See also https://rusefi.com/forum/viewtopic.php?t=1478
https://wbo2.com/lsu/sensors.htm says
LSU 4.9 17 025 Bosch # 0 258 017 025 33" = 830 mm
LSU 4.9 17 123 Bosch # 0 258 017 123 13" = 330 mm
are there longer options? like a 100cm or 120cm?
LSU 4.9 cable lengths?
Re: LSU 4.9 cable lengths?
Someone said 1200mm long 0 281 004 150
Correct, 0 281 004 150 should have 1215mm overall lenght.
Do you know anything closer to 1000mm?
Not ad-hoc. I've got ESITronic on my PC and will try to find some sensors for you.
I.e, short look into ESI (LSU4.93 probes) says:
- 0 281 004 150: 1215mm
- 0 281 004 184: 1000mm
- 0 258 017 012: 1060mm
- 0 258 017 025: exact 1000mm overall lenght
Thank you that's amazing data!
You're welcome.
Should I pick out a couple more LSU-4.9 numbers with the lengths or is it enough?
Good for now, Harley project is first recipient.
Okay, all right. If you need anything else, let me know.
