU hw: 192 191 1
2021-04-25_07_14_03_263: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_07_14_03_263: EngineState: trigger#1 event counters up=0/down=192
2021-04-25_07_14_03_294: EngineState: expected cycle events 30/0/0
2021-04-25_07_14_03_294: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_07_14_03_294: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_07_14_03_294: EngineState: synchronizationNeeded=Yes/isError=Yes/total errors=9 ord_err=0/total revolutions=10/self=No
2021-04-25_07_14_03_294: EngineState: gap from 0.37 to 0.62
2021-04-25_07_14_03_294: EngineState: primary trigger input: PC6
2021-04-25_07_14_03_294: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_07_14_03_310: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_07_14_03_310: EngineState: primary logic input: NONE
2021-04-25_07_14_03_310: EngineState: secondary logic input: NONE
2021-04-25_07_14_03_310: EngineState: totalTriggerHandlerMaxTime=1589
2021-04-25_07_14_03_767: EngineState: engine stopped
2021-04-25_07_14_03_767: EngineState: calc 0: action 103 value 45.00
2021-04-25_07_14_03_767: EngineState: calc 1: action 1 value 0.00
2021-04-25_07_14_03_767: EngineState: calc 2: action 5 value 1.00
2021-04-25_07_14_03_767: EngineState: calc 3: action 103 value 45.00
2021-04-25_07_14_03_767: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_07_14_03_767: EngineState: calc 5: action 2 value 0.00
2021-04-25_07_14_03_767: EngineState: calc 6: action 6 value 0.00
2021-04-25_07_14_03_767: EngineState: calc 7: action 127 value 1.04
2021-04-25_07_14_03_783: EngineState: calc 8: action 1 value 1.00
2021-04-25_07_14_03_783: EngineState: calc 9: action 2 value 0.00
2021-04-25_07_14_03_783: EngineState: calc 10: action 7 value 0.00
2021-04-25_07_14_03_783: EngineState: setPin pump off
Re: Daihatsu KF-VE Engine
Please post a link to your tune on rusEFI online. I would like to "use only rising edge" as it should be for VR.
In TS please switch to "display only interesting"/"display logic signals" that would chance engine sniffer look a bit.
I have posted the currentTune file at rusefi online,
Yes, 'use only rising edge' and ''display only interesting' both fields are already set 'true'.
Meanwhile, thanks for prompt response ......
https://github.com/rusefi/rusefi/wiki/HOWTO-upload-tune#q-any-hints-on-forum-links-best-practices
"Please post a link"
In your opinion have you posted a link to your tune?
Yes thank you!
Healthy cranking RPM for a small engine is usually about 250 rpm give or take.
At the moment trigger was expecting a 0.5 ratio gap +/- 25% followed by a 1.0 ratio gap +/0 25%
In your case I see a 0.625 followed by 1.0 and 0.625 followed by 1.2, looks like at the moment decoder is confusing these two separate areas.
I've just changed expectation to 0.6 +/- 25% followed by 0.9 +/- 25% https://github.com/rusefi/rusefi/commit/ac2d0b99cd517f0eeb8ac9a2ec5105ec51246690
Can you please take latest "nightly" firmware in about 15 minutes from now and see if RPM would stay more consistent?
grep '=0.6' -A 1 b
2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=0: gap=0.647 expected from 0.375 to 0.625 error=No 2021-04-25_07_14_01_263: EngineState: TRG rpm=0 time=42 index=1: gap=1.269 expected from 0.750 to 1.250 error=No
Sorry for inconvenience,
Earlier I donwloaded the rusEFI bundle for console, hex/bin file, and ini file.
How do it get updated firmware? Is there a specific download page etc, (regrets if my question is a bit odd)?
https://rusefi.com/build_server/
https://rusefi.com/build_server/rusefi_bundle.zip probably you would need to flash that firmware into your board
I have updated the firmware, TS configuration is also updated using ini file in the new build. 'higher RPM' than expected is still persistent.
Following is the output
Am i overlooking something or making some very basic error?
