2022 Canam
2022 Canam
Looking to set rusEFI on a 2022 Canam side-by-side vehicles.
WhatsApp Image 2023-11-15 at 19.23.07_d54be4fa.jpg (278.42 KiB) Viewed 28392 times
Re: 2022 Canam
I have the wiring diagram but I am failing to comprehend it :(
https://github.com/rusefi/rusefi_documentation/blob/master/OEM-Docs/CanAm/SSV%202022%20MAVERICK%20-%20Wiring%20Diagram.pdf (same file has two versions of the pinout just to make it more fun)
Seat belt switch how hard could that be right? With stock ECU Pin B OR/VI wire reads some sort of switched +12 volts. It goes to a JT (junction?) with VT/GY? Which goes where? Maybe same is mentioned as oxygen sensor heater+?
Re: 2022 Canam
Well there is also this legend saying that green color code is ground. So the +12v I am seeing is some pull-up. Weird.
Alex90
Re: 2022 Canam
Post by Alex90 »
Screenshot_20240114_112030_Adobe Acrobat.jpg (293.62 KiB) Viewed 25903 times
Hi dear, i' m Alessandor, i work on brp seadoo very similar to this, maybe somethink was wrong, i try to find new eletrical diagram but sure lambda heater going in this junction, see fuse name.
Have you develop more for this veicle? I need to build one ecu for this, new version, very similar to hellen 112 17 but different pinout
Re: 2022 Canam
Ha, the black one has fuel system issues but stock ECU deals with it! We have a chance to play with closed loop range settings
WhatsApp Image 2024-03-14 at 13.45.23_7eb0e610.jpg (327.86 KiB) Viewed 15702 times
Re: 2022 Canam
Polaris is more or less the same thing, just totally different.
53 inches seems to be the perfect length if you need to do the same.
WhatsApp Image 2024-05-27 at 17.18.36_29b3fd48.jpg (296.18 KiB) Viewed 5788 times
