[README] End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Re: End users, PLEASE subscribe to this topic - MAJOR firmware announcements
Bake Cookies Day released
December 2020 Bake Cookies Day
Breaking Changes
GM x24 trigger now uses 0 offset (offset is now built in, previously needed 50 degrees offset)
Added
DAIHATSU 3/4 cylinder trigger https://rusefi.com/images/triggers/trigger_6.png
Ford ST170 VVT cam trigger https://rusefi.com/images/triggers/trigger_42.png
Changed scheduling timer driver to improve scheduling accuracy #1983
Fixed
microRusEFI GP3 & GP4 fixed
Breaking Changes
Added
Fixed
Breaking change:
On our way to quad VVT first VVT shaft target is now "vvt table #1" not "fsio table #1" like before. Anyone using VVT control would have to copy-paste their target table.
More renaming would probably follow later.
While anyone is free to self-assemble anything we publish... Please don't. The rusEFI project uses machine assembled boards to avoid having to troubleshoot poorly user-assembled boards.
- Slack: Orchardperformance
We have outlined the reason for this decision in the wiki page here.
We hope everyone will understand and appreciate there are good reasons for this with the recent hardware.
https://github.com/rusefi/rusefi_documentation/blob/Build-the-firmware/FAQ/FAQ-Why-No-Self-Assembly.md
https://github.com/rusefi/rusefi/releases/tag/2021.06.28_release release with major idle improvements!
In preparation to two banks of VVT in my Nissan we have a small breaking change in snapshot builds:
### Breaking Changes
- vvtOffset field migrated to four vvtOffsets fields. Anyone using VVT would need to manually adjust their configuration.
We have a release candidate https://github.com/rusefi/rusefi/releases/tag/2021.08.27_release
TS project had issues in 2021.08.27 so now a new release candidate https://github.com/rusefi/rusefi/releases/tag/2021.09.09_release
Feel free to move to correct sub-forum if appropriate.
Just wanted to give a shout out that I've uploaded last firmware release for Proteus (20210909_013133) together with my current tune file made with a previous nightly build (20210714_031445_proteus_f4), and I get this error:
.msq uploaded here:
https://rusefi.com/online/?vehicleName=Aurora&user_id=1083&sorts[uploadedMsq]=-1&sorts[uploadedLog]=-1
Any ideas how to get this fixed?
.msq uploaded here:
I read the message is "invalid table axis must be ascending! VE"
please consider fixing your VE table axis and have keys ascending. Two keys of same "1" value is not a valid rusEFI table at https://rusefi.com/online/view.php?msq=638&dialog=veTableDialog
Thanks. I just noticed, lol. After fixing VE, I got prompted with the exact same problem for the VVT intake and exhaust tables (even though I don't have VVT enabled either under advanced trigger or VVT settings).
Had to put in some arbitrary acceding values on X and Y to make the error go away. All fine now, but would've been nice to get that cleaned up
Great idea! this is now done https://github.com/rusefi/rusefi/commit/410e449a22128ba770074f60c19291d2bbc978ee
We have pre-release https://github.com/rusefi/rusefi/releases/tag/2021.10.07_release
Will promote that one to full release status in 48 hours unless we come up with major defects.
In _snapshot_ we now use STM32CubeProgrammer and current STM32 Bootloader driver instead of legacy DfuSe tool and driver.
It's going to be a messy transition, next step would be to update https://github.com/rusefi/rusefi/wiki/HOWTO-DFU
Reminder that we have Install Drivers button in rusEFI console, please download full new bundle, just auto-updating would not get you fresh drivers pack. Fresh drivers pack is called silent_st_drivers2.exe not silent_st_drivers.exe
This change is needed to better support newer chips like F7 used on Proteus 0.6
Some minor internals renaming related to VVT outputs: please make sure your VVT output pin and frequency are migrated while updating to latest firmware. https://github.com/rusefi/rusefi/commit/5f4fa50682e3cfbac81690969d478ea6335535ac
Just removed FSIO from user interface. While deep inside some system logic still runs using FSIO for now, for end users it's Lua time.
https://github.com/rusefi/rusefi/issues/2928
We have a release candidate https://github.com/rusefi/rusefi/releases/tag/2021.11.14_release
Hello Andrey,
what does "hardware_QC_special_build" mean?
Many thanks.
Many thanks.
Added into https://rusefi.com/build_server/readme.txt
More detailed announcement later but David has made http://wiki.rusefi.com/
I've tried to install this RC on my Proteus, but it's failed and now is and now Proteus is no longer recognized by Windows (device manager).
Logfile from FW-update is attached.
I'm able to boot MCU into Bootloader mode (by pressing PROG-button during power on) and I can reprocduce update firmware with the same result. If Proteus is in Bootloader-mode, I see this in device manager under USB-Devices I see STM32 BOOTLOADER:
Sorry, it's in German.
- update.txt
- (4.58 KiB) Downloaded 4367 times
Zeiss, please clarify if you are good at the moment or in the indefinitely loop of bricked?
