Bigger picture is in this post:
https://rusefi.com/forum/viewtopic.php?f=2&t=2147&p=42497#p42497
Now new issue.
Some pin assignments revert back to values set while compiling FW. For example, LED pin assignments (Running, Warning) and Primary CAN BUS pins reverts back after power cycle.
Values set, burned.
After power cycle
any suggestion what can it be?
Some pin assignment reverts back to FW values and not being stored in Flash
- Github Username: opelpanfan
- Slack: Ben
Re: Some pin assignment reverts back to FW values and not being stored in Flash
This smells like "Overrides" - "Overrides" as in "overrule, overturn"
At the moment we have to help in the blind without a URL for you custom code fork. It's hard to help in the blind. At the moment we are having a case of Trabant
https://github.com/rusefi/rusefi/wiki/Hardware#q-this-is-all-very-cool-but-you-guys-do-not-have-a-plugplay-for-my-trabant-i-think-i-will-go-and-make-a-new-rusefi-board-just-for-my-trabant
void setBoardConfigOverrides(void) {
setHellen176LedPins();
setupVbatt();
setSdCardConfigurationOverrides();
engineConfiguration->clt.config.bias_resistor = 4700;
engineConfiguration->iat.config.bias_resistor = 4700;
engineConfiguration->canTxPin = GPIOD_1;
engineConfiguration->canRxPin = GPIOD_0;
- Slack: Ben
Thank you Andrey. Yes it smells like Trabant but had this hardware so use what I have. Sorry will try to keep posts as minimal as possible.
