Wideband Controller: Fully Custom, no ASIC!
Dron_Gus
Github Username: dron0gus
Re: Wideband Controller: Fully Custom, no ASIC!
Post by Dron_Gus »
kimman1 wrote:
Sun Apr 21, 2024 3:25 am
I'm just finishing lamba x2
The problem is when I connect the lsu 4.2. Just about 30 second after heating, the temperature notification on tunner studio is sensor overheat.
I attached log below. Please help me
Attached the is latest file
Did you change settings to LSU4.2? By default WBO is configured for LSU4.9.
Also you have too low "Ipump actual" compared to "Ipump target". Please check LSU_Ip circuit: U12B, values of R12, R42, R45, R18, R21.
kimman1
Github Username: kimman1
Post by kimman1 »
Dron_Gus wrote:
Wed Apr 24, 2024 7:22 am
Ah. I also think like you. I've checked for all wire for make sure wiring is correct ( Before I have wrong wiring ) . So I think the U9 (GS8832) is dead, trying replacing U9 but the error still there. The R41 is 6K8 0.1% ( missing in order from LCSC ) I replace it with 6.8K 1% , but still error :D . After that, I just only solder R24 and try testing with LSU 4.9 sensor and the problem fixed
NickZ
Post by NickZ »
Can someone please help with the current firmware (rusEFI master.2024.04.18.f407-discovery.1378508940) and these wideband controllers. Originally on older firmware and using TS to update the controllers they would work, but randomly go into a error (blue led started flashing), Updating the ECU to 2024.04.18 and then updating the wideband controllers from TS, the wideband does not go into a error now, but there is no reading in TS or on my dash. I get very random readings on the TS where the outline (last position) needle jumps around but the display never moves from displaying zero.
Just adding that the AEM canbus Wideband is working perfectly on the same settings.
NickZ
Post by NickZ »
Where in the wideband firmware is the Can bus speed set, I would like to change it to 1k from the 500 speed.
Dron_Gus
Post by Dron_Gus »
NickZ wrote:
Thu Jul 18, 2024 11:40 pm
https://github.com/mck1117/wideband/blob/c7f1a17b00861ee072901a82ac26a8fc7ca08469/firmware/boards/f0_module/port_shared.cpp#L14
Larspars
Github Username: larsnergard
Post by Larspars »
Hi guys
I'm trying to compile the firmware for f0_module but it does not seem to "bake" the bootloader.bin together with the firmware. Can someone have a look at the terminal output and point me in a direction?
I use WSL and Visual Code. The wideband.bin file is 24kB and I can see that the "baked" file available for download is 31kB. So I am missing something.
Ctrl->shift->B->Build F0 module image
Executing task: ./build_wideband.sh
Cleaning
- ./.dep
- ./build
Done
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m0 -mthumb -Os -ggdb -fomit-frame-pointer -falign-functions=16 -fsingle-precision-constant -DWB_PROD=1 -Wl,--defsym=USE_BOOTLOADER=1 -ffunction-sections -fdata-sections -fno-common -flto -Wall -Wextra -Wundef -Wstrict-prototypes -Wa,-alms=./build/lst/ -DCORTEX_USE_FPU=FALSE -MD -MP -MF ./.dep/build.d -I. -I./cfg -I../../../ChibiOS/os/license -I../../../ChibiOS/os/common/portability/GCC -I../../../ChibiOS/os/common/startup/ARMCMx/compilers/GCC -I../../../ChibiOS/os/common/startup/ARMCMx/devices/STM32F0xx -I../../../ChibiOS/os/common/ext/ARM/CMSIS/Core/Include -I../../../ChibiOS/os/common/ext/ST/STM32F0xx -I../../../ChibiOS/os/hal/include -I../../../ChibiOS/os/hal/ports/common/ARMCMx -I../../../ChibiOS/os/hal/ports/STM32/STM32F0xx -I../../../ChibiOS/os/hal/ports/STM32/LLD/ADCv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/CANv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/DACv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/DMAv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/EXTIv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/GPIOv2 -I../../../ChibiOS/os/hal/ports/STM32/LLD/I2Cv2 -I../../../ChibiOS/os/hal/ports/STM32/LLD/RTCv2 -I../../../ChibiOS/os/hal/ports/STM32/LLD/SPIv2 -I../../../ChibiOS/os/hal/ports/STM32/LLD/TIMv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/USART -I../../../ChibiOS/os/hal/ports/STM32/LLD/USARTv2 -I../../../ChibiOS/os/hal/ports/STM32/LLD/USBv1 -I../../../ChibiOS/os/hal/ports/STM32/LLD/xWDGv1 -I../../../ChibiOS/os/hal/osal/rt-nil -I../../../ChibiOS/os/rt/include -I../../../ChibiOS/os/oslib/include -I../../../ChibiOS/os/common/ports/ARMv6-M -I../../../ChibiOS/os/common/ports/ARMv6-M/compilers/GCC -I../../../libfirmware/util/include -I../../../shared/ -I../io -I../.. main.c -o main.o
Compiling crt0_v6m.S
Compiling vectors.S
Compiling chcoreasm.S
Compiling crt1.c
Compiling hal.c
Compiling hal_st.c
Compiling hal_buffers.c
Compiling hal_queues.c
Compiling hal_flash.c
Compiling hal_mmcsd.c
Compiling hal_can.c
Compiling hal_pal.c
Compiling nvic.c
Compiling stm32_isr.c
Compiling hal_lld.c
Compiling hal_can_lld.c
Compiling stm32_dma.c
Compiling stm32_exti.c
Compiling hal_pal_lld.c
Compiling hal_st_lld.c
Compiling osal.c
Compiling chsys.c
Compiling chdebug.c
Compiling chtrace.c
Compiling chvt.c
Compiling chschd.c
Compiling chthreads.c
Compiling chregistry.c
Compiling chsem.c
Compiling chmtx.c
Compiling chcond.c
Compiling chmsg.c
Compiling chdynamic.c
Compiling chmemcore.c
Compiling chmemheaps.c
Compiling chcore.c
Compiling board.c
Compiling util_dummy.cpp
Compiling crc.cpp
Compiling fragments.cpp
Compiling math.cpp
Compiling bootloader.cpp
Compiling port_shared.cpp
Compiling flash.cpp
Linking build/wideband_bootloader.elf
lto-wrapper: warning: Options to Xassembler do not match: -alms=./build/lst/crt1.lst, -alms=./build/lst/hal.lst, dropping all -Xassembler and -Wa options.
Creating build/wideband_bootloader.hex
Creating build/wideband_bootloader.bin
Creating build/wideband_bootloader.dmp
Creating build/wideband_bootloader.list
text data bss dec hex filename
5828 0 5888 11716 2dc4 build/wideband_bootloader.elf
Done
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m0 -mthumb -O2 -ggdb -fomit-frame-pointer -falign-functions=16 -fsingle-precision-constant -DWB_PROD=1 -Wl,--defsym=USE_BOOTLOADER=1 -ffunction-sections -fdata-sections -fno-common -flto -Wall -Wextra -Wundef -Wstrict-prototypes -Wa,-alms=./build/lst/ -DCORTEX_USE_FPU=FALSE -MD -MP -MF ./.dep/build.d -I. -Iboards/f0_module -IChibiOS/os/license -IChibiOS/os/hal/include -IChibiOS/os/hal/osal/rt-nil -IChibiOS/os/rt/include -IChibiOS/os/oslib/include -IChibiOS/os/hal/lib/streams -IChibiOS/os/various/cpp_wrappers -IChibiOS/os/hal/lib/complex/mfs -IChibiOS/os/common/portability/GCC -IChibiOS/os/common/startup/ARMCMx/compilers/GCC -IChibiOS/os/common/startup/ARMCMx/devices/STM32F0xx -IChibiOS/os/common/ext/ARM/CMSIS/Core/Include -IChibiOS/os/common/ext/ST/STM32F0xx -IChibiOS/os/hal/ports/common/ARMCMx -IChibiOS/os/hal/ports/STM32/STM32F0xx -IChibiOS/os/hal/ports/STM32/LLD/ADCv1 -IChibiOS/os/hal/ports/STM32/LLD/CANv1 -IChibiOS/os/hal/ports/STM32/LLD/DACv1 -IChibiOS/os/hal/ports/STM32/LLD/DMAv1 -IChibiOS/os/hal/ports/STM32/LLD/EXTIv1 -IChibiOS/os/hal/ports/STM32/LLD/GPIOv2 -IChibiOS/os/hal/ports/STM32/LLD/I2Cv2 -IChibiOS/os/hal/ports/STM32/LLD/RTCv2 -IChibiOS/os/hal/ports/STM32/LLD/SPIv2 -IChibiOS/os/hal/ports/STM32/LLD/TIMv1 -IChibiOS/os/hal/ports/STM32/LLD/USART -IChibiOS/os/hal/ports/STM32/LLD/USARTv2 -IChibiOS/os/hal/ports/STM32/LLD/USBv1 -IChibiOS/os/hal/ports/STM32/LLD/xWDGv1 -IChibiOS/os/common/ports/ARMv6-M -IChibiOS/os/common/ports/ARMv6-M/compilers/GCC -Ilibfirmware/util/include -Iutil/ -Iutil/math/ -Iconsole/binary/ -Iboards/ -Ishared/ -Iboards/f0_module/io/ main.c -o main.o
Compiling vectors.S
Compiling main_hardfault_asm.S
Compiling hal.c
Compiling hal_st.c
Compiling hal_adc.c
Compiling hal_can.c
Compiling hal_pal.c