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=0: gap=1.021 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=1: gap=1.011 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG duty 3397.103515625 279597
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=0: gap=1.019 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=1: gap=1.021 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=0: gap=1.046 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=1: gap=1.019 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG duty 3626.155273437 298449
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=0: gap=1.045 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=1: gap=1.046 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=0: gap=1.073 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_453: EngineState: TRG rpm=1458 time=497 index=1: gap=1.045 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG duty 3883.237060546 319608
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=0: gap=1.122 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=1: gap=1.073 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=0: gap=1.186 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=1: gap=1.122 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG duty 4225.600097656 347786
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=0: gap=1.234 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=1: gap=1.186 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=0: gap=1.925 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=1: gap=1.234 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG duty 5039.516113281 414775
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=0: gap=1.050 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=1: gap=1.925 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=0: gap=0.466 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=1458 time=497 index=1: gap=1.050 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=0: gap=0.842 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=1: gap=0.466 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=0: gap=0.826 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=1: gap=0.842 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG duty 102.271644592 22854
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=0: gap=0.884 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=1: gap=0.826 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=0: gap=0.931 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=1: gap=0.884 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG duty 186.553787231 41688
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=0: gap=0.950 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=1: gap=0.931 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=0: gap=0.981 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_537: EngineState: TRG rpm=537 time=497 index=1: gap=0.950 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_553: EngineState: TRG duty 265.130310058 59247
2021-04-25_08_31_57_553: EngineState: TRG rpm=537 time=497 index=0: gap=0.979 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_553: EngineState: TRG rpm=537 time=497 index=1: gap=0.981 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG duty 265.130310058 59247
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=1.004 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=0.979 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG duty 342.453826904 76526
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=1.004 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=1.003 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG duty 420.368041992 93937
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=1.015 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=1.003 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=1.015 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG duty 500.779327392 111906
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=1.013 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=2.230 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=1.013 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG duty 682.522460937 152519
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=1.838 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=2.230 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=0.890 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=1.838 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG duty 980.154724121 219029
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=0: gap=0.495 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=537 time=497 index=1: gap=0.890 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_637: EngineState: error: synchronizationPoint @ index 32 expected 30/0/0 got 17/0/0
2021-04-25_08_31_57_637: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_57_637: EngineState: TRG rpm=1037 time=497 index=0: gap=1.042 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_637: EngineState: TRG rpm=1037 time=497 index=1: gap=0.495 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_653: EngineState: TRG rpm=1037 time=497 index=0: gap=1.019 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_653: EngineState: TRG rpm=1037 time=497 index=1: gap=1.042 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_737: EngineState: TRG duty 302.501525878 35005
2021-04-25_08_31_57_737: EngineState: TRG rpm=1037 time=497 index=0: gap=0.932 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_737: EngineState: TRG rpm=1037 time=497 index=1: gap=1.019 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_737: EngineState: TRG rpm=1037 time=497 index=0: gap=0.831 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=1: gap=0.932 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG duty 537.010437011 62142
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=0: gap=0.838 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=1: gap=0.831 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=0: gap=0.880 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=1: gap=0.838 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG duty 710.094360351 82171
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=0: gap=0.931 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=1: gap=0.880 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=0: gap=0.957 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=1: gap=0.931 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG duty 864.494995117 100038
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=0: gap=0.975 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=1: gap=0.957 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_753: EngineState: TRG rpm=1037 time=497 index=0: gap=0.980 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=1: gap=0.975 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG duty 1012.146545410 117124
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=0: gap=2.084 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=1: gap=0.980 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=0: gap=0.954 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=1: gap=2.084 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG duty 1305.980468750 151126
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=0: gap=0.521 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG rpm=1037 time=497 index=1: gap=0.954 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_768: EngineState: error: synchronizationPoint @ index 24 expected 30/0/0 got 13/0/0
2021-04-25_08_31_57_768: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_57_768: EngineState: TRG rpm=1453 time=497 index=0: gap=1.041 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_768: EngineState: TRG rpm=1453 time=497 index=1: gap=0.521 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=0: gap=1.041 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=1: gap=1.041 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG duty 232.552642822 19206
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=0: gap=1.050 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=0: gap=1.078 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=1: gap=1.050 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG duty 495.896759033 40955
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=0: gap=1.113 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=1: gap=1.078 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=0: gap=1.229 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_784: EngineState: TRG rpm=1453 time=497 index=1: gap=1.113 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_853: EngineState: TRG duty 856.289184570 70719
2021-04-25_08_31_57_853: EngineState: TRG rpm=1453 time=497 index=0: gap=1.175 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_853: EngineState: TRG rpm=1453 time=497 index=1: gap=1.229 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_853: EngineState: TRG rpm=1453 time=497 index=0: gap=0.904 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=1.175 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG duty 1239.178833007 102341
