[info] How to compile the firmware
It's all about the code!
Tom_Alp
Re: How to compile the firmware
Post by Tom_Alp »
Hi Andrey,
Thanks for your answer, thus I'm using 'firmware' as suggested in your first post, not boot (which is a nested project if I'm correct).
Removed folders are not random, for sure that would not make sens. I was only an example, but this folders are not imported with the git command, they are created during compilation, by the makefile. So removing this folder was an example to restore the initial condition.
The 'make clean' command is not working properly here.
PS C:\Users\--\Source\Local_Git\rusefi\firmware> make clean
No CCACHE_DIR
PROJECT_BOARD: f407-discovery
PROJECT_CPU:   ARCH_STM32F4
CPU_HWLAYER:   ports/stm32/stm32f4
CONFDIR:       ./hw_layer/ports/stm32/stm32f4/cfg
LDSCRIPT:      ./hw_layer/ports/stm32/stm32f4/STM32F4.ld
rm -f ./pch/pch.h.gch/firmware
process_begin: CreateProcess(NULL, rm -f ./pch/pch.h.gch/firmware, ...) failed.
make (e=2): Le fichier spécifié est introuvable.
make: *** [rusefi_pch.mk:25: CLEAN_RULE_HOOK] Error 2
As I wrote down in the previous post, the incremental build is OK when it has been prepared manually :
But "Build All" option is not working.
Neo
Github Username: Benjamin-neo
Post by Neo »
Hi all,
Did you know the way to have all working on windows 11, at this moment I can only use older pc on win10...
Neo wrote:
Thu Feb 02, 2023 12:14 pm
Hi all,
Yes obviously everything works on win 11 just fine, reminder that windows 11 even self-identifies as Windows 10.
Please http://rusefi.com/s/questions
Neo
Post by Neo »
thanks for your answer, ok if you tell me compil firmware on Win11 is like win10, I will look at. I doesn't yet understand where is the failure, but I will try again, just asking if win11 is problematic before spend some hour.
mi-hol
Github Username: mi-hol
Post by mi-hol »
Hi Neo,
the recommended solution is to compile inside Windows Subsystem for Linux (WSL) in a Ubuntu 22.04 LTS environment.
Did you try that?
Best Regards
Michael
Benelli Tornado 900 Tre
Benelli TNT 1130 (rebuilding)
Neo
Post by Neo »
Yes , I just have try, Exactly same problem. I will format my computer, and maybe with a little lucky .. it will be good. Will post news when I find solution or tips. thanks
Well, technically we are on gcc 11 as of today https://github.com/rusefi/rusefi/commit/26b5a63d22df4800f1e1563e1dea33b0d2976837
But I've just installed gcc 12 and it did compile see https://github.com/rusefi/rusefi/issues/5031
Neo
Post by Neo »
Thanks to all for tips , fresh install win 10, install same version make4.4 gcc12.2 , work directly, compil without any problem. I don't known if win11 was the problem or a system corrupt file.
hugovw1976
Github Username: hugovw1976
Post by hugovw1976 »
I compile on Windows 11 make 4.4 gcc12 and work fine (just some error compiling for proteus but for other board compile fine) .
Icebear1983
Post by Icebear1983 »
Somehow I seem just to stupid to do the compilation ... for the wideband controller in my case.
GCC version 13 and GNU Make 4.4.1 on Windows 10 Pro
I always end up with "arm-none-eabi-objcopy: command not found"
The path variable has the correct link to the ARM_GNU toolchain.
Can maybe somebody point me in the right direction?
Icebear1983 wrote:
Thu Dec 21, 2023 8:41 pm
I can only suggest the workaround of using github actions since those work the same for everyone
zed65
Post by zed65 »
I'm trying to compile the master but it throws some errors:
Any ideas what the problem might be?
spaces in gcc path are the problem
zed65
Post by zed65 »
Hah! Thank you!
It was really that "easy".. Is that rule mentioned somewhere?
zed65 wrote:
Wed Jan 03, 2024 10:23 pm
https://github.com/rusefi/rusefi/issues/5861
Dron_Gus
Github Username: dron0gus
Post by Dron_Gus »
Wed Jan 03, 2024 10:01 pm
or brackets.
Atlantis2013
Post by Atlantis2013 »
Hi everyone,
I have a little problem, just update new tool chain kit arm and impossible for compiling.
overstack memory, new compiler use more bytes
thx
Atlantis2013
i back on 12.3 and its ok
