MRE and EGT option
MRE and EGT option
Is able make EGT option "visible" in any future release ..?
due to: https://rusefi.com/forum/viewtopic.php?p=43270#p43270
- Screenshot_20211121_101205.png (91.4 KiB) Viewed 13248 times
Re: MRE and EGT option
Done
Well
still waiting for Godot ...
Thanks.
Thanks.
I still can't see EGT option in TS ...
(stable 20211114)
(stable 20211114)
What is the relation between "Sun Nov 21" done and 2021-11-14 version?
SORRY ....
I'm an idiot ... ...
You are in best company here!
..it is thereee..... and IT WORKS ...
- mre_egt.png (155.11 KiB) Viewed 12900 times
I'm got this error ....
no sensor connected (to MAX31855)
and MRE is conected, or to be connected to TS (via USB or BT)
MRE drop to FATAL, and engine STOP ...
(it is not too safe, when you overtake and something cut EGT senror wire)
it occur when EGT chip SPI & CS pin are selected,no sensor connected (to MAX31855)
What version of MRE firmware are you using for EGT to work? I connected MAX31855 to SPI3(PC10, PC11, PC12) and СS(PA 15) and EGT doesn't work.
I am using stm32f405 discovery. If you write the firmware from Frankenso, then the EGT works.
- 2022-03-30_075723.jpg (264.02 KiB) Viewed 11070 times
this is for microRusEFI ... not for others ...
We disabled it on MRE edit: looks like I was even the one who broke it, oops
Will be fixed soon: https://github.com/rusefi/rusefi/pull/4026
..in latest firmware ... ???
That linked pull request will merge some time tomorrow morning (8-12 hours from now), then it will be in the latest snapshot firmware.
I have 20220126 .. and it have EGT option ..
EDITED: but I can't test it at this moment ...
Correct, you do have it on 2022 01 26. It was broken after that.JRD McLAREN wrote: ↑Wed Mar 30, 2022 7:16 amI have 20220126 .. and it have EGT option ..
Thank's mck1117, EGT work.mck1117 wrote: ↑Wed Mar 30, 2022 6:42 amWe disabled it on MRE edit: looks like I was even the one who broke it, oops
On one SPI, egt and sd card do not work, either egt or sd card. Can you add the ability to disable flash memory on SPI2 in the TS menu so that you can connect a SD card to SPI2?
The SD card will be on SPI2, and on SPI3 there will be EGT.
- 2022-03-30_194742.jpg (185.97 KiB) Viewed 11032 times
rusEFI does not use flash memory at all there is nothing to disable.
please upload your tune to rusEFI online
please provide a URL of the exact dialog where you are failing to make a change
"doesn't work." is vague please use more of technical terms
SPI_1=true //for TLE8888
SPI_3=true //for SD, EGT and other
SPI_2 none
I want SD card and EGT to work. Because EGT and SD CARD don't work at the same time on SPI3.
board_configuration file
static void setupTle8888() {
// on microRusEFI SPI3 is exposed on PC10/PC11 and there is interest to use SD card there
// PB3/PB4 could be either SPI1 or SP3, let's use not SPI3 to address the contention
// Enable spi1
engineConfiguration->is_enabled_spi_1 = true;
// Wire up spi1
engineConfiguration->spi1mosiPin = GPIOB_5;
engineConfiguration->spi1misoPin = GPIOB_4;
engineConfiguration->spi1sckPin = GPIOB_3;
// Chip select
engineConfiguration->tle8888_cs = GPIOD_5;
// SPI device
engineConfiguration->tle8888spiDevice = SPI_DEVICE_1;
void setBoardConfigOverrides() {
setLedPins();
setupVbatt();
setupTle8888();
setupEtb();
engineConfiguration->clt.config.bias_resistor = 2700;
engineConfiguration->iat.config.bias_resistor = 2700;
engineConfiguration->canTxPin = GPIOB_6;
engineConfiguration->canRxPin = GPIOB_12;
// SPI for SD card
engineConfiguration->is_enabled_spi_3 = true;
engineConfiguration->sdCardSpiDevice = SPI_DEVICE_3;
engineConfiguration->spi3mosiPin = GPIOC_12;
engineConfiguration->spi3misoPin = GPIOC_11;
engineConfiguration->spi3sckPin = GPIOC_10;
Sorry do not follow, you've jumped from TS to board file I was not able to follow what leads to what
why? maybe proper route is to fix this defect in the code?
Okay Andrey, please fix it.
Why is flash memory needed on the MPE board?
- 2022-03-31_034455.jpg (39.43 KiB) Viewed 10937 times
Flash memory is not used ..
When I'm testing my addon borad, EGT and SDcard woks together on SPI3 bus .. ..
- Screenshot_20220331_103611.png (12.31 KiB) Viewed 10824 times
Make EGT work, again it does not work on the latest version of August 12th.
- 2022-09-11_144949.jpg (149.48 KiB) Viewed 7721 times