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=1.055 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=0.904 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=1.029 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=1.055 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG duty 1655.475463867 136722
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=1.018 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=1.029 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=0.932 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=1.018 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG duty 2050.800537109 169371
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=0.822 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=0.932 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=1.630 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=0.822 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG duty 2580.564208984 213123
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=1.216 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=1.630 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=0.625 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=1.216 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG duty 2983.844238281 246429
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=0.507 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=0.625 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=0: gap=1.012 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=497 index=1: gap=0.507 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG duty 3190.921142578 263531
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=498 index=0: gap=1.009 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=498 index=1: gap=1.012 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=498 index=0: gap=1.022 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_869: EngineState: TRG rpm=1453 time=498 index=1: gap=1.009 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG duty 3404.826904296 281197
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=0: gap=1.016 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=1: gap=1.022 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=0: gap=1.048 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=1: gap=1.016 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG duty 3632.790527343 300024
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=0: gap=1.045 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=1: gap=1.048 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=0: gap=1.078 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_884: EngineState: TRG rpm=1453 time=498 index=1: gap=1.045 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_953: EngineState: TRG duty 3889.862548828 321255
2021-04-25_08_31_57_953: EngineState: TRG rpm=1453 time=498 index=0: gap=1.111 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_953: EngineState: TRG rpm=1453 time=498 index=1: gap=1.078 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_953: EngineState: TRG rpm=1453 time=498 index=0: gap=1.208 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=1: gap=1.111 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG duty 4235.070800781 349765
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=0: gap=1.218 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=1: gap=1.208 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=0: gap=1.925 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=1: gap=1.218 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG duty 5045.033691406 416658
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=0: gap=1.042 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=1: gap=1.925 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=0: gap=0.465 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=1453 time=498 index=1: gap=1.042 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_57_969: EngineState: TRG rpm=536 time=498 index=0: gap=0.847 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=536 time=498 index=1: gap=0.465 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=536 time=498 index=0: gap=0.828 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=536 time=498 index=1: gap=0.847 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG duty 101.728332519 22775
2021-04-25_08_31_57_969: EngineState: TRG rpm=536 time=498 index=0: gap=0.883 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_969: EngineState: TRG rpm=536 time=498 index=1: gap=0.828 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=0: gap=0.927 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=1: gap=0.883 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG duty 185.165664672 41455
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=0: gap=0.953 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=1: gap=0.927 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=0: gap=0.979 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=1: gap=0.953 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG duty 263.113464355 58906
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=0: gap=0.980 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_57_985: EngineState: TRG rpm=536 time=498 index=1: gap=0.979 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_054: EngineState: TRG duty 263.113464355 58906
2021-04-25_08_31_58_054: EngineState: TRG rpm=536 time=498 index=0: gap=1.007 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_054: EngineState: TRG rpm=536 time=498 index=1: gap=0.980 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_054: EngineState: TRG duty 340.065185546 76134
2021-04-25_08_31_58_054: EngineState: TRG rpm=536 time=498 index=0: gap=1.000 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_054: EngineState: TRG rpm=536 time=498 index=1: gap=1.007 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=1.000 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=1.000 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG duty 417.070526123 93374
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=1.032 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=1.008 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=1.032 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG duty 497.238250732 111322
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=1.012 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=1.008 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=2.240 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=1.012 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG duty 679.071777343 152031
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=1.819 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=2.240 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=0.923 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=1.819 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG duty 984.712402343 220458
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=0: gap=0.532 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=536 time=498 index=1: gap=0.923 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: error: synchronizationPoint @ index 32 expected 30/0/0 got 17/0/0
2021-04-25_08_31_58_069: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_58_069: EngineState: TRG rpm=1029 time=498 index=0: gap=1.107 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=1029 time=498 index=1: gap=0.532 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_069: EngineState: TRG rpm=1029 time=498 index=1: gap=1.107 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_154: EngineState: TRG duty 383.062377929 44672
2021-04-25_08_31_58_154: EngineState: TRG rpm=1029 time=498 index=0: gap=0.978 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_154: EngineState: TRG rpm=1029 time=498 index=1: gap=1.107 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_154: EngineState: TRG rpm=1029 time=498 index=0: gap=0.757 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_154: EngineState: TRG rpm=1029 time=498 index=1: gap=0.978 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_169: EngineState: TRG duty 666.997802734 77784
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.780 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.757 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG duty 666.997802734 77784
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.858 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.780 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG duty 857.311340332 99978
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.914 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.858 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.948 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.914 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG duty 1022.457214355 119237
