Update ECU definition from internet seems to be broken at least on Windows
TS no longer downloads fresh .ini files automatically for me, can someone who uses Windows confirm or deny having same issue?
I believe this is about TS having too old version of JRE 1.8.0_66 from back 2015 emended. I've actually replaced cacerts file with a file from a fresh 1.8 JRE instance and got the issue resolved.
https://github.com/rusefi/rusefi/issues/5536
Re: Update ECU definition from internet seems to be broken at least on Windows
PS: corresponding log line in TunerStudioAppDebug.txt is
Debug: Failed to get ini: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested targetVery limited telepathic abilities - please post logs & tunes where appropriate - http://rusefi.com/s/questions
Oh right, it's the annual rusefi.com certificate update and 25% of the 1.8.0_66 CA certificates have already expired.
- NormanAlphaspeed
- Contact:
large amount of end users in panic because choosing ini file is too difficult
AlphaX Auto Electronics
Tuned by AlphaSpeed
Tuned by AlphaSpeed
- NormanAlphaspeed
- Contact:
More reports of angry people
Tuned by AlphaSpeed
Tuned by AlphaSpeed
Work-around is now documented at https://github.com/rusefi/rusefi/wiki/JRE#tunerstudio-cacerts-work-around
Are you recommending that users install a custom certificate authority globally for all Java apps? That's TERRIBLE security advice. You know better than that.AndreyB wrote: ↑Sun Sep 24, 2023 10:37 pmWork-around is now documented at https://github.com/rusefi/rusefi/wiki/JRE#tunerstudio-cacerts-work-around
Please see where you are wrong.
On my end let me spell out source of cacerts file
So it is just for TS, but it's still a risk. TS is using that file for downloading updates to TS, which then run as administrator on your PC. So you've now installed a CA (if only to TS) that can serve files that are expected to grant admin rights.
Can you explain the actual issue that requires adding a CA?
https://github.com/rusefi/rusefi/wiki/JRE#tunerstudio-cacerts-work-around clarifies source of cacerts file, thank you for your feedback.
Matt please read github ticket in first post and let me know if I can clarify anything beyond what is already documented.
rusEFI bundles now contain 'update-ts-cacerts' folder with fixts.bat
- NormanAlphaspeed
- Contact:
~credit to norman for writing a crappy batch file
Tuned by AlphaSpeed
Tuned by AlphaSpeed
