My01 Subaru Wrx ej205
007adr
Post by 007adr »
Hey everyone
im Andrew From Australia, i have audm my01 wrx that will be rusefi in the near future,
I have previously built a ms3 a wired up to a Nissan pulsar sss, i enjoy, like all of us diy and ecu tuning,
I currently are running a carberry flash tune, but hate flash tuning so are moving to the rusefi
MRE ordered and on its way, ive ordered a ecu header and will build a little patch harness to the factory engine harness,
stock
ej205 non avcs
vf35
1000cc
bigger newer sti intercooler
i will be uploading tune once ive got it working and is reasonably happy, to help the community
Re: My01 Subaru Wrx ej205
Welcome, we need more rusEFI subarus!
is 2001 still the 76 pin header? Random minor bits of info at https://github.com/rusefi/rusefi/wiki/Vault-of-Subaru probably not much valuable for you
@dron_gus is the head of rusEFI Subaru dept :)
007adr
Post by 007adr »
hey buddy
bugeye wrx are 122 pin same as toyota/mazda, 03 change to a different plug, at the time i couldn't find any ecu headers to suit in ref to Subaru, so i found the connector number and ordered from Alibaba and ordered 10 of them as a minimum order, then i found that they fit other things and you guys have a freaking setup already o well, if you want more ill happily sell the rest them for my cost,
Andrew
007adr
Post by 007adr »
this is the plan for the patch harness from the pigtail to the factory ecu, i need to buy a vr to hall for my cam sensor
MRE-WRX.xlsx
(7.65 KiB) Downloaded 172 times
If anyone see's any glairing problems please let me know
007adr
Post by 007adr »
ive got my ecu but cant update the firmware, installed drivers and getting this from the message window
Andrew Ross <jrfantom@gmail.com>
10:03 PM (12 minutes ago)
to me
Using selected COM10
Reboot command [reboot_dfu] sent into serial=COM10!
Giving time for USB enumeration...
Executing .\STM32_Programmer_CLI/bin/STM32_Programmer_CLI.exe -c port=usb1 -w "C:\Users\Andrew\Desktop\snapshot_20220831_023113_mre_f4_rusefi\console\..\rusefi.bin" 0x08000000 -v -s
STM32CubeProgrammer v2.11.0
Error: Target device not found
Establishing connection with the device failed
Done!
ERROR: Device not connected or STM32 Bootloader driver not installed?
ERROR: does not look like DFU has worked!
ERROR: Please try installing drivers using 'Install Drivers' button on rusEFI splash screen
ERROR: Alternatively please install drivers using Device Manager pointing at 'drivers/silent_st_drivers/DFU_Driver' folder
************* YOU NEED TO REMOVE LEGACY DFU DRIVER ***************
Devices: OK USB STM Device in DFU Mode USB\VID_...
after this point i can see it in device manager under stm32 bootloader
can the smart people help
"stm32 bootloader" with or without red icon in device manager?
if driver was installed it should work. try "swtich to DFU" and "manual DFU update" actions separately if your windows takes too much time to detect device?
007adr
Post by 007adr »
Stm32 boot loader is a little question mark and is not categorised as a usb device,
I tried that it just said unable to find device in the log
I think that’s due to the above
007adr
Post by 007adr »
got it sorted just played with drivers once in dfu mode
007adr
Post by 007adr »
Just a little update 122pin to MRE complete
Next step is to gut the tgv's and we should be good to plug it in
007adr
Post by 007adr »
Ive just seen the electronic wastegate video on youtube and thought to myself why dont i do that, so ive ordered a 06L145612 Turbo Wastegate Electronic Actuator from VAG cars for under $100 from aliexpress and i will integrate it into my project i dont think this will be too hard considering i have a few ins and out left over
007adr
Post by 007adr »