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.971 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.948 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.973 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.971 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG duty 1178.608032226 137447
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=2.086 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.973 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.952 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=2.086 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG duty 1488.877197265 173630
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=0: gap=0.518 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1029 time=498 index=1: gap=0.952 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: error: synchronizationPoint @ index 24 expected 30/0/0 got 13/0/0
2021-04-25_08_31_58_216: EngineState: TRG duty 0.000000000 0
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=0: gap=1.046 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=1: gap=0.518 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=0: gap=1.040 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=1: gap=1.046 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG duty 215.302993774 20424
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=0: gap=1.061 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=1: gap=1.040 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=0: gap=1.086 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_216: EngineState: TRG rpm=1265 time=498 index=1: gap=1.061 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_254: EngineState: TRG duty 463.411651611 43960
2021-04-25_08_31_58_254: EngineState: TRG rpm=1265 time=498 index=0: gap=1.138 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_254: EngineState: TRG rpm=1265 time=498 index=1: gap=1.086 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_254: EngineState: TRG rpm=1265 time=498 index=0: gap=1.314 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_254: EngineState: TRG rpm=1265 time=498 index=1: gap=1.138 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_254: EngineState: TRG duty 834.657531738 79177
2021-04-25_08_31_58_254: EngineState: TRG rpm=1265 time=498 index=0: gap=3.563 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=1.314 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG duty 834.657531738 79177
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=0.321 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=3.563 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG duty 1260.013793945 119527
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=0.797 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=0.321 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=0.915 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=0.797 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG duty 1570.402587890 148971
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=0.962 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=0.915 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=0.989 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=0.962 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG duty 1866.127929687 177024
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=1.018 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=0.989 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=0: gap=1.024 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_270: EngineState: TRG rpm=1265 time=498 index=1: gap=1.018 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_354: EngineState: TRG duty 2174.735107421 206299
2021-04-25_08_31_58_354: EngineState: TRG rpm=1265 time=498 index=0: gap=2.325 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_354: EngineState: TRG rpm=1265 time=498 index=1: gap=1.024 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_370: EngineState: TRG duty 2174.735107421 206299
2021-04-25_08_31_58_370: EngineState: TRG rpm=1265 time=498 index=0: gap=1.611 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_370: EngineState: TRG rpm=1265 time=498 index=1: gap=2.325 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_370: EngineState: TRG duty 3331.250976562 316008
2021-04-25_08_31_58_370: EngineState: TRG rpm=1265 time=498 index=0: gap=2.064 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_370: EngineState: TRG rpm=1265 time=498 index=1: gap=1.611 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_454: EngineState: TRG duty 3331.250976562 316008
2021-04-25_08_31_58_454: EngineState: TRG rpm=1265 time=498 index=0: gap=0.394 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_454: EngineState: TRG rpm=1265 time=498 index=1: gap=2.064 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_470: EngineState: TRG duty 4273.865722656 405426
2021-04-25_08_31_58_470: EngineState: TRG rpm=1265 time=498 index=0: gap=0.482 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=1: gap=0.394 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG duty 4273.865722656 405426
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=0: gap=1.082 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=1: gap=0.482 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG duty 4766.435546875 452152
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=0: gap=1.150 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=1: gap=1.082 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=0: gap=1.487 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_485: EngineState: TRG rpm=1265 time=498 index=1: gap=1.150 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_555: EngineState: TRG duty 5609.009765625 532080
2021-04-25_08_31_58_555: EngineState: TRG rpm=1265 time=498 index=0: gap=3.125 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_555: EngineState: TRG rpm=1265 time=498 index=1: gap=1.487 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_570: EngineState: TRG duty 5609.009765625 532080
2021-04-25_08_31_58_570: EngineState: TRG rpm=1265 time=498 index=0: gap=0.329 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_570: EngineState: TRG rpm=1265 time=498 index=1: gap=3.125 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_586: EngineState: TRG duty 6478.169921875 614530
2021-04-25_08_31_58_586: EngineState: TRG rpm=1265 time=498 index=0: gap=1.065 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_586: EngineState: TRG rpm=1265 time=498 index=1: gap=0.329 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_58_655: EngineState: TRG duty 6478.169921875 614530
2021-04-25_08_31_58_655: EngineState: TRG rpm=1265 time=498 index=0: gap=1.581 expected from 0.450 to 0.750 error=Yes
2021-04-25_08_31_58_655: EngineState: TRG rpm=1265 time=498 index=1: gap=1.065 expected from 0.674 to 1.125 error=Yes
2021-04-25_08_31_59_172: EngineState: engine has STOPPED
2021-04-25_08_31_59_172: EngineState: templog engine has STOPPED 0.542496025
2021-04-25_08_31_59_172: EngineState: trigger ICU hw: 1057 1056 1
2021-04-25_08_31_59_187: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_08_31_59_187: EngineState: trigger#1 event counters up=0/down=1057
2021-04-25_08_31_59_203: EngineState: trigger#1 event counters up=0/down=1057
2021-04-25_08_31_59_203: EngineState: expected cycle events 30/0/0
2021-04-25_08_31_59_203: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_08_31_59_203: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_08_31_59_203: EngineState: synchronizationNeeded=Yes/isError=No/total errors=35 ord_err=0/total revolutions=52/self=No
2021-04-25_08_31_59_203: EngineState: gap from 0.45 to 0.75
2021-04-25_08_31_59_203: EngineState: primary trigger input: PC6
2021-04-25_08_31_59_203: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_08_31_59_203: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_08_31_59_203: EngineState: primary logic input: NONE
2021-04-25_08_31_59_203: EngineState: secondary logic input: NONE
2021-04-25_08_31_59_203: EngineState: totalTriggerHandlerMaxTime=1609
2021-04-25_08_31_59_672: EngineState: engine stopped
2021-04-25_08_31_59_672: EngineState: calc 0: action 103 value 499.00
2021-04-25_08_31_59_672: EngineState: calc 1: action 1 value 0.00
2021-04-25_08_31_59_672: EngineState: calc 2: action 5 value 1.00
2021-04-25_08_31_59_672: EngineState: calc 3: action 103 value 499.00
2021-04-25_08_31_59_672: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_08_31_59_672: EngineState: calc 5: action 2 value 0.00
2021-04-25_08_31_59_672: EngineState: calc 6: action 6 value 0.00
2021-04-25_08_31_59_672: EngineState: calc 7: action 127 value 1.04
2021-04-25_08_31_59_672: EngineState: calc 8: action 1 value 1.00
2021-04-25_08_31_59_672: EngineState: calc 9: action 2 value 0.00
2021-04-25_08_31_59_672: EngineState: calc 10: action 7 value 0.00
2021-04-25_08_31_59_672: EngineState: setPin pump off
Now I am really confused. Maybe time to flip the wires one more time>
Hopefully by now you are starting to understand how trigger decoder works - it looks for a sequence of gaps in the specific range. From experience we have magic gap values hardcoded with +/- 25% tolerance.
