I am in the process of building my 1984 E28, and my engine has evolved into a significant project.
Presently I have a 3.2L M30B32 which has custom forged pistons, (I will soon replace the connecting rods, I originally left the factory forged rods as I thought I would do no more than 500hp), we have an unsprung 6-puck clutch which we hope to hold the power, and I have forced induction.
My turbo is of the following size:
Exhaust:
IN:88.2
EX:77.5
Compressor:
IN: 69
EX:98.1
Exhaust A/R 1.05
Intake A/R 0.66
The supercharger is an eaton m90, normally found on 3.0 - 4.0L motors.
I am still building the intake manifold and (waiting on laser cut parts) my do two injector stages, one in the normal position near the back of the valve and the other shooting directly into the straight runner.
I was originally going to use two Speeduinos, one for ignition and one for fuel. The reasoning being that I also have an M70 (Maybe a 72 as it is aluminum?) V12 that may at some point be swapped into this chassis and I like the idea of not having to change the ECU.
Now that I know there is an open-source ECU that has 12x12 control channels I am thinking that the Proteus is the correct ECU for both the twincharged 6 and later the V12.
I have worked with arduinos in the past so I am looking for any initial information or resources that I should know/review before getting into the rusEFI Proteus. Any comments are welcome.
Side note: does the tuning software for Proteus work in a Linux environment?
Inside the mocked up plenum.
Stock BMW N54 turbo VS the M30 Turbo
Lowered on custom fabricated airLift suspension
