MAP Sync and how it works
It's all about the code!
NormanAlphaspeed
Post by NormanAlphaspeed »
An FSAE team that have an AlphaECU 2chan are trying to get MAP sync working on their Kawasaki EX300 engine with an intake manifold (since it's turbocharged) working, but they have not been succesful.
Here is a log of the engine not turning on with MAP sync:
https://rusefi.com/online/view.php?log=1223
And here is a log of MAP sync working on a Yamaha FZ09 engine:
https://github.com/rusefi/rusefi/files/11312116/2022-06-14_20.46.00.mlg.zip
I'm still trying to wrap my head around how it works??
Thread created for permanent reference
Re: MAP Sync and how it works
	if (engineConfiguration->vvtMode[0] == VVT_MAP_V_TWIN &&
			Sensor::getOrZero(SensorType::Rpm) < engineConfiguration->cranking.rpm) {
		// we are trying to figure out which 360 half of the total 720 degree cycle is which, so we compare those in 360 degree sense.
		auto toothAngle360 = currentPhase;
		while (toothAngle360 >= 360) {
			toothAngle360 -= 360;
		if (mapCamPrevToothAngle < engineConfiguration->mapCamDetectionAnglePosition && toothAngle360 > engineConfiguration->mapCamDetectionAnglePosition) {
			// we are somewhere close to 'mapCamDetectionAnglePosition'
			// warning: hack hack hack
			float map = engine->outputChannels.instantMAPValue;
			// Compute diff against the last time we were here
			float diff = map - mapCamPrevCycleValue;
			mapCamPrevCycleValue = map;
			if (diff > 0) {
				mapVvt_map_peak++;
				int revolutionCounter = getTriggerCentral()->triggerState.getCrankSynchronizationCounter();
				mapVvt_MAP_AT_CYCLE_COUNT = revolutionCounter - prevChangeAtCycle;
				prevChangeAtCycle = revolutionCounter;
				hwHandleVvtCamSignal(TriggerValue::RISE, timestamp, /*index*/0);
				hwHandleVvtCamSignal(TriggerValue::FALL, timestamp, /*index*/0);
#if EFI_UNIT_TEST
				// hack? feature? existing unit test relies on VVT phase available right away
				// but current implementation which is based on periodicFastCallback would only make result available on NEXT tooth
				getLimpManager()->onFastCallback();
#endif // EFI_UNIT_TEST
			mapVvt_MAP_AT_SPECIAL_POINT = map;
			mapVvt_MAP_AT_DIFF = diff;
		mapCamPrevToothAngle = toothAngle360;
So we see that only syncs at RPM below cranking and that it's looking at instant MAP not just MAP
We see that it's about "diff" being positive or negative, and diff is difference of instant MAP at the "mapCamDetectionAnglePosition" engine position.
So depending on where is your sync point on your trigger mapCamDetectionAnglePosition "MAP readout angle" setting would have to be different.
Do you have a link to Yamaha FZ09 tune?
https://rusefi.com/online/?vehicleName=FXLRS&user_id=1662 or https://rusefi.com/online/?vehicleName=RoadKing+TEST&user_id=1662 could be helpful
In canned tune I see engineConfiguration->mapCamDetectionAnglePosition = 50;
NormanAlphaspeed
https://rusefi.com/online/view.php?msq=1093
Link to FZ09 tune
-_________________
I think there is a problem at setting the detection angle at 50, because for some reason with VTwin by MAP active, the count starts at 360 and goes up to 720, so 50 degrees never happens