Compiling hal_pwm.c
Compiling osal.c
Compiling chsys.c
Compiling chdebug.c
Compiling chtrace.c
Compiling chvt.c
Compiling chschd.c
Compiling chprintf.c
Compiling memstreams.c
Compiling nullstreams.c
Compiling hal_mfs.c
Compiling crt1.c
Compiling nvic.c
Compiling hal_lld.c
Compiling hal_adc_lld.c
Compiling hal_pwm_lld.c
Compiling chcore.c
Compiling board.c
Compiling ch.cpp
Compiling syscalls_cpp.cpp
Compiling port.cpp
Compiling crc.cpp
Compiling math.cpp
Compiling pid.cpp
Compiling sampling.cpp
Compiling heater_control.cpp
Compiling timer.cpp
Compiling flash.cpp
Compiling can.cpp
Compiling can_helper.cpp
Compiling fault.cpp
Compiling lambda_conversion.cpp
Compiling pwm.cpp
Compiling dac.cpp
Compiling pump_dac.cpp
Compiling pump_control.cpp
Compiling max3185x.cpp
Compiling uart.cpp
Compiling auxout.cpp
Compiling indication.cpp
Compiling sampling_thread.cpp
Compiling heater_thread.cpp
Compiling main.cpp
main.cpp:41:5: warning: "TS_ENABLED" is not defined, evaluates to 0 [-Wundef]
41 | #if TS_ENABLED
Linking build/wideband.elf
/usr/lib/gcc/arm-none-eabi/10.3.1/../../../arm-none-eabi/bin/ld:app.ld:90: warning: memory region `shared' not declared
lto-wrapper: warning: Options to Xassembler do not match: -alms=./build/lst/hal.lst, -alms=./build/lst/hal_st.lst, dropping all -Xassembler and -Wa options.
Creating build/wideband.hex
Creating build/wideband.bin
Creating build/wideband.dmp
Creating build/wideband.list
Creating build/wideband.srec
18208 6148 5888 30244 7624 build/wideband.elf
Done
18224+0 records in
18224+0 records out
18224 bytes (18 kB, 18 KiB) copied, 0.077755 s, 234 kB/s
./build_wideband.sh: line 33: crc32: command not found
* The terminal process "/bin/bash '-c', './build_wideband.sh'" terminated with exit code: 127.
* Terminal will be reused by tasks, press any key to close it.
Cheers
Larspars wrote:
Wed Aug 28, 2024 5:40 pm
I am not a nice person, I have a few snarky comments here.
Larspars
Post by Larspars »
Wed Aug 28, 2024 5:51 pm
You replied and pointed me in a direction like I asked, so you're kind of nice :)
I will look into it further.
Cheers
Larspars
Post by Larspars »
For the next person running in to the same error.
sudo apt-get install libarchive-zip-perl
It includes CRC32
https://www.etas.com/download-center-files/products_ES600/etas-es63x.1-user-guide-en-202110.pdf 3.5.1 and 3.5.2 calls out six (?) kinds of LSUs
Bosch Lambda Sensors LSU 4.2, LSU 4.9 and LSU 5.2 in the less smart category and LSU ADV-G (Code A7), LSU ADV-D (Code 1) and LSU 5.1 in a smarter (?) category. And then NTK Lambda Sensors ZFAS-D, ZFAS-U2 and ZFAS-U3.
diegort5
Post by diegort5 »
Good morning everyone, today I am writing to ask for help, I have assembled a pair of rusefi wbo x0, I have already compiled the firmware, uploaded it to the board, connected the wbo to the microrusefi 0.6. 0 board and configured the wideband parameters, updated the firmware from tunerstudio and the green led is alternating, so far everything is fine when trying to heat the bosch 0258 017 359 sensor immediately the board sends an error 4 times blue led sensor overheat, but I touch it and it is cold, I perform the same test with the sensor disconnected and it sends me the same error, thank you in advance for the help
DATALOG
2025-02-23_10.25.37 sensor conected
2025-02-23_10.38.06 sensor disconected
Dron_Gus
Post by Dron_Gus »
Please double check sensor - controller wiring. Seems incorrect.
JRD McLAREN
Post by JRD McLAREN »
are you have my add-on board ..?? or not ..??
(i'm not sure, casue it was year++ ago, when we talking about it ... )
diegort5
Post by diegort5 »
diegort5 wrote:
Sun Feb 23, 2025 3:18 pm
DATALOG
HUMAN ERROR :lol:
problem solved, error in resistor R14, put a 62 OHM resistor and it is a 62K resistor, thanks, it is already working with a 61k resistor while I get the correct one
