Rusefi tunerstudio plugin
It's all about the code!
ELMEPRO
Post by ELMEPRO »
Hello, im tried use rusefi ts plugin followed instructions but when i click on rusefi plugin nothing is opening, i tried on two different laptops, do im only one who doesent work plugin?
Tunerstudio 3.1.08
Java is the last version
Re: Rusefi tunerstudio plugin
Thank you for the report, I've just fixed the defect in TS plugin launcher.
ELMEPRO
Post by ELMEPRO »
Noup try again :D Or meybe my fault
Screenshot 2022-07-14 172109.jpg (11.8 KiB) Viewed 2381 times
Wow, never saw that one. Any details in TS log file?
ELMEPRO
Post by ELMEPRO »
Here are logs
when im trying add new fixed rusefi plugin.txt
(6.26 KiB) Downloaded 100 times
When i open non working rusefi plugin.txt
(6.44 KiB) Downloaded 86 times
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/rusefi/shared/FileUtil
at com.rusefi.ts_plugin.Updater.<clinit>(Updater.java:30)
at com.rusefi.ts_plugin.TsPluginLauncher.getPluginPanel(TsPluginLauncher.java:77)
that's the one I've fixed and things seem better on my end
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at aJ.g.v(Unknown Source)
at aJ.dR.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
this one let me report to TS people
