Micro vs uaefi
cpipkin6.5x55
Micro vs uaefi
Post by cpipkin6.5x55 »
I am looking at doing an efi upgrade on my harley. What's the difference between the microrusefi and the uaefi?
Sent from my SM-G991U using Tapatalk
Re: Micro vs uaefi
proper connector and proper case are the advantages of microrusEFI
on a harley you would need dual channel WBO
what year harley/what motor?
cpipkin6.5x55
Re: Micro vs uaefi
Um working on a 97 flhtcui evo engine factory fuel injection with cam and crank sensor
Re: Micro vs uaefi
So not CANbus, does this have Automatic Compression Release (ACR) valves?
cpipkin6.5x55
Re: Micro vs uaefi
No canbus no compression release. It is a fairly simple efi system. Inputs on the bike are engine temp, intake airtemp, vss map and tps sensor . Output are fuel injector coils and fuel pump and cruse control. I have to add a wide band sensor or two.
Re: Micro vs uaefi
cpipkin6.5x55 wrote:
Wed Feb 07, 2024 4:04 am
you _really_ need two sensors.
cpipkin6.5x55
Re: Micro vs uaefi
Ok 2 widebands it is I was thinking uaefi will that support 2 who or do I need to go to microrusefi
zed65
Re: Micro vs uaefi
Post by zed65 »
and cruse control.
How does the cruise control work? Electronic throttle body?
cpipkin6.5x55
Re: Micro vs uaefi
Cable operated cruise control module. Same modual works with the carb modules so I don't think ecm does anything other than pass vss to it
Re: Micro vs uaefi
Wed Feb 07, 2024 4:45 am
Just realized that this is a small mess
On the bright side we have https://www.shop.rusefi.com/shop/p/dual-channel-wbo
On the other side https://github.com/rusefi/uaefi/issues/45
* uaefi has one CAN-based WBO on board
* firmware does not support mixing CAN and analog
* external dual channel CAN would conflict with on-board?
* firmware can go use dual external analog which would be LAME
cpipkin6.5x55
Re: Micro vs uaefi
So I could go uaefi with dual analog wbo2 or microrusefi with dual can bus wbo2modual?
Re: Micro vs uaefi
Looks like that yes.
cpipkin6.5x55
Re: Micro vs uaefi
Does dual wide band controller come with a plug for the harness side?
Re: Micro vs uaefi
Yes, it comes with a crimp kit
cpipkin6.5x55
Re: Micro vs uaefi
Will ot work with clone sensors or only bosch?
