The car is a real rustbucket that we decided to use as a Ice racing car the last part of its life! And things get out of hand pretty fast (as always?
So first we had to replace the engine, and that's no real problem if you live in the land of b230 (Swedens LS). So we put in a fresh(er) engine that's only done 290000km
And when you already have torn everything apart already you just can't leave it stock can you? Ofc not! So the engine got a Holset hx35w (chinese) Siemens deka 875cc, bosch 044 (chinese) and ofc a rusEFI uaEFI!
We are using the original coil, ignitor, distributor almost everything stock, just added some sensors such as GM 3bar map sensor and bosch IAT, bosch tps from Volvo 850.
We were hoping to have made some 300hp this weekend but we ran in to some boost creep problems unfortunately
But we took the turbo apart and ported the wastegate port and modified the twin entry (Wall?) And hopefully this works! I will update when theres progress made
