Hi!
Have questions about bmw cam trigger settings.
As M54 and M5x series engine uses missing tooth 60/2 on crank and poll level type for both cams.
Alternative could be used single tooth cam type, this could impact egine starting if im correct.
What is the basic settings for this kind of engines on RusEfi?
One more question.
Is the RusEfi using falling edge for hall triggers? Im worry about ignition angle drift at high rpm if using rising edge with filtering caps like 4.7nF etc.
Thanks!
BMW M54 Trigger Settings
LemonX
- Github Username: Zazins
