Looking to set rusEFI on a 2022 Canam side-by-side vehicles.
2022 Canam
2022 Canam
Re: 2022 Canam
I have the wiring diagram but I am failing to comprehend it
https://github.com/rusefi/rusefi_documentation/blob/master/OEM-Docs/CanAm/SSV%202022%20MAVERICK%20-%20Wiring%20Diagram.pdf (same file has two versions of the pinout just to make it more fun)
Seat belt switch how hard could that be right? With stock ECU Pin B OR/VI wire reads some sort of switched +12 volts. It goes to a JT (junction?) with VT/GY? Which goes where? Maybe same is mentioned as oxygen sensor heater+?
Re: 2022 Canam
Well there is also this legend saying that green color code is ground. So the +12v I am seeing is some pull-up. Weird.
Re: 2022 Canam
Have you develop more for this veicle? I need to build one ecu for this, new version, very similar to hellen 112 17 but different pinout
Re: 2022 Canam
Ha, the black one has fuel system issues but stock ECU deals with it! We have a chance to play with closed loop range settings
Re: 2022 Canam
Polaris is more or less the same thing, just totally different.
53 inches seems to be the perfect length if you need to do the same.
