[info] Feature Requests - Feature Bounty Program
It's all about the code!
Zeiss
Re: Feature Requests - Feature Bounty Program
Post by Zeiss »
@Andrey and Matthew:
I would put $300 bounty at https://github.com/rusefi/rusefi/issues/3680
Plus:
– possibility to increase idle RPM, i.e. when AC is on
– possibility to temporary (depends of input state) increase RPM, I.e. when trany engages the gear ( change from N to D). It is something for Lua?
Thank you guys!
Regards,
Heinrich
My GitHub
Zeiss wrote:
Mon Aug 22, 2022 6:13 pm
Automatic or manual sync?
Plus:
We already support adding more air, but not adding target RPM. Trivial enough to add.
Thank you guys!
I think we've already had other asks for P/N vs D idle control, so this is indeed one worth doing. You could also do it with Lua, but it seems like a common enough ask.
Zeiss
Post by Zeiss »
mck1117 wrote:
Mon Aug 22, 2022 6:16 pm
Automatic, of course. Or a mix? Initial sync manual and then a kind of „keep air masses in sync“? Two MAFs and then balance the air mass, when the engine is warm and is idling, like the implementation of BMW/Bosch.
Plus:
This sounds very good! Something like „AC off = 600 rpm idle, AC on = 750 rpm idle“.
Thank you guys!
Sounds very good! I think, here are two features. First one is „change from P/N to D“ (increase RPM) and the second one is „reduce torque during gear change“. BMW achieve this by retarding the ignition.
Regards,
Heinrich
My GitHub
Zeiss wrote:
Mon Aug 22, 2022 6:50 pm
Plus:
wait, this is already done! We have a field "A/C target adder (RPM)" that will add some extra RPM when AC is turned on.
Zeiss
Post by Zeiss »
Perfect!
Where can I find this in TS.
Regards,
Heinrich
My GitHub
Zeiss
Post by Zeiss »
Thank you!
So, then $300 for trany stuff and ETB sync. :)
Regards,
Heinrich
My GitHub
Zeiss wrote:
Mon Aug 22, 2022 7:01 pm
Top-right corner of TS has search control! Took me 8 years to find out about that search feature. One day we shall add it on the rusEFI Online :)
