It appears as though 2001-2004 6.6 LB7 Duramax used in silverados 2500HD & more, is basically the same, however with the addition of having 8 Cylinder control.
GM Part # 97720663
Bosch Part # 0281010014
Online they are ridiculous, but at my local junkyard im quoted $60 CAD. This may be a better option for me when working on DI stuff.
Who knows if this diesel FICM would still operate well enough with petrol DI?
Alternative To BMW DI module, Duramax FICM
"Dave B. 5:03 PM
Re: Alternative To BMW DI module, Duramax FICM
90,91 can bus
So you need car to sniff can-bus to start injector driver ...
Diesel DI is usually higher voltage right? I would be concerned that diesel injector peak/hold currents could be further away than BMW GDI settings.
No CanBus needed for this. But also easy, CANbus is my thing. CAN is only used for diagnostics as far as I recall, and itself takes no data in.
This I am concerned about yes.
EDIT: Andrey dont kill me, I'll upload better schematics with proper names in a bit.
- FICM 1.pdf
- (754.94 KiB) Downloaded 175 times
- FICM 2.pdf
- (531.43 KiB) Downloaded 177 times
"Dave B. 5:03 PM
