10th Anniversary #0739
10AE0739
Post by 10AE0739 »
Hey, I'm Jonathan and I drive a 10th Anniversary Miata. I've been modifying it since I got it in December 2019. I've been wanting to add a standalone ecu and start learning tuning for a long time and finally pulled the trigger on a BMM at MATG 2022. I enjoy learning and experimenting and want to share as much of what I learn as I can. I plan to use this thread to document my tuning and learning journey. This is very much a work in progress.
Mods:
Power:
Beer Money Motorsports ECU powered by RusEFI
Custom CAI with airbox and foglight air duct
Mazdaspeed Intake Camshaft
Racingbeat 4-1 Header
Cobalt Midpipe
Racingbeat Dual Tip Muffler
Moroso Oil Catch Can
DIY Audi R8 COP with Flowforce Bracket
Flowforce 380 Fuel Injectors
ATI Superdamper with 32/2 Timing Wheel
Flyin Miata Coolant Reroute
TDR 11.8 lb Flywheel
SPEC Stage 1 Clutch
Cosmetic/Exterior:
JDM Mazdaspeed Wing
Gen 1 SPEC Miata 949Racing 6UL Wheels
LRB Aluminum Undertray
Hard Dog M2 Sport Roll Bar
DanDak Sequential Third Brake Light
Morimoto Headlight Projector Retrofit with 5500k HIDs
Morimoto XB Fog Light
Interior:
Revlimiter 10AE Gauges
A Pillar Gauges: KaN Gauge and AEM Wideband
MiataRoadster Tall Angled Shifter
NB2 Black Leather Seats
Revlimiter Retro Window Switches
DIY Toggle Switch Panel (Replaces airbag switch)
Blue Seatbelts
Suspension:
FM Front Sway Bar
Hard S Rear Sway Bar
Speedsage Delrin Sway Bar Bushings with Zerks
Flyin Miata Frame Rails
OEM Bilstein Shocks
Superpro Poly Differential Inserts
DIY Modifications:
Relay to start in Neutral but not in Gear
Relay to power Wideband only when engine is running
Ignition light with fade
Switch to turn on license plate lights as trunk lights
Modified trunk lock to allow trunk lever lockout
Modified OEM Oil Pressure Gauge to work with true oil pressure sensor
Wired Window Switches directly to battery
Leather shifter and ebrake boots
Additional Sensors:
Aux 1 Oil Temp Sensor
Aux 2 Temp; varies, usually related to air temp testing
Oil Pressure Sensor
Future Projects:
JDM Squaretop Manifold
VVT Head with .020" shave
Micro RusEFI board as additional input controller
DIY Bilstein Coil Overs
Superpro Poly Bushings
3763807 (1).jpg (812.75 KiB) Viewed 4599 times
Re: 10th Anniversary #0739
Niiiice :)
I had a cool license plate back in Chicago but... A lot has changed since :)
10AE0739
Post by 10AE0739 »
Coming Soon: Temp and Pressure sensor info
10AE0739
Post by 10AE0739 »
Coming Soon: Idle tuning experience
10AE0739
Post by 10AE0739 »
Coming Soon: Wiring wideband so that sensor heater is only on when engine is running
10AE0739
Post by 10AE0739 »
Coming Soon: Micro RusEFI as input controller
10AE0739
Post by 10AE0739 »
Coming Soon: IAT sensor location
10AE0739
Post by 10AE0739 »
Coming Soon: DIY NB Miata Cold Air Intake
10AE0739
Post by 10AE0739 »
Coming Soon: DIY Knock Microphone
BeerMoneyMotorsports
Thanks for the upates! I look forward to seeing all the stuff you have been up to since matg. You have been busy!
