NA Miata EcotecMiata Race Car
mtmotorsport
Re: NA Miata EcotecMiata Race Car
To be honest the tune changed each time I flipped the wiring/position so I'm not sure which one that tune correlates to. I can redo this if you think it would be of benefit.
Matt
MT Motorsport / EcotecMiata
Nope, at the moment I am not sure how to use all that data.
How do you calibrate TPS?
I wonder if the issue is with auto-calibrate. Note that you have a 4% split at 24% TPS that's already a huge red flag, let's focus on that crazy split. What is 24% is that ETB resting point?
Can you calibrate manually? Let's try two different strategies and see how it goes:
* let's temporary calibrate ETB resting point ("Disable ETB if engine is stopped" setting) and manual WOT position with your fingers
* fully shot and WOT position with your fingers
mtmotorsport
Manually holding the throttle closed and open is how I did calibrate it. ETB motor off. Resting throttle is around 20-25% depending on which AV channels are used and which way around they are wired.
Matt
Just added TPS split gauges similar to PPS split gauge which we already had - until now tps splits were available in the logs but not as gauges https://github.com/rusefi/rusefi/commit/063495a87010d0070f28801054728092a51d3fc1
Please create a log with manual throttle movement, let's have zero split at 0% and 100% and see what that split does in the middle.
saabrich
OP, do you have a build log, or more information on how you mounted the B207R ?
I have 2 Miatas and a Saab 9-3 B207R that is running a touch over 300bhp, the car itself is a bit tatty and I was thinking about transplanting it into the miata.
Thanks!
Thanks!
mtmotorsport
www ecotecmiata.ca
You'll want an 8 bolt flywheel kit for the 2.0L engine. Stock location turbos clear the chassis with lots of room. You'll need to bypass and block off the oil cooler and run a remote one.
Matt
mtmotorsport
Is it possible to add something like this screenshot to the ETB system? This is allowed TPS error percentage in the OE GM calibration.
Matt
user can now reduce TPS/PPS split error thresholdmtmotorsport wrote: ↑Tue Oct 17, 2023 12:11 amIs it possible to add something like this screenshot to the ETB system? This is allowed TPS error percentage in the OE GM calibration.
bottom of pedal settings dialog
https://github.com/rusefi/rusefi/issues/5620
mtmotorsport