With this trigger being a bit special instead of looking for just one magic gap I am looking for two consecutive magic gaps. Something is wrong with the expectation.
A small red flag is gap=3.563 which does not happen as periodically as I would expect it to happen.
One way or another can you identify a series of gaps (length anywhere between 1 and 12) which would reliably detect sync point?
I think wire polarity is all fine, because upon swapping the wires once again ............ RPM is not detected again and stays at zero.
Message output after I swap the crankshaft VR wires
2021-04-25_08_58_32_502: EngineState: TRG duty 0.000000000 486059192
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=0: gap=1.052 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=1: gap=1.048 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=0: gap=1.088 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=1: gap=1.052 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_502: EngineState: TRG duty 0.000000000 486080964
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=0: gap=1.136 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=1: gap=1.088 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=0: gap=1.267 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_502: EngineState: TRG rpm=0 time=161 index=1: gap=1.136 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_596: EngineState: TRG duty 0.000000000 486112315
2021-04-25_08_58_32_596: EngineState: TRG rpm=0 time=161 index=0: gap=1.127 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_596: EngineState: TRG rpm=0 time=161 index=1: gap=1.267 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_612: EngineState: TRG duty 0.000000000 486112315
2021-04-25_08_58_32_612: EngineState: TRG rpm=0 time=161 index=0: gap=0.888 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=1.127 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG duty 0.000000000 486143712
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=1.096 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=0.888 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=1.080 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=1.096 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG duty 0.000000000 486180909
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=1.060 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=1.080 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=0.853 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=1.060 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG duty 0.000000000 486214593
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=0.831 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=0.853 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=2.096 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=0.831 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG duty 0.000000000 486273311
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=0.873 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=2.096 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=0.351 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=0.873 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG duty 0.000000000 486291322
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=0.949 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=0.351 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=1.010 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=1: gap=0.949 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_627: EngineState: TRG duty 0.000000000 486308597
2021-04-25_08_58_32_627: EngineState: TRG rpm=0 time=161 index=0: gap=1.007 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=1: gap=1.010 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_643: EngineState: TRG duty 0.000000000 486308597
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=0: gap=1.024 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=1: gap=1.007 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_643: EngineState: TRG duty 0.000000000 486326430
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=0: gap=1.022 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=1: gap=1.024 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=0: gap=1.049 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=1: gap=1.022 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_643: EngineState: TRG duty 0.000000000 486345574
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=0: gap=1.054 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_643: EngineState: TRG rpm=0 time=161 index=1: gap=1.049 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_696: EngineState: TRG duty 0.000000000 486345574
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=0: gap=1.088 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=1: gap=1.054 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_696: EngineState: TRG duty 0.000000000 486367561
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=0: gap=1.142 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=1: gap=1.088 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=0: gap=1.290 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=1: gap=1.142 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_696: EngineState: TRG duty 0.000000000 486399982
2021-04-25_08_58_32_696: EngineState: TRG rpm=0 time=161 index=0: gap=3.753 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=1.290 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG duty 0.000000000 486399982
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=0.302 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=3.753 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG duty 0.000000000 486436775
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=0.814 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=0.302 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=0.909 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=0.814 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG duty 0.000000000 486464011
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=0.954 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=0.909 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=0.987 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=0.954 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG duty 0.000000000 486489680
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=1.003 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=0.987 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=0: gap=1.026 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_712: EngineState: TRG rpm=0 time=161 index=1: gap=1.003 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_812: EngineState: TRG duty 0.000000000 486516123
