Need to confirm cam sensors are working - console does not show two VVT senosrs
- Slack: Callum Henn***
Don't seem to be getting any confirming data to say the ecu is getting cam sensor data, I may swap over the vr conditioner to a different chip just in case. Any help will be greatly appreciated
Re: Need to confirm cam sensors are working
After some tinkering I found that the vr conditioner was not outputting any signal to the ecu and after swapping to a new conditioner I now have confirmed both cam signals are getting to the ecu's digital inputs.
Re: Need to confirm cam sensors are working - console does not show two VVT senosrs
I've made a change to firmware - please try latest firmware let's see if engine sniffer would display two different VVT sensors
Also please link your tune and logs to this thread if you see two VVT sensors on engine sniffer.
Awesome no worries, I'll try it tomorrow along with the other changes I've made to wideband fw ect
Can confirm after update both vvt1 and vvt 2 show up in the console still fighting a wierd issue where vvt pos said 800+ lol but that's for another day/thread
