I'm use HC-05 for BT communication and ESP8285MOD for WiFi communication
(you can use any compatible modules)
Requirements:
HW side: any kind of serial communication module capable for TTL level signal (3.3Volts)
+ some wires
SW side: set "serial port" baudrate to 38400 8N1
+ all other required settings in TS
Wiring:
Connect "power pins" to power - GND, 5V or 3.3V to "any power source" - J8 header (or anything else)
Connect "signal pins" to RX and TX - on my mre 0.5.3 are J12 J13 headers - J12 is PB11 RX and J13 is PB10 TX
(it looks so easy ... at this moment
