SBC HEI
SBC HEI
Playing with that HEI module https://rusefi.com/forum/viewtopic.php?p=31888#p31888 on a bench.
Proteus uses GPPWM to tell HEI who is in charge - below say 300 RPM it's HEI doing cranking timing and above 300 it's rusEFI doing timing.
channel 1 tach signal - purple wire with a white trace - pin R
channel 2 coil tach output
channel 3 ignition override - tan wire with a black trace - pin B
channel 4 advance control - white wire - pin E
Here HEI is in charge (channel #3 on the image is low)
WhatsApp Image 2023-04-30 at 13.45.33.jpg (273.55 KiB) Viewed 8998 times
Re: SBC HEI
My tune https://rusefi.com/online/view.php?msq=1461
Here rusEFI controls timing.
WhatsApp Image 2023-04-30 at 13.55.43.jpg (286 KiB) Viewed 8997 times
Re: SBC HEI
On the other hand why even bother allowing HEI to even control timing? Just feed constant +5v to override pin and make life easier.
WhatsApp Image 2023-04-30 at 14.04.12.jpg (258.06 KiB) Viewed 8996 times
Re: SBC HEI
Or you simply ignore the whole HEI - hook up pickup coil as VR input and use external igniter. This works as is but custom/better trigger would be needed (or just nice to have?) to pick up less noise. Current implementation with skipped 8/0 wheel does not allow for redundant gap checks.
Re: SBC HEI
https://rusefi.com/online/view.php?msq=1530
https://rusefi.com/online/view.php?log=1272
WhatsApp Image 2023-08-09 at 15.25.00.jpg (418.99 KiB) Viewed 8064 times
