startPwm(0, 100, 0)
startPwm(1, 100, 0)
startPwm(2, 100, 0)
setTickRate(5) -- set tick rate to 1hz
function onTick()
TPS = getSensor("Tps1")
ger1 = readPin("PF0")
ger2 = readPin("PF1")
ger3 = readPin("PC13")
ger4 = readPin("PE6")
print('TPS: ' ..TPS)
print('gear1: ' ..ger1)
print('gear2 ' ..ger2)
print('gear3 ' ..ger3)
print('gear4 ' ..ger4)
print('status PF5 ' ..readPin("PF5"))
print('status PF4 ' ..readPin("PF4"))
print('status PF3 ' ..readPin("PF3"))
print('status PF2 ' ..readPin("PF2"))
if ger1 == 0 or ger4 == 0 then
setPwmDuty(1, 1.0)
else
setPwmDuty(1, 0.0)
end
if ger2 == 0 or ger4 == 0 then
setPwmDuty(2, 1.0)
else
setPwmDuty(2, 0.0)
end
if ger3 == 0 and TPS < 5 then
setPwmDuty(0, 1)
else
setPwmDuty(0, 0)
end
end
