Hello!
I just received my Proteus.
I'm about to start wiring it onto my Genesis coupe with a 4th gen LS in it.
I saw that GM 58x isn't part of the support list for the RusEFI.
Can I use the custom toothed wheel?
Thanks
GM 58x
Re: GM 58x
58x is just the GM name for ordinary 60-2 missing tooth.
Re: GM 58x
Yes
Also you really want to find existing proteus LS tunes. We might have LS proteus preset
Re: GM 58x
Engine size? ETB or cable? Throttle size?
"Dave B. 5:03 PM
Re: GM 58x
LY5, so 5.3 ETB, DOD deleted no VVT. I'm not sure about the exact size of the TB but it's the stock one.
Andrey, by preset, what do you mean exactly? A MSQ or the preset in the console?
Also, I already have an OK tune on my megasquirt for this engine, I thought on using that as a base
Re: GM 58x
My bad we do not have LS preset I was wrong
Re: GM 58x
https://rusefi.com/online/view.php?msq=1009ykill wrote: ↑Fri Feb 24, 2023 9:54 pmLY5, so 5.3 ETB, DOD deleted no VVT. I'm not sure about the exact size of the TB but it's the stock one.
Here you go. Tuned and running, but had cable throttle so idle is controlled via timing.
"Dave B. 5:03 PM
Re: GM 58x
nmstec wrote: ↑Mon Feb 27, 2023 1:27 amhttps://rusefi.com/online/view.php?msq=1009ykill wrote: ↑Fri Feb 24, 2023 9:54 pmLY5, so 5.3 ETB, DOD deleted no VVT. I'm not sure about the exact size of the TB but it's the stock one.
That's a 24x, right?
But thanks for the msq, I'll have a good base to start from!
Re: GM 58x
24x, but jsut change trigger pattern. Tune is good. Its for an LM7. Mck1117 Also has a very good tune but has a cam.
"Dave B. 5:03 PM
Re: GM 58x
Yeah, smallish cam though. But 24x with a gen4 ETB. Worth looking at both as reference.
https://rusefi.com/online/view.php?msq=1111