I've just added stm32-read-dfu.bat script into console\STM32_Programmer_CLI\bin
If yours is a brick at the moment can you please
1) get fresh bundle
2) go to console\STM32_Programmer_CLI\bin and execute stm32-read-dfu.bat to preserve the broken image for later investigation (rusefi_dump.hex file should be created)
once you have rusefi_dump.hex you can use stm32-full-erase.bat for full erase and attempt to flash either RC or latest good release in order to un-bricked if you are bricked
1) get fresh bundle
Hello Andrey,
thank you for a fast response!
At the moment I'm in the indefinitely loop of bricked: bootloader --> flash hex file --> error by verify --> restart board --> no recognition in Windows --> bootloader -->.....
Where did you add it? I just downloaded this bundle and it's not in there. Is it a wrong one?
yes that's wrong. see https://github.com/rusefi/rusefi/wiki/Release-Process
Argh, damned... okay, new try.
Thank you verymuch!
Done, I took this one: https://rusefi.com/build_server/rusefi_bundle_proteus_f7.zip
Done, file and log attached.
After that power cycle into Bootloader and upload firmware with RusEfi Console and all clear!
Thank you verymuch!
- rusefi_dump.hex
- (2.38 MiB) Downloaded 4337 times
- rusefi_dump.log
- (2.07 KiB) Downloaded 4329 times
I believe I had cases of same. This is now https://github.com/rusefi/rusefi/issues/3566
I believe that this is not about specific RC but just an F7 issue we have
Release candidate https://github.com/rusefi/rusefi/releases/tag/2021.12.22_release
Hello Andrej,
I've got some problems after upgrade to January 2022 Release - "Green Juice". I've used this bundle: https://github.com/rusefi/rusefi/releases/download/20220126.release/rusefi_bundle_proteus_f7.zip
I've followed these instructions: https://github.com/rusefi/rusefi/wiki/F7-requires-full-erase
Result:
-> after power cycle I don't have any drives "mounted" (either drive contains rusefi_proteus_f7.ini nor the installed SD card)
-> if I start console, I get the connection dialog, the I hit connect (the right COM port is choosen), the console opens as "not connected"
-> after some time (ca. 10 seconds or so) the console closes without error messages or the like
In CMD I see this output:
The strange thing is:
Result:
and the content of rusefi_tool.log is:rlog Writing to logs/MAIN_rfi_report_2022-03-02_09_28_36_903.csv
2022-03-02_09_28_36_915<EOT>: OS name: Windows 10
2022-03-02_09_28_36_916<EOT>: OS version: 10.0
Console configuration not found C:\Users\Heinrich\.rusEFI\console_properties.xml, using defaults
LazyFile: Not updating logs/README.html since looks to be the same content, new content size=171
Opening rusefi_tool.log
2022-03-02_09_28_37_769<EOT>: Rendering available ports: [Auto Serial, COM11]
2022-03-02_09_28_38_000<EOT>: Reading from https://rusefi.com/console/versions.txt
Wed Mar 02 09:28:38 CET 2022: Server recommends java_console version 20171217 or newer
Wed Mar 02 09:28:38 CET 2022: Server recommends firmware 14892 or newer
Wed Mar 02 09:28:39 CET 2022: Connection refused in getAvailablePorts(): simulator not running in 2041ms
Wed Mar 02 09:28:39 CET 2022: Connection refused in getAvailablePorts(): simulator not running in 2047ms
communicationThread lookup DONE
class com.rusefi.io.CommandQueue: SerialIO started
2022-03-02_09_28_41_978<EOT>: Settings file not found or damaged. Using default settings.
2022-03-02_09_28_42_292<EOT>: Console 20220124
2022-03-02_09_28_42_292<EOT>: Hardware: F4
Zoom setValue 1.0
ANTLR Tool version 4.5 used for code generation does not match the current runtime version 4.9.3
Wed Mar 02 09:28:42 CET 2022: Connection refused in getAvailablePorts(): simulator not running in 2039ms
line 8:6 missing ';' at '['
Got from settings:
2022-03-02_09_28_47_428<EOT>: onWindowOpened
class com.rusefi.io.LinkManager$5: Opening port: COM11
FuelTunePane: Loaded [28.0, 23.0, 17.0, 10.0, 0.0, 0.0, 0.0, 0.0, 32.0, 28.0, 23.0, 17.0, 10.0, 0.0, 0.0, 0.0]
FuelTunePane: Loaded [35.0, 32.0, 28.0, 23.0, 17.0, 10.0, 0.0, 0.0, 37.0, 35.0, 32.0, 28.0, 23.0, 17.0, 10.0, 0.0]
2022-03-02_09_28_48_813<EOT>: ConnectionWatchdog.reconnectTimer restarting: 5000
Shutdown hook...
SystemOut Hook done for rusefi_tool.log
Saved settings to C:\Users\Heinrich\.rusEFI\console_properties.xml
Shutdown hook!
E:\_Software\rusEFI\January_2022\snapshot_20220126_214648_proteus_f7_rusefi\console>
I think I am too stupid to update the firmware of my Proteus...logs/README.html does not exist considering empty current content
I've got a revision 0.6 with F7 in it...2022-03-02_09_28_41_978<EOT>: Settings file not found or damaged. Using default settings.