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=0: gap=1.041 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=1: gap=1.026 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=0: gap=1.073 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=1: gap=1.041 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_812: EngineState: TRG duty 0.000000000 486545686
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=0: gap=1.107 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=1: gap=1.073 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=0: gap=1.303 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=1: gap=1.107 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_812: EngineState: TRG duty 0.000000000 486588379
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=0: gap=5.119 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_812: EngineState: TRG rpm=0 time=161 index=1: gap=1.303 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_828: EngineState: TRG duty 0.000000000 486588379
2021-04-25_08_58_32_828: EngineState: TRG rpm=0 time=161 index=0: gap=0.237 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_828: EngineState: TRG rpm=0 time=161 index=1: gap=5.119 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_828: EngineState: TRG duty 0.000000000 486640386
2021-04-25_08_58_32_828: EngineState: TRG rpm=0 time=161 index=0: gap=0.807 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_828: EngineState: TRG rpm=0 time=161 index=1: gap=0.237 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_897: EngineState: TRG duty 0.000000000 486640386
2021-04-25_08_58_32_897: EngineState: TRG rpm=0 time=161 index=0: gap=0.935 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_897: EngineState: TRG rpm=0 time=161 index=1: gap=0.807 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_897: EngineState: TRG duty 0.000000000 486679676
2021-04-25_08_58_32_897: EngineState: TRG rpm=0 time=161 index=0: gap=0.977 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_897: EngineState: TRG rpm=0 time=161 index=1: gap=0.935 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_897: EngineState: TRG rpm=0 time=161 index=0: gap=1.029 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_897: EngineState: TRG rpm=0 time=161 index=1: gap=0.977 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_897: EngineState: TRG duty 0.000000000 486719225
2021-04-25_08_58_32_912: EngineState: TRG rpm=0 time=161 index=0: gap=1.085 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_912: EngineState: TRG rpm=0 time=161 index=1: gap=1.029 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_912: EngineState: TRG duty 0.000000000 486719225
2021-04-25_08_58_32_912: EngineState: TRG rpm=0 time=161 index=0: gap=1.192 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_912: EngineState: TRG rpm=0 time=161 index=1: gap=1.085 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_32_912: EngineState: TRG duty 0.000000000 486770450
2021-04-25_08_58_32_912: EngineState: TRG rpm=0 time=161 index=0: gap=1.615 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_32_912: EngineState: TRG rpm=0 time=161 index=1: gap=1.192 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_33_012: EngineState: TRG duty 0.000000000 486770450
2021-04-25_08_58_33_012: EngineState: TRG rpm=0 time=161 index=0: gap=2.420 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_33_012: EngineState: TRG rpm=0 time=161 index=1: gap=1.615 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_33_012: EngineState: TRG duty 0.000000000 486970686
2021-04-25_08_58_33_012: EngineState: TRG rpm=0 time=161 index=0: gap=0.364 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_33_012: EngineState: TRG rpm=0 time=161 index=1: gap=2.420 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_33_043: EngineState: TRG rpm=0 time=161 index=0: gap=0.948 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_33_043: EngineState: TRG rpm=0 time=161 index=1: gap=0.364 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_33_043: EngineState: TRG duty 0.000000000 487039904
2021-04-25_08_58_33_043: EngineState: TRG rpm=0 time=161 index=0: gap=1.133 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_33_043: EngineState: TRG rpm=0 time=161 index=1: gap=0.948 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_33_113: EngineState: TRG duty 0.000000000 487039904
2021-04-25_08_58_33_113: EngineState: TRG rpm=0 time=161 index=0: gap=1.601 expected from 0.450 to 0.750 error=No
2021-04-25_08_58_33_113: EngineState: TRG rpm=0 time=161 index=1: gap=1.133 expected from 0.674 to 1.125 error=No
2021-04-25_08_58_33_614: EngineState: engine has STOPPED
2021-04-25_08_58_33_614: EngineState: templog engine has STOPPED 0.505478024
2021-04-25_08_58_33_614: EngineState: trigger ICU hw: 749 748 1
2021-04-25_08_58_33_630: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_08_58_33_645: EngineState: trigger#1 event counters up=0/down=749
2021-04-25_08_58_33_645: EngineState: expected cycle events 30/0/0
2021-04-25_08_58_33_645: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_08_58_33_661: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_08_58_33_661: EngineState: synchronizationNeeded=Yes/isError=No/total errors=0 ord_err=0/total revolutions=1/self=No
2021-04-25_08_58_33_661: EngineState: gap from 0.45 to 0.75
2021-04-25_08_58_33_661: EngineState: primary trigger input: PC6
2021-04-25_08_58_33_661: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_08_58_33_661: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_08_58_33_661: EngineState: primary logic input: NONE
2021-04-25_08_58_33_661: EngineState: secondary logic input: NONE
2021-04-25_08_58_33_661: EngineState: totalTriggerHandlerMaxTime=534
2021-04-25_08_58_34_060: EngineState: calc 0: action 103 value 162.00
2021-04-25_08_58_34_060: EngineState: calc 1: action 1 value 0.00
2021-04-25_08_58_34_060: EngineState: calc 2: action 5 value 1.00
2021-04-25_08_58_34_060: EngineState: calc 3: action 103 value 162.00
2021-04-25_08_58_34_060: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_08_58_34_060: EngineState: calc 5: action 2 value 0.00
2021-04-25_08_58_34_068: EngineState: calc 6: action 6 value 0.00
2021-04-25_08_58_34_081: EngineState: calc 7: action 127 value 1.00
2021-04-25_08_58_34_081: EngineState: calc 8: action 1 value 1.00
2021-04-25_08_58_34_089: EngineState: calc 9: action 2 value 0.00
2021-04-25_08_58_34_089: EngineState: calc 10: action 7 value 0.00
2021-04-25_08_58_34_089: EngineState: setPin pump off
Latest snipped is a bit short it's only 51 gaps? For a 36 tooth trigger we want at least 36*4*2 gap lines?
