[help needed] Dual "Dual channel WBO Controller" for quad lambda reading
It's all about the code!
0me6a_
Github Username: EragonPower
Slack: 0me6a
Post by 0me6a_ »
Hi everybody,
I 've got a Proteus, and i'm just starting to plan a wire harness for a 4 rotor, and i was wondering if i there could be a way to use two Dual channel WBO Controller to read from a total of four lambda sensors, one for each rotor, and at the same time, also read four EGTs.
Is it possible to have something like this? I'm not greatly concerned over which lambda sensor to use for calculating fuel, i would see something like an average reading be used for that, i'm more concerned over differences between rotors, both in lambda, and in EGT.
If a feature like that is not available, i'd love to be able to contribute, but C++ is still new for me.
Thanks in advance to everyone that can give an opinion about that.
Dron_Gus
Github Username: dron0gus
Re: Dual "Dual channel WBO Controller" for quad lambda reading
Post by Dron_Gus »
Two dual channel WBO can read 4 sensors. And 4 EGTs. Note that EGT is optional. You'll need to populate MAX chips.
RusEFI ECU itself currently support only two WBOs/banks.
