As the title states, my TPS ADC value when the throttle is closed changes everytime I start the car after having it sit for a few hours. The full-throttle ADC value will stay consistent though. I am using honda CBR1000 bike throttles with an adapter harness I made from the Miata TPS plug to the CBR's TPS. This causes my car to run richer at low rpm and idle, I'm not sure if the TPS itself is at fault or if the wiring is the issue. I verified that the throttle is fully closed physically so I don't think the problem lies there. It's annoying to have to recalibrate the TPS whenever I need to drive...
Tune: https://rusefi.com/online/view.php?msq=1041
High value is closed and low value is full throttle. It's supposed to do that.
Anything I should check before I buy a replacement TPS and redo my adapter harness?
TPS closed ADC value changes
Nightsknight45
nmstec
Re: TPS closed ADC value changes
We've had a very similar problem on another car. Please confirm with a multimeter your voltage.
Last time this was a problem with the TPS itself, it was changing resistance with temperature.
Also we can't see your values, because your tune has no logs attached to it.
"Dave B. 5:03 PM
Nightsknight45
The car is reading around 4.5 volts when closed and around .30-.35 volts at W.O.T. I know those values should be swapped but that's how the honda TPS works in my situation.
Here is a link to a datalog I took yesterday: https://rusefi.com/online/view.php?log=850
nmstec
I mean check it when hot, then check when cold. See if theres a difference with multimeter.
"Dave B. 5:03 PM
BTW there's no such thing as "should be swapped" - that's the point of the TPS calibration process. So long as the sensor does something linear, it does the right thing. Electronic throttle bodies have a redundant pair of sensors that are usually roughly opposite, so one of them is always "backwards" as you describe, but it's by design.
Nightsknight45
Nightsknight45
Ok I see what you mean. I guess I was comparing the open and closed values from my stock setup. Thanks for the informationmck1117 wrote: ↑Tue May 31, 2022 5:59 pmBTW there's no such thing as "should be swapped" - that's the point of the TPS calibration process. So long as the sensor does something linear, it does the right thing. Electronic throttle bodies have a redundant pair of sensors that are usually roughly opposite, so one of them is always "backwards" as you describe, but it's by design.
Nightsknight45
Nightsknight45
Bought a new tps and the problem seems to have been remedied.
Simon@FutureProof
- Slack: Orchardperformance
We also had a similar problem and it was due to sensor drift when it was hot.
Something to do is check the raw voltages/ADC when the sensor is cold and then warm it up to see if it changes.
We were seeing drift in both the low and high end of the sensors signal, solved completely with a Honda CRV sensor.