Need your help identifying a pattern in those "index=0: gap=" lines
Battery is now drained, let me recharge it ........... meanwhile i shall have a thorough go through once again from all the observation i can get.
Thanks for prompt response all the time.
Just a hint: remove spark plugs while we are trying to get trigger sync.
Without spark plugs you get zero compression thus your starter is not pumping air thus your signals are much more linear.
Now its fault on my side, i should have done it earlier
Battery will also run longer under low load conditions.............
thanks.
thanks.
Removed the plugs, furthermore i checked out every thing a to z, starter relay output contact was giving some noise at ohm meter, relay is now replaced.
Trigger decoding is now fine (please correct me if my interpretation is mistaken), i rcvd the following output:
As i understand from the forum and the pages, after successful testing of trigger signal (with spark plugs installed and injection/ignition disabled)my next logical step would be measurement of trigger angle advance?
2021-04-25_14_58_32_299: EngineState: TRG rpm=559 time=70 index=1: gap=0.496 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_315: EngineState: TRG duty 1219.295410156 261745
2021-04-25_14_58_32_315: EngineState: TRG rpm=559 time=70 index=0: gap=0.998 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_315: EngineState: TRG rpm=559 time=70 index=1: gap=1.005 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_361: EngineState: TRG duty 1219.295410156 261745
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=0: gap=1.003 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=1: gap=0.998 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_361: EngineState: TRG duty 1328.156005859 285114
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=0: gap=1.006 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=1: gap=1.003 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=0: gap=1.026 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=1: gap=1.006 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_361: EngineState: TRG duty 1440.650146484 309263
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=0: gap=1.040 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=1: gap=1.026 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=0: gap=1.047 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_361: EngineState: TRG rpm=559 time=70 index=1: gap=1.040 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_361: EngineState: TRG duty 1563.317993164 335596
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=0: gap=1.039 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=1: gap=1.047 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_377: EngineState: TRG duty 1563.317993164 335596
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=0: gap=1.056 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=1: gap=1.039 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_377: EngineState: TRG duty 1697.990478515 364506
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=0: gap=1.042 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=1: gap=1.056 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=0: gap=2.263 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=1: gap=1.042 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_377: EngineState: TRG duty 2015.777343750 432725
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=0: gap=1.108 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=1: gap=2.263 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=0: gap=0.548 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_377: EngineState: TRG rpm=559 time=70 index=1: gap=1.108 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_462: EngineState: TRG duty 0.000000000 0
2021-04-25_14_58_32_462: EngineState: TRG rpm=511 time=70 index=0: gap=1.077 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_462: EngineState: TRG rpm=511 time=70 index=1: gap=0.548 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_477: EngineState: TRG duty 0.000000000 0
2021-04-25_14_58_32_477: EngineState: TRG rpm=511 time=70 index=0: gap=1.052 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_477: EngineState: TRG rpm=511 time=70 index=1: gap=1.077 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_477: EngineState: TRG duty 200.218307495 47018
2021-04-25_14_58_32_477: EngineState: TRG rpm=511 time=70 index=0: gap=1.046 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_477: EngineState: TRG rpm=511 time=70 index=1: gap=1.052 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_493: EngineState: TRG duty 200.218307495 47018
2021-04-25_14_58_32_493: EngineState: TRG rpm=511 time=70 index=0: gap=1.029 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_493: EngineState: TRG rpm=511 time=70 index=1: gap=1.046 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_493: EngineState: TRG duty 415.890106201 97665
2021-04-25_14_58_32_493: EngineState: TRG rpm=511 time=70 index=0: gap=1.010 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_493: EngineState: TRG rpm=511 time=70 index=1: gap=1.029 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_499: EngineState: TRG rpm=511 time=70 index=0: gap=1.013 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_499: EngineState: TRG rpm=511 time=70 index=1: gap=1.010 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_499: EngineState: TRG duty 636.846496582 149553
