[rusEfi] 1995 Dodge Neon
Re: 1995 Dodge Neon
I made a system schematic using Dia which is a program very similar to visio. It's multi platform ect. I like Dia for system schematics as it's fairly easy to use, it allows you to kind of connect colored wires, and it allows layers. This means someone else can take this schematic, hide a layer, re-draw a layer and make their own system schematic. Here is a picture of a draft copy of what it would/could produce.
[edit above broken link fixed]
I need to connect things to the correct input pins and such, however it's a draft and a starting point.
Thoughts? Is this a worth while effort, are there better options?
Source files found here. [edit] https://sourceforge.net/p/daecu/code/HEAD/tree/Hardware/trunk/rusefi.com/frankenstein/system_schematics/ was originally found at this link http://code.google.com/p/daecu/source/browse/Hardware/trunk/rusefi.com/frankenstein/system_schematics/ [/edit]
Re: 1995 Dodge Neon
The injector and especially the sparks are too small, barely visible. The rest is pretty cool :)
Re: 1995 Dodge Neon
Before we forget - can you please post your 'showconfig' so that I can put this into the default configuration? Quite often while updating you latest version configuration would be lost, so we want a valid default config.
erikmag
Re: 1995 Dodge Neon
Post by erikmag »
Can you run this engine without the camshaft sensor?
Re: 1995 Dodge Neon
erikmag wrote:
Tue Feb 27, 2018 1:56 am
I think so
erikmag
Re: 1995 Dodge Neon
Post by erikmag »
what trigger angle offset do you use
erikmag
Re: 1995 Dodge Neon
Post by erikmag »
what trigger angle use
