Is Renault Logan a Volkswagen Beetle of 2000s?
I wonder if anyone has a URL for good engine wiring diagram.
https://en.wikipedia.org/wiki/Nissan_B_platform
Is Renault Logan the most global vehicle these days?
Re: Is Renault Logan the most global vehicle these days?
Look Lada Largus
yes, but unlike the bug, I don't think one has ever been built as an enthusiast vehicle
I have LOGAN wiring diagrams.
What are you interested in ?
PS : this ECU works with the Renault special 60 - 2 trigger wheel...
Thank you those are now available at https://github.com/rusefi/rusefi/wiki/Vault-of-Renault Those diagrams have no text not the most readable ones but so much better than nothing
I have more documentation (my SECMA engine is also mounted in export LOGAN).
Ask what you need.
Ask what you need.
Logan is a very very long shot for now. A nicer ECU diagram with more text instead of unclear icons would be nice but very low priority. For instance see https://github.com/rusefi/rusefi/wiki/Mazda-Miata-2003 those call out all devices explicitly. Maybe it's the question of being used to and maybe the current one is good enough.
I have some better diagrams but with Renault PnP will be a problem.
They have very French (complicated) configuration management habits. Even OEM ECU are not PnP because of all the continuous changes in production. They trust on VIN to find the right part and even then it's not sure you get the right one.
Generaly I trust only the part number that is on my car to be sure..