2021-04-25_14_58_32_499: EngineState: TRG rpm=511 time=70 index=0: gap=0.996 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_499: EngineState: TRG rpm=511 time=70 index=1: gap=1.013 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_499: EngineState: TRG rpm=511 time=70 index=0: gap=0.993 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_499: EngineState: TRG rpm=511 time=70 index=1: gap=0.996 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_562: EngineState: TRG duty 855.494873046 200899
2021-04-25_14_58_32_562: EngineState: TRG rpm=511 time=70 index=0: gap=0.975 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_562: EngineState: TRG rpm=511 time=70 index=1: gap=0.993 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_577: EngineState: TRG duty 855.494873046 200899
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=0: gap=0.976 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=1: gap=0.975 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_577: EngineState: TRG duty 1063.689086914 249790
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=0: gap=0.986 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=1: gap=0.976 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=0: gap=1.021 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=1: gap=0.986 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_577: EngineState: TRG duty 1273.501342773 299061
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=0: gap=1.053 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=1: gap=1.021 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_32_577: EngineState: TRG rpm=511 time=70 index=0: gap=2.492 expected from 0.450 to 0.750 error=No
2021-04-25_14_58_32_593: EngineState: TRG rpm=511 time=70 index=1: gap=1.053 expected from 0.674 to 1.125 error=No
2021-04-25_14_58_33_063: EngineState: engine has STOPPED
2021-04-25_14_58_33_063: EngineState: templog engine has STOPPED 0.502303004
2021-04-25_14_58_33_063: EngineState: trigger ICU hw: 881 880 1
2021-04-25_14_58_33_063: EngineState: Template DEFAULT_FRANKENSO (0) trigger TT_36_2_2_2 (23) useRiseEdge=Yes onlyFront=Yes useOnlyFirstChannel=No tdcOffset=0.00
2021-04-25_14_58_33_063: EngineState: trigger#1 event counters up=0/down=881
2021-04-25_14_58_33_063: EngineState: expected cycle events 30/0/0
2021-04-25_14_58_33_063: EngineState: trigger type=23/need2ndChannel=No
2021-04-25_14_58_33_079: EngineState: expected duty #0=0.49/#1=0.00
2021-04-25_14_58_33_079: EngineState: synchronizationNeeded=Yes/isError=No/total errors=2 ord_err=0/total revolutions=30/self=No
2021-04-25_14_58_33_079: EngineState: gap from 0.45 to 0.75
2021-04-25_14_58_33_079: EngineState: primary trigger input: PC6
2021-04-25_14_58_33_079: EngineState: primary trigger simulator: PD1 OM_DEFAULT freq=1200
2021-04-25_14_58_33_079: EngineState: trigger error extra LED: NONE OM_DEFAULT
2021-04-25_14_58_33_079: EngineState: primary logic input: NONE
2021-04-25_14_58_33_079: EngineState: secondary logic input: NONE
2021-04-25_14_58_33_079: EngineState: totalTriggerHandlerMaxTime=1255
2021-04-25_14_58_33_564: EngineState: engine stopped
2021-04-25_14_58_33_564: EngineState: calc 0: action 103 value 71.00
2021-04-25_14_58_33_564: EngineState: calc 1: action 1 value 0.00
2021-04-25_14_58_33_564: EngineState: calc 2: action 5 value 1.00
2021-04-25_14_58_33_564: EngineState: calc 3: action 103 value 71.00
2021-04-25_14_58_33_564: EngineState: calc 4: action startup_fuel_pump_duration value 4.00
2021-04-25_14_58_33_564: EngineState: calc 5: action 2 value 0.00
2021-04-25_14_58_33_564: EngineState: calc 6: action 6 value 0.00
2021-04-25_14_58_33_564: EngineState: calc 7: action 127 value 1.00
2021-04-25_14_58_33_564: EngineState: calc 8: action 1 value 1.00
2021-04-25_14_58_33_564: EngineState: calc 9: action 2 value 0.00
2021-04-25_14_58_33_564: EngineState: calc 10: action 7 value 0.00
2021-04-25_14_58_33_564: EngineState: setPin pump off
Re: Daihatsu KF-VE Engine
that's progress!!!
yes offset is next step once you have synchronization.
are you planning to use a timing gun with ignition without fuel?
hello,
For TDC detection, I am searching for some alternative to timing gun .... bad-luck,
Please confirm that my understanding is right,
Once i have some mechanism wokring, i need to tune 'trigger delay' to attain the TDC at ignition time?
Is that right? Please correct me if wrong,
Apart from it, i am working to complete the firmware toolchain working for me,
Theoretically you can figure out TDC offset analytically but I would recommend some way to validate your theories on the offset value.
Look at the dot on - that's where current trigger decoder believes your TDC is because that's where rusEFI has pretty randomly chosen to have synchronization point. You need an offset to place TDC where it's actually located.
Thanks,
What if i take ignition pulse from ECU,
disconnect ignition coil, connect an LED/Light to it and put it at the dot on the pulley (in the image attached),
Maximum error would be equal to dwell time or less?
Am i right, or am i overlooking something? Please correct .....
- pulley_dot.jpeg (127.5 KiB) Viewed 10823 times
I do not have capacity to think about this hack Please consider using a proper tool for the job.
hello,
The trick worked, from youtube i confirmed that the mark on the pulley which i attached in previous response is correct one.
Coils rcv 12V pulse (adjusted from the jumpers on rusEFI frankenso board), i dicsonnected CYL1 ignition coil from the connector and connected 12V 1.5W LED.
TDC detected by the algorithm is all fine and do not require any trigger delay.
I have already tested individual injectors and ignitiion coils from dev console.
So, my next logical step is to adjust cranking and idling parameters and move to start the engine?
Please correct me, if i am missing something.
Many thanks for prompt response everytime.
Engine started, idle for 20seconds.
please link your current tune. logs and video
