740 Turbo
turbomuts
740 Turbo
Post by turbomuts »
Hello, new here and from Sweden. I’m trying to install a Uaefi in my Volvo 740. The car was originally a 740 GLT with a 16V engine, but I bought it without an engine, gearbox, or rear axle. I took all those parts from a 940 Turbo instead. I completely rebuilt the B230 engine — it’s bored 0.060" over, and I replaced the connecting rods with H-beam ones. The cylinder head was swapped to a “531 head,” which I ported and replaced all the worn parts in. For the camshaft, I’m using a VX3 from a B230FB engine, and the turbo is a new TD04 19T.
With Rusefi, I’m trying to keep it as plug-and-play as possible with such an old ECU setup like LH2.4. In the PnP harness, I’m using the functions for controlling the ignition box, all relays such as the fuel relay, etc. I’ve also wired in the engine temperature sensor and the VR signal from my 60-2 flywheel. However, that stopped working — I’m getting a lot of missing teeth, so I’ll try running separate wires to it, like I already did with the MAP sensor, IAT, and TPS.
I’m afraid I may have damaged the board when I cleaned off the flux residue I missed after soldering the Molex connectors on the board using isopropanol. After that, I started getting interference on the VR signal, and I also get the message “C9012: out-of-order coil of coil 1” in the Rusefi console. I even get that error when I run a spark test in the console with only the Uaefi board connected to the computer.
Re: 740 Turbo
I would assume that you have not broken anything. Some of our warnings are known to be false unfortunatelly.
turbomuts
Re: 740 Turbo
Post by turbomuts »
The car runs without missing any teeth when i use the standard Ecu runs fine. but i am going to try new wiring to the Vr sensor now. i am most affraid of the error C9012: out-of-order coil of coil 1 did not have that code before i clean the ecu and i get it without hook up to anything
Dron_Gus
Github Username: dron0gus
Re: 740 Turbo
Post by Dron_Gus »
Are vr wires twisted? Shielded?
turbomuts
Re: 740 Turbo
Post by turbomuts »
I redid all my wiring and went through everything, and I think I found a big mistake :-(
I had connected the activation for my main relay and fuel pump relay to B9 Main Relay Weak Low Side Output 1 and B16 Low Side Output 4 / Fuel Pump Relay, but when I looked at the car’s original wiring diagram, those are supposed to be grounded, not receive a control voltage.
Yet the relays still clicked on, so I’ve probably managed to damage something.
mpgmike
Re: 740 Turbo
Post by mpgmike »
"Low Side Output" is a grounding circuit; it either grounds the output or it doesn't. Your rusEFI Low Side Outputs should go to one activation pin of the relay (pin 85 on the relay) and keyed power to the other (pin 86 of the relay). It sounds like you probably did it right.
mpgmike
Re: 740 Turbo
Post by mpgmike »
Oops, somehow made a duplicate post.
turbomuts
Re: 740 Turbo
Post by turbomuts »
mpgmike wrote:
Sat Oct 11, 2025 1:15 pm
okey then i did right :-( then i don´t know what i did wrong
